- /* USER CODE BEGIN Header */
- * @file : main.c
- * @brief : Main program body
- ** This notice applies to any and all portions of this file
- * that are not between comment pairs USER CODE BEGIN and
- * USER CODE END. Other portions of this file, whether
- * inserted by the user or by software development tools
- * are owned by their respective copyright owners.
- * COPYRIGHT(c) 2019 STMicroelectronics
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "oled.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- uint8_t tx_buf[7]={0x42,0x4d,0xab,0x00,0x00,0x01,0x3a};
- uint8_t aRxBuffer[50];
- volatile uint8_t CNT=0;
- uint16_t PM_VAL;
- uint16_t TVOC_VAL_H ;
- uint16_t TVOC_VAL_L ;
- uint16_t HCHO_VAL_H ;
- uint16_t HCHO_VAL_L;
- uint16_t CO2_VAL;
- uint16_t TEM_VAL_H;
- uint16_t TEM_VAL_L;
- uint16_t HIM_VAL_H;
- uint16_t HIM_VAL_L;
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- TIM_HandleTypeDef htim2;
- TIM_HandleTypeDef htim3;
- UART_HandleTypeDef huart1;
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_USART1_UART_Init(void);
- static void MX_TIM2_Init(void);
- static void MX_TIM3_Init(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_USART1_UART_Init();
- MX_TIM2_Init();
- MX_TIM3_Init();
- /* USER CODE BEGIN 2 */
- HAL_TIM_Base_Start_IT(&htim2);
- OLED_Init();
- OLED_Clear();
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- HAL_UART_Receive_IT(&huart1,(uint8_t*)aRxBuffer,24);
- OLED_ShowString(25,0,"AIR-SENSER");
- OLED_ShowString(0,2,"CO2:");
- OLED_ShowString(65,2,"HH:");
- OLED_ShowString(105,2,".");
- OLED_ShowString(0,4,"HIM:");
- OLED_ShowString(49,4,".");
- OLED_ShowString(65,4,"TEM");
- OLED_ShowString(113,4,".");
- OLED_ShowString(0,6,"TVOC");
- OLED_ShowString(41,6,".");
- OLED_ShowString(65,6,"PM");
- OLED_ShowNum(97,6,PM_VAL,3,12);
- OLED_ShowNum(33,2,CO2_VAL,4,12);
- OLED_ShowNum(97,4,TEM_VAL_H,2,12);
- OLED_ShowNum(121,4,TEM_VAL_L,1,12);
- OLED_ShowNum(33,4, HIM_VAL_H,2,12);
- OLED_ShowNum(57,4, HIM_VAL_L,1,12);
- OLED_ShowNum(97,2, HCHO_VAL_H,1,12);
- if(HCHO_VAL_L<10)
- OLED_ShowNum(113,2, 0,1,12);
- OLED_ShowNum(121,2, HCHO_VAL_L,1,12);
- }else OLED_ShowNum(113,2, HCHO_VAL_L,2,12);
- OLED_ShowNum(33,6,TVOC_VAL_H,1,12);
- if(HCHO_VAL_L<10)
- OLED_ShowNum(49,6,0,1,12);
- OLED_ShowNum(57,6,TVOC_VAL_L,1,12);
- }else OLED_ShowNum(49,6, TVOC_VAL_L,2,12);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- * @brief TIM2 Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN TIM2_Init 0 */
- /* USER CODE END TIM2_Init 0 */
- TIM_ClockConfigTypeDef sClockSourceConfig = {0};
- TIM_MasterConfigTypeDef sMasterConfig = {0};
- /* USER CODE BEGIN TIM2_Init 1 */
- /* USER CODE END TIM2_Init 1 */
- htim2.Instance = TIM2;
- htim2.Init.Prescaler = 49999;
- htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
- htim2.Init.Period = 71999;
- htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
- htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
- if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
- Error_Handler();
- sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
- if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
- Error_Handler();
- sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
- sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
