- 功能簡介:
- 該例程為數(shù)碼管顯示可調(diào)鐘表(無定時(shí)功能),用到TX-1C開發(fā)板中矩陣鍵盤的上三排按鍵。
- 若要更改時(shí)鐘初始值(即時(shí)鐘校準(zhǔn),因?yàn)闀r(shí)鐘初始值全為0),可先按下矩陣鍵盤中的S16鍵
- (第三排第三列),此時(shí)時(shí)鐘會暫停。
- 然后按S6---S15中的鍵修改矯正當(dāng)前值,S6--S15分別先后對應(yīng)數(shù)字0到9。
- 矯正完后,按下S17(第三排最后一個(gè)),時(shí)鐘可繼續(xù)工作。
- 注意晶振需為11.0592M。
- 若為其他數(shù)值晶振,請合理改變TH0與TL0參數(shù)值,否則計(jì)時(shí)會有很大誤差 。
- #include<reg51.h>
- #define uchar unsigned char
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit beep=P2^3;
- unsigned char j,k,a1,a0,b1,b0,c1,c0,s,f,m,key=10,temp,qq;
- uchar shi20,shi10,fen20,fen10,miao20,miao10,new,ok=1,wei;
- unsigned int pp;
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- void delay(unsigned char i)
- for(j=i;j>0;j--)
- for(k=125;k>0;k--);
- void display(uchar shi2,uchar shi1,uchar fen2,uchar fen1,uchar miao2,uchar miao1)
- dula=0;
- P0=table[shi2];
- dula=1;
- dula=0;
- wela=0;
- P0=0xfe;
- wela=1;
- wela=0;
- delay(5);
- P0=table[shi1]|0x80;
- dula=1;
- dula=0;
- P0=0xfd;
- wela=1;
- wela=0;
- delay(5);
- P0=table[fen2];
- dula=1;
- dula=0;
- P0=0xfb;
- wela=1;
- wela=0;
- delay(5);
- P0=table[fen1]|0x80;
- dula=1;
- dula=0;
- P0=0xf7;
- wela=1;
- wela=0;
- delay(5);
- P0=table[miao2];
- dula=1;
- dula=0;
- P0=0xef;
- wela=1;
- wela=0;
- delay(5);
- P0=table[miao1];
- dula=1;
- dula=0;
- P0=0xdf;
- wela=1;
- wela=0;
- delay(5);
- void keyscan0()
- P3=0xfb;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xbb:
- ok=0;
- break;
- case 0x7b:
- ok=1;
- break;
- void keyscan()
- P3=0xfe;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xee:
- key=0;
- wei++;
- break;
- case 0xde:
- key=1;
- wei++;
- break;
- case 0xbe:
- key=2;
- wei++;
- break;
- case 0x7e:
- key=3;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xfd;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xed:
- key=4;
- wei++;
- break;
- case 0xdd:
- key=5;
- wei++;
- break;
- case 0xbd:
- key=6;
- wei++;
- break;
- case 0x7d:
- key=7;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xfb;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xeb:
- key=8;
- wei++;
- break;
- case 0xdb:
- key=9;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- void main()
- TMOD=0x01;
- TH0=(65536-46080)/256;// 由于晶振為11.0592,故所記次數(shù)應(yīng)為46080,計(jì)時(shí)器每隔50000微秒發(fā)起一次中斷。
- TL0=(65536-46080)%256;//46080的來歷,為50000*11.0592/12
- ET0=1;
- EA=1;
- while(1)
- { keyscan0();
- if(ok==1)
- { TR0=1;
- wei=0;
- if(pp==20)
- { pp=0;
- m++;
- if(m==60)
- m=0;
- f++;
- if(f==60)
- f=0;
- s++;
- if(s==24) //為24h一個(gè)循環(huán),若要12h,只需在此改為12即可。
- s=0;
- a0=s%10;
- a1=s/10;
- b0=f%10;
- b1=f/10;
- c0=m%10;
- c1=m/10;
- display(a1,a0,b1,b0,c1,c0);
- else
- { TR0=0;
- keyscan();
- if(key!=10)
- switch(wei)
- case 1: if(key<3) //小時(shí)最高位為2
- a1=key;
- else
- wei--;
- break;
- case 2: if(a1==1|a1==0)
- a0=key;
- else
- if(key<5)
- a0=key; //當(dāng)小時(shí)最高位為2時(shí),低位最高為4
- break;
- case 3: if(key<7) //分鐘最高位為6
- b1=key;
- else
- wei--;
- break;
- case 4: b0=key; break;
- case 5: if(key<7) //秒最高位為6
- c1=key;
- else
- wei--;
- break;
- case 6: c0=key; break;
- key=10;
- m=c1*10+c0;
- f=b1*10+b0;
- s=a1*10+a0;
- void time0() interrupt 1
- { TH0=(65536-46080)/256;
- pp++;
全部資料51hei下載地址:
12、鐘表(可矯正時(shí)間).zip
(22.2 KB, 下載次數(shù): 8)
2019-1-12 22:12 上傳
點(diǎn)擊文件名下載附件
鐘表(可矯正時(shí)間)
