#include<reg52.h>
#include <intrins.h>
sbit rw=P2^5;//一下三行是設(shè)置lcd1602的使能端
sbit rs=P2^6;
sbit ep=P2^7;
typedef bit BOOL;
uchar t,A1,A2,A3,A4,A5,A6,Flag=0,count,H,L;
void delay(uchar ms) //延時(shí)
uchar i;
while(ms--)
for(i=0;i<100;i++);
BOOL lcd_bz()//測(cè)試lcd忙碌狀態(tài)返回值為布爾型數(shù)值真或假'1'.'0'
BOOL result;
rs=0; // 讀忙信號(hào)
rw=1;
ep=1;
_nop_();
_nop_();
_nop_();
_nop_();
result=(BOOL)(P0&0x80);
ep=0;
return(result) ;
void write_cmd(uchar cmd)//寫(xiě)指令
while (lcd_bz());
rs=0;
rw=0;
ep=0;
_nop_();
_nop_();
P0=cmd ;
_nop_();
_nop_();
_nop_();
_nop_();
ep=1;
_nop_();
_nop_();
_nop_();
_nop_();
ep=0;
void write_addr(uchar addr)//寫(xiě)地址
write_cmd(addr|0x80);//LCD第一行的首地址為0x80第二行的首地址為0x80+0x40=0xc0
void write_byte(uchar dat) //寫(xiě)字節(jié)
while (lcd_bz());
rs=1;
rw=0;
ep=0;
_nop_();
_nop_();
P0=dat ;
_nop_();
_nop_();
_nop_();
_nop_();
ep=1;
_nop_();
_nop_();
_nop_();
_nop_();
ep=0;
void lcd_init() //lcd初始化
write_cmd(0x38);//設(shè)置LCD兩行顯示一個(gè)數(shù)據(jù)由5*7點(diǎn)陣表示,數(shù)據(jù)由8跟線傳輸
write_cmd(0x0c);//清除屏幕顯示
write_cmd(0x06);//設(shè)定輸入方式增量不移位
write_cmd(0x01);//開(kāi)整體顯示關(guān)光標(biāo)不閃爍
void display(uchar addr,uchar q)//在某一地址上顯示內(nèi)容adder表示的是地址偏移量q表示顯示的字符或數(shù)字
write_addr(addr);
write_byte(q);
delay(1);//修改此時(shí)間�?梢愿淖僉CD上數(shù)值跳變的數(shù)度
void init()
TMOD = 0x51;
TH0 = (65535-45872)/256;
TL0 = (65535-45872)%256;
TH1 = 0x00;
TL1 = 0x00;
ET0 = 1;
ET1 = 1;
EA = 1;
TR0 = 1;
TR1 = 1;
void Time0() interrupt 1
TL0 = 0x00;
TH0 = 0x4c;
t++;
if (t == 20)
TR0 = 0;
TR1 = 0;
t = 0;
Flag = 1;
void Time1() interrupt 3
count++;
unsigned long x;
P3 = 0xFF;
init();
lcd_init();
while (1)
if (Flag)
H = TH1;
L = TL1;
x = ((count*65535)+(H*256)+L);
A1=x/100000;
A2=x%100000/10000;
A3=x%10000/1000;
A4=x%1000/100;
A5=x%100/10;
A6=x%10;
Flag = 0;
count = 0;
TH1 = 0x00;
TL1 = 0x00;
TR1 = 1;
TR0 = 1;
display(0x00,A1+0x30);
display(0x01,A2+0x30);
display(0x02,A3+0x30);
display(0x03,A4+0x30);
display(0x04,A5+0x30);
display(0x05,A6+0x30);
