我用stm32移植到ucos輸出18b20
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "timer.h"
- #include "pwm.h"
- #include "includes.h"
- #include "ds18b20.h"
- //UCOSIII中以下優(yōu)先級(jí)用戶程序不能使用,ALIENTEK
- //將這些優(yōu)先級(jí)分配給了UCOSIII的5個(gè)系統(tǒng)內(nèi)部任務(wù)
- //優(yōu)先級(jí)0:中斷服務(wù)服務(wù)管理任務(wù) OS_IntQTask()
- //優(yōu)先級(jí)1:時(shí)鐘節(jié)拍任務(wù) OS_TickTask()
- //優(yōu)先級(jí)2:定時(shí)任務(wù) OS_TmrTask()
- //優(yōu)先級(jí)OS_CFG_PRIO_MAX-2:統(tǒng)計(jì)任務(wù) OS_StatTask()
- //優(yōu)先級(jí)OS_CFG_PRIO_MAX-1:空閑任務(wù) OS_IdleTask()
- //任務(wù)優(yōu)先級(jí)
- #define START_TASK_PRIO 3
- //任務(wù)堆棧大小
- #define START_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB StartTaskTCB;
- //任務(wù)堆棧
- CPU_STK START_TASK_STK[START_STK_SIZE];
- //任務(wù)函數(shù)
- void start_task(void *p_arg);
- #define TASK1_TASK_PRIO 4
- //任務(wù)堆棧大小
- #define TASK1_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Task1_TaskTCB;
- //任務(wù)堆棧
- CPU_STK TASK1_TASK_STK[TASK1_STK_SIZE];
- void task1_task(void *p_arg);
- #define TASK2_TASK_PRIO 5
- //任務(wù)堆棧大小
- #define TASK2_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Task2_TaskTCB;
- //任務(wù)堆棧
- CPU_STK TASK2_TASK_STK[TASK2_STK_SIZE];
- //任務(wù)函數(shù)
- void task2_task(void *p_arg);
- short temperature;
- u8 t=0;
- //LCD刷屏?xí)r使用的顏色
- int lcd_discolor[14]={ WHITE, BLACK, BLUE, BRED,
- GRED, GBLUE, RED, MAGENTA,
- GREEN, CYAN, YELLOW,BROWN,
- BRRED, GRAY };
- //主函數(shù)
- int main(void)
- OS_ERR err;
- CPU_SR_ALLOC();
- delay_init(); //時(shí)鐘初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//中斷分組配置
- uart_init(115200); //串口初始化
- LED_Init(); //LED初始化
- LCD_Init(); //LCD初始化
- //TIM1_PWM_Init(299,719);//頻率3ms
- //TIM3_Int_Init(20000,7199);//2S中斷一次,10hz,2000ms
- POINT_COLOR = RED;
- LCD_ShowString(60,50,200,16,16,"Mini STM32");
- LCD_ShowString(60,70,200,16,16,"DS18B20 TEST");
- LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(60,110,200,16,16,"2014/3/12");
- OSInit(&err); //初始化UCOSIII
- OS_CRITICAL_ENTER(); //進(jìn)入臨界區(qū)
- //創(chuàng)建開始任務(wù)
- OSTaskCreate((OS_TCB * )&StartTaskTCB, //任務(wù)控制塊
- (CPU_CHAR * )"start task", //任務(wù)名字
- (OS_TASK_PTR )start_task, //任務(wù)函數(shù)
- (void * )0, //傳遞給任務(wù)函數(shù)的參數(shù)
- (OS_PRIO )START_TASK_PRIO, //任務(wù)優(yōu)先級(jí)
- (CPU_STK * )&START_TASK_STK[0], //任務(wù)堆棧基地址
- (CPU_STK_SIZE)START_STK_SIZE/10, //任務(wù)堆棧深度限位
- (CPU_STK_SIZE)START_STK_SIZE, //任務(wù)堆棧大小
- (OS_MSG_QTY )0, //任務(wù)內(nèi)部消息隊(duì)列能夠接收的最大消息數(shù)目,為0時(shí)禁止接收消息
- (OS_TICK )0, //當(dāng)使能時(shí)間片輪轉(zhuǎn)時(shí)的時(shí)間片長度,為0時(shí)為默認(rèn)長度,
- (void * )0, //用戶補(bǔ)充的存儲(chǔ)區(qū)
- (OS_OPT )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR, //任務(wù)選項(xiàng)
- (OS_ERR * )&err); //存放該函數(shù)錯(cuò)誤時(shí)的返回值
- OS_CRITICAL_EXIT(); //退出臨界區(qū)
- OSStart(&err); //開啟UCOSIII
- //開始任務(wù)任務(wù)函數(shù)
- OS_ERR err;
- CPU_SR_ALLOC();
- p_arg = p_arg;
- CPU_Init();
- #if OS_CFG_STAT_TASK_EN > 0u
