查看: 6775|回復(fù): 4
PIC16F877輸出正弦波信號(hào)PROTEUS仿真及程序
ID:138119 發(fā)表于 2019-1-23 00:11 | 顯示全部樓層 |閱讀模式
//PIC16F877單片機(jī)輸出正弦波信號(hào)仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
//20MHz晶振,輸出500Hz的正弦波,每周波100個(gè)點(diǎn)。
//1個(gè)周期時(shí)間為2ms,二點(diǎn)間隔時(shí)間為2000/100=20us
//用TMR2延時(shí),256*Tcy*K=20,Tcy=0.2,取K=1
//PR2計(jì)算:(PR2+1)*Tcy*1=20,得PR2=99
#include <pic.h>
__CONFIG(0x3F3A);
#define        CS                RB1
#define        LDAC        RB2
char BUF,N;
#define  nn   100
const unsigned int SS[100]={
2048,2111,2173,2235,2297,2357,2416,2474,2530,2584,2636,2685,2733,2777,2819,2857,
2892,2924,2953,2978,2999,3017,3030,3040,3046,3048,3046,3040,3030,3017,2999,2978,
2953,2924,2892,2857,2819,2777,2733,2685,2636,2584,2530,2474,2416,2357,2297,2235,
2173,2111,2048,1985,1923,1861,1799,1739,1680,1622,1566,1512,1460,1411,1363,1319,
1277,1239,1204,1172,1143,1118,1097,1079,1066,1056,1050,1048,1050,1056,1066,1079,
1097,1118,1143,1172,1204,1239,1277,1319,1363,1411,1460,1512,1566,1622,1680,1739,
1799,1861,1923,1985};
//宏定義,最后的讀SSPBUF是一定要的!
#define SPI_WRITE(A)        \
        SSPBUF=A;                        \
        while(STAT_BF==0);        \
        BUF=SSPBUF
void        main(void)
{        unsigned int x;
        TRISB=0b11111001;
        CS=1;NOP();
        LDAC=1;
        TRISC=0b00010000;        //RC3輸出(SCK),RC4輸入(SDI),RC5輸出(SDO)
        SSPEN=1;                        //SPI串口使能
        CKP=1;                                //空閑時(shí)鐘為高電平
        SSPM3=0;
        SSPM2=0;
        SSPM1=0;
        SSPM0=0;                        //SPI主控模式,時(shí)鐘為Fosc/4
        STAT_SMP=1;                        //在數(shù)據(jù)輸出時(shí)間的末端采樣輸入數(shù)據(jù)
        STAT_CKE=0;                        //在SCK上升沿傳輸數(shù)據(jù)
        PR2=99;                                //按照計(jì)算,每20us中斷一次
        T2CON=0b00000100;
        N=0;
        TMR2IE=1;                        //允許TMR2中斷
        PEIE=1;
        GIE=1;
        while(1);
void        interrupt INT_ISR(void)
{        unsigned        int X;
        char        i,j;
        if (TMR2IF==1)
        {        TMR2IF=0;
                X=SS[N++];
                if (N>=nn)
                        N=0;
                X+=0x7000;                        //HSDN=1,參考電壓緩沖,放大倍數(shù)GA=1
                CS=0;                                //片選有效
                i=X>>8;
                j=X;
                SPI_WRITE(i);                //輸出命令的高8位
                SPI_WRITE(j);                //輸出命令的低8位
                LDAC=0;NOP();                //DA輸出有效
                LDAC=1;NOP();
                CS=1;
全部資料51hei下載地址:
PIC16F877輸出正弦波信號(hào)仿真及程序.rar (44.66 KB, 下載次數(shù): 51)
DA應(yīng)用+正弦波產(chǎn)生.pdf (2.1 MB, 下載次數(shù): 30)
ID:469417 發(fā)表于 2019-1-31 18:43 | 顯示全部樓層
妹子,多放一點(diǎn)例程上來(lái)大家相互學(xué)習(xí)
參與人數(shù) 2黑幣 +23 收起 理由
sheng7533967 + 15
找人PK + 8 贊一個(gè)!
ID:138119 發(fā)表于 2019-2-16 23:06 | 顯示全部樓層
刀刀見(jiàn)紅 發(fā)表于 2019-1-31 18:43
光盤(pán)丟了,資料也沒(méi)有了,正著急呢~
ID:472268 發(fā)表于 2019-2-18 23:47 | 顯示全部樓層
yfpc2006 發(fā)表于 2019-2-16 23:06
你用的哪個(gè)的開(kāi)發(fā)板
ID:138119 發(fā)表于 2019-2-22 18:39 | 顯示全部樓層
sheng7533967 發(fā)表于 2019-2-18 23:47
《PIC16系列單片機(jī)C程序設(shè)計(jì)與PROTEUS仿真》附帶光盤(pán)丟了~嗚~~嗚~~
