查看: 3663|回復(fù): 3
基于普中科技51單片機(jī)的單向單個(gè)交通燈程序
ID:432757 發(fā)表于 2019-1-17 18:46 | 顯示全部樓層 |閱讀模式
  1. #include "reg52.h"                //根據(jù)實(shí)驗(yàn)程序秒表改的
  2. typedef unsigned int u16;
  3. typedef unsigned char u8;
  4. sbit LSA=P2^2;
  5. sbit LSB=P2^3;
  6. sbit LSC=P2^4;
  7. sbit red=P2^7;
  8. sbit yellow=P2^6;
  9. sbit green=P2^5;//三個(gè)LED分別表示紅黃綠
  10. u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//顯示0~F的值
  11. u8 ssec,sec;
  12. u8 DisplayData[2];
  13. void delay(u16 i)
  14. {
  15. while(i--);
  16. }
  17. void Timer0Init()  //定時(shí)器初始化
  18. {
  19. TMOD|=0x01;
  20. TH0=0xd8;
  21. TL0=0xf0;  //10ms
  22. ET0=1;
  23. EA=1;
  24. TR0=1;
  25. }
  26. void DigDisplay()
  27. {
  28. u8 i;
  29. for(i=0;i<2;i++)
  30. {
  31. switch(i)
  32. {
  33. case(0):LSA=0;LSB=0;LSC=0;break;
  34. case(1):LSA=1;LSB=0;LSC=0;break;
  35. }
  36. P0=DisplayData[i];
  37. delay(100);
  38. P0=0x00;
  39. }
  40. }
  41. void Timer0() interrupt 1
  42. {
  43. TH0=0xd8;
  44. TL0=0xf0;
  45. ssec++;
  46. if(ssec>=100)
  47. {
  48. ssec=0;
  49. sec++;
  50. if(sec>=0&&sec<=10) //紅燈點(diǎn)亮,同時(shí)倒計(jì)時(shí)10s
  51. {
  52. red=0;
  53. yellow=1;
  54. green=1;
  55. }
  56. if(sec>=11&&sec<=15) //黃燈閃爍,同時(shí)倒計(jì)時(shí)5s
  57. {
  58. red=1;
  59. yellow=~yellow;
  60. green=1;
  61. }
  62. if(sec>=16&&sec<=25) //綠燈點(diǎn)亮,同時(shí)倒計(jì)時(shí)10s
  63. {
  64. red=1;
  65. yellow=1;
  66. green=0;
  67. }
  68. if(sec>25)                         //sec置0,實(shí)現(xiàn)循環(huán)
  69. {
  70. red=0;
  71. yellow=1;
  72. green=1;
  73. sec=0;
  74. }
  75. }}
  76. void datapros()
  77. {
  78. if(sec>=0&&sec<=10)
  79. {
  80. DisplayData[0]=smgduan[(10-sec)%10];        //紅燈倒計(jì)時(shí)
  81. DisplayData[1]=smgduan[(10-sec)/10];
  82. }
  83. if(sec>=11&&sec<=15)
  84. {
  85.   DisplayData[0]=smgduan[(15-sec)%10];         //黃燈倒計(jì)時(shí)
  86. DisplayData[1]=smgduan[(15-sec)/10];
  87. }
  88. if(sec>=16&&sec<=25)
  89. {
  90.   DisplayData[0]=smgduan[(25-sec)%10];  //綠燈倒計(jì)時(shí)
  91. DisplayData[1]=smgduan[(25-sec)/10];
  92. }
  93. }
  94. void main()
  95. {
  96. Timer0Init();
  97. while(1)
  98. {
  99. datapros();
  100. DigDisplay();
  101. }
  102. }
ID:1146304 發(fā)表于 2025-3-25 22:38 | 顯示全部樓層
led的d3,d4,d5.能不能不亮,只有d6d7d8在按照中斷點(diǎn)亮和熄滅
ID:548675 發(fā)表于 2019-6-5 14:17 | 顯示全部樓層
怎么給它加個(gè)按鍵比如k1 ,讓紅燈一直亮
ID:540976 發(fā)表于 2019-5-17 20:35 | 顯示全部樓層
you proteus tu ma