- if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN TIM2_Init 2 */
- /* USER CODE END TIM2_Init 2 */
- * @brief TIM3 Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN TIM3_Init 0 */
- /* USER CODE END TIM3_Init 0 */
- /* USER CODE BEGIN TIM3_Init 1 */
- /* USER CODE END TIM3_Init 1 */
- htim3.Instance = TIM3;
- htim3.Init.Prescaler = 9999;
- htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
- htim3.Init.Period = 71999;
- htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
- htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
- if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
- Error_Handler();
- if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
- Error_Handler();
- if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN TIM3_Init 2 */
- /* USER CODE END TIM3_Init 2 */
- * @brief USART1 Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN USART1_Init 0 */
- /* USER CODE END USART1_Init 0 */
- /* USER CODE BEGIN USART1_Init 1 */
- /* USER CODE END USART1_Init 1 */
- huart1.Instance = USART1;
- huart1.Init.BaudRate = 9600;
- huart1.Init.WordLength = UART_WORDLENGTH_8B;
- huart1.Init.StopBits = UART_STOPBITS_1;
- huart1.Init.Parity = UART_PARITY_NONE;
- huart1.Init.Mode = UART_MODE_TX_RX;
- huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
- huart1.Init.OverSampling = UART_OVERSAMPLING_16;
- if (HAL_UART_Init(&huart1) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN USART1_Init 2 */
- /* USER CODE END USART1_Init 2 */
- * @brief GPIO Initialization Function
- * @param None
- * @retval None
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- /*Configure GPIO pin Output Level */
- HAL_GPIO_WritePin(GPIOA, CS_Pin|RES_Pin|DC_Pin|D0_Pin
- |D1_Pin, GPIO_PIN_SET);
- /*Configure GPIO pins : CS_Pin RES_Pin DC_Pin D0_Pin
- D1_Pin */
- GPIO_InitStruct.Pin = CS_Pin|RES_Pin|DC_Pin|D0_Pin
- |D1_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /* USER CODE BEGIN 4 */
- void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
- if(htim==(&htim2)){
- HAL_UART_Transmit(&huart1,tx_buf,7,10);
- if(htim==(&htim3)){
- OLED_ShowNum(105,6,PM_VAL,3,12);
- OLED_ShowNum(25,2,CO2_VAL,3,12);
- OLED_ShowNum(89,2,TEM_VAL_H,2,12);
- OLED_ShowNum(113,2,TEM_VAL_L,2,12);
- OLED_ShowNum(25,4, HIM_VAL_H,2,12);
- OLED_ShowNum(49,4, HIM_VAL_L,2,12);
- OLED_ShowNum(97,4, HCHO_VAL_H,2,12);
- OLED_ShowNum(113,4, HCHO_VAL_L,2,12);
- OLED_ShowNum(33,6,TVOC_VAL_H,2,12);
- OLED_ShowNum(57,6,TVOC_VAL_L,2,12);
- void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
- UNUSED(huart);
- uint16_t t;
- uint16_t WAIT_C=0;
- uint16_t CH;
- if(aRxBuffer[0]==0x42&&aRxBuffer[1]==0x4d)
- for(t=0;t<22;t++)
- WAIT_C+=aRxBuffer[t];
- CH=(aRxBuffer[22]<<8)+aRxBuffer[23];
- if(WAIT_C==CH)
- PM_VAL=((aRxBuffer[4])<<8)+aRxBuffer[5];
- TVOC_VAL_H=((aRxBuffer[6]<<8)+aRxBuffer[7])/100;
- TVOC_VAL_L=((aRxBuffer[6]<<8)+aRxBuffer[7])%100;
- HCHO_VAL_H=((aRxBuffer[9]<<8)+aRxBuffer[10])/100;
- HCHO_VAL_L=((aRxBuffer[9]<<8)+aRxBuffer[10])%100;
- CO2_VAL=(aRxBuffer[12]<<8)+aRxBuffer[13];
- TEM_VAL_H=((aRxBuffer[14]<<8)+aRxBuffer[15])/10;
- TEM_VAL_L=((aRxBuffer[14]<<8)+aRxBuffer[15])%10;
- HIM_VAL_H=((aRxBuffer[16]<<8)+aRxBuffer[17])/10;
- HIM_VAL_L=((aRxBuffer[16]<<8)+aRxBuffer[17])%10;
- CNT=0;
- else CNT=0;
- else CNT=0;
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
復(fù)制代碼 |