- OSStatTaskCPUUsageInit(&err); //統(tǒng)計(jì)任務(wù)
- #endif
- #ifdef CPU_CFG_INT_DIS_MEAS_EN //如果使能了測量中斷關(guān)閉時(shí)間
- CPU_IntDisMeasMaxCurReset();
- #endif
- #if OS_CFG_SCHED_ROUND_ROBIN_EN //當(dāng)使用時(shí)間片輪轉(zhuǎn)的時(shí)候
- //使能時(shí)間片輪轉(zhuǎn)調(diào)度功能,時(shí)間片長度為1個(gè)系統(tǒng)時(shí)鐘節(jié)拍,既1*5=5ms
- OSSchedRoundRobinCfg(DEF_ENABLED,1,&err);
- #endif
- //創(chuàng)建TASK1任務(wù)
- OSTaskCreate((OS_TCB * )&Task1_TaskTCB,
- (CPU_CHAR * )"Task1 task",
- (OS_TASK_PTR )task1_task,
- (void * )0,
- (OS_PRIO )TASK1_TASK_PRIO,
- (CPU_STK * )&TASK1_TASK_STK[0],
- (CPU_STK_SIZE)TASK1_STK_SIZE/10,
- (CPU_STK_SIZE)TASK1_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- //創(chuàng)建TASK2任務(wù)
- OSTaskCreate((OS_TCB * )&Task2_TaskTCB,
- (CPU_CHAR * )"task2 task",
- (OS_TASK_PTR )task2_task,
- (void * )0,
- (OS_PRIO )TASK2_TASK_PRIO,
- (CPU_STK * )&TASK2_TASK_STK[0],
- (CPU_STK_SIZE)TASK2_STK_SIZE/10,
- (CPU_STK_SIZE)TASK2_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- OSTaskDel((OS_TCB*)0,&err); //刪除start_task任務(wù)自身
- //task1任務(wù)函數(shù)
- //u8 task1_num=0;
- // u8 t=0;
- // OS_ERR err;
- CPU_SR_ALLOC();
- p_arg = p_arg;
- //short temperature;
- // POINT_COLOR = BLACK;
- // LCD_DrawRectangle(5,110,115,314); //畫一個(gè)矩形
- // LCD_DrawLine(5,130,115,130); //畫線
- // POINT_COLOR = BLUE;
- // LCD_ShowString(6,111,110,16,16,"Task1 Run:000");
- while(DS18B20_Init()) //DS18B20初始化
- LCD_ShowString(60,130,200,16,16,"DS18B20 Error");
- delay_ms(200);
- LCD_Fill(60,130,239,130+16,WHITE);
- delay_ms(200);
- LCD_ShowString(60,130,200,16,16,"DS18B20 OK");
- POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
- LCD_ShowString(60,150,200,16,16,"Temp: . C");
- while(1)
- { printf("任務(wù)5已經(jīng)執(zhí)行次\r\n");
- if(t%10==0)//每100ms讀取一次
- temperature=DS18B20_Get_Temp();
- if(temperature<0)
- LCD_ShowChar(60+40,150,'-',16,0); //顯示負(fù)號(hào)
- temperature=-temperature; //轉(zhuǎn)為正數(shù)
- }else LCD_ShowChar(60+40,150,' ',16,0); //去掉負(fù)號(hào)
- LCD_ShowNum(60+40+8,150,temperature/10,2,16); //顯示正數(shù)部分
- LCD_ShowNum(60+40+32,150,temperature%10,1,16); //顯示小數(shù)部分
- delay_ms(10);
- t++;
- if(t==20)
- t=0;
- LED0=!LED0;
- //task2任務(wù)函數(shù)
- u8 task2_num=0;
- OS_ERR err;
- CPU_SR_ALLOC();
- p_arg = p_arg;
- //POINT_COLOR = BLACK;
- // LCD_DrawRectangle(125,110,234,314); //畫一個(gè)矩形
- // LCD_DrawLine(125,130,234,130); //畫線
- // LCD_ShowString(126,111,110,16,16,"Task2 Run:000");
- while(1)
- task2_num++; //任務(wù)2執(zhí)行次數(shù)加1 注意task1_num2加到255的時(shí)候會(huì)清零!
- // LED1=~LED1;
- printf("任務(wù)2已經(jīng)執(zhí)行:%d次\r\n",task2_num);
- // LCD_ShowxNum(206,111,task2_num,3,16,0x80); //顯示任務(wù)執(zhí)行次數(shù)
- // LCD_Fill(126,131,233,313,lcd_discolor[13-task2_num%14]); //填充區(qū)域
- OSTimeDlyHMSM(0,0,1,0,OS_OPT_TIME_HMSM_STRICT,&err); //延時(shí)1s
UCOSIII輸出DS18B20.7z
(409.92 KB, 下載次數(shù): 54)
2019-1-13 16:05 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
