2019-1-22 00:11 上傳
/***************標(biāo)準(zhǔn)源碼***************/
#include<reg51.h>
#include <intrins.h>
sbit sda = P2 ^ 1; //數(shù)據(jù)口定義
sbit scl = P2 ^ 0;
char code music[] = {//生日快樂(lè)譜
0x11,0x05,0x11,0x05,0x12,0x0a,0x11,0x0a,0x14,0x0a,0x13,0x14,
0x11,0x05,0x11,0x05,0x12,0x0a,0x11,0x0a,0x15,0x0a,0x14,0x14,
0x11,0x05,0x11,0x05,0x21,0x0a,0x16,0x0a,0x14,0x0a,0x13,0x0a,
0x22,0x0a,0x17,0x05,0x17,0x05,0x16,0x0a,0x14,0x0a,0x15,0x0a,
0x14,0x14,0x00,0x00
uchar data buffer[100];
void delay(uint m) ;
void nop();
void delay1(uint m);
void IIc_init();
void start();
void stop();
void writebyte(uchar jad);
uchar readbyte();
void ACK();
uchar read24c02(uchar spress) ;
void write24c02(uchar spress, uchar info);
uchar sp, i, j, m;
IIc_init();
P1 = 0X55;
while (sp != sizeof(music))
write24c02(0x00 + sp, music[sp]);
sp++;
if (sp % 4 == 0)
P1 = ~P1;
P1 = 0X00;
void delay(uint m)
uint n, p;
for (n = m; n>0; n--)
for (p = 125; p>0; p--);
void nop()
_nop_();
_nop_();
void delay1(uint m)
uint n;
for (n = 0; n<m; n++);
void IIc_init()
scl = 1;
nop();
sda = 1;
nop();
void start()
sda = 1;
nop();
scl = 1;
nop();
sda = 0;
nop();
scl = 0;
nop();
void stop() //停止I2C 總線(xiàn)
sda = 0;
nop();
scl = 1;
nop();
sda = 1;
nop();
void writebyte(uchar jad) //寫(xiě)一個(gè)字節(jié)
uchar i;
scl = 0;
for (i = 0; i<8; i++)
if(jad & 0x80)
sda = 1;
else sda = 0;
jad <<= 1;
nop();
scl = 1; //待sda 線(xiàn)上的數(shù)據(jù)穩(wěn)定后 將scl 拉高
nop();
scl = 0; //待sda 線(xiàn)上的數(shù)據(jù)穩(wěn)定后 將scl 拉高
nop();
sda = 1;
nop();
uchar readbyte() //讀一個(gè)字節(jié)
uchar i, j, k ;
scl = 0;
nop();
sda = 1;
nop();
scl = 1;
nop();
if (sda == 1)
j = 1;
j = 0;
k = (k << 1) | j;
scl = 0;
nop();
return k;
void ACK() //應(yīng)答函數(shù)
uchar i = 0;
scl = 1;
nop();
while ((sda == 1) && (i<255))
i++;
scl = 0;
nop();
uchar i;
start();
writebyte(0xa0);
ACK();
writebyte(spress);
ACK();
start();
writebyte(0xa1);
ACK();
i = readbyte();
stop();
delay1(100);
return(i);
start();
writebyte(0xa0);
ACK(); writebyte(spress);
ACK();
writebyte(info);
ACK();
stop();
delay1(5000);
24c04音樂(lè)讀取與存儲(chǔ).rar
(8.64 KB, 下載次數(shù): 34)
2019-1-22 00:15 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
