用C#做的一個簡易串口助手,可以作為練手使用,再也不用別人的串口助手了HHHH
基本功能都有,代碼也有很多注釋,歡迎下載。
程序運(yùn)行界面:
程序源碼如下:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.IO.Ports;
- using System.Linq;
- using System.Text;
- using System.Threading.Tasks;
- using System.Windows.Forms;
- namespace WinFormSeriport
- public partial class FORM1 : Form
- SerialPort sp = new SerialPort();
- public FORM1()
- Control.CheckForIllegalCrossThreadCalls = false;
- InitializeComponent();
- sp.Close();
- lbl_TxRx.Text = "Tx:" +0+" " + "Rx:" + 0;
- private void Form1_Load_1(object sender, EventArgs e)
- Timer_SendDate.Interval = 1000;
- Timer_SendDate.Stop();
- private void Form1_MouseMove(object sender, MouseEventArgs e)
- lbl_Move.Text = e.X.ToString() + " " + e.Y.ToString();
- private void serialPort1_ErrorReceived(object sender, System.IO.Ports.SerialErrorReceivedEventArgs e)
- MessageBox.Show("接收數(shù)據(jù)時發(fā)生未知錯誤!", "錯誤", MessageBoxButtons.OK, MessageBoxIcon.Information);
- private void btn_OpenSerial_Click(object sender, EventArgs e)
- if (sp.IsOpen == false)
- btn_OpenSerial.Text = "開啟串口";
- try
- sp.PortName = comboBox_Com.Text;
- sp.BaudRate = Convert.ToInt32(comboBox_Bot.Text);
- sp.Parity = (System.IO.Ports.Parity)Enum.Parse(typeof(System.IO.Ports.Parity), comboBox_Parity.Text);
- sp.DataBits = Convert.ToInt16(comboBox_DateBit.Text);
- sp.StopBits = (System.IO.Ports.StopBits)Enum.Parse(typeof(System.IO.Ports.StopBits), comboBox_StopBit.Text);
- sp.Encoding = Encoding.Default; //設(shè)置串口編碼為default:獲取操作系統(tǒng)的當(dāng)前 ANSI 代碼頁的編碼。
- sp.DataReceived += new System.IO.Ports.SerialDataReceivedEventHandler(port_DataReceived);
- sp.Open(); //開啟串口
- if (checkBox_ClearShow.Checked) //如果開啟了自動清空功能
- Timer_SendDate.Start();
- btn_OpenSerial.Text = "關(guān)閉串口";
- catch
- MessageBox.Show("配置串口出錯,檢查各項參數(shù)是否設(shè)置!", "錯誤", MessageBoxButtons.OK, MessageBoxIcon.Error);
- else
- try
- sp.Close();
- MessageBox.Show("串口已關(guān)閉!","提示",MessageBoxButtons.OK, MessageBoxIcon.Information);
- catch
- MessageBox.Show("出現(xiàn)未知錯誤,串口關(guān)閉失敗!", "錯誤", MessageBoxButtons.OK, MessageBoxIcon.Error);
- string receiveData;
- UInt32 receiveBytesCount;
- string sendData;
- UInt32 sendBytesCount;
- private void port_DataReceived(object sender, SerialDataReceivedEventArgs e)
- receiveData = sp.ReadExisting();
- receiveBytesCount += (UInt32)receiveData.Length;
- //字符串顯示
- if (checkBox_ClearShow.Checked == false)
- if (checkBox_16Show.Checked == false) //hex 方式顯示
- richtxtbox_ShowGetNumber.AppendText(receiveData);
- richtxtbox_ShowGetNumber.Focus(); //讓光標(biāo)到這來
- richtxtbox_ShowGetNumber.Select(richtxtbox_ShowGetNumber.TextLength, 0);
- this.richtxtbox_ShowGetNumber.ScrollToCaret(); //設(shè)置光標(biāo)到最后
- //16進(jìn)制顯示
- else
- byte[] recData = System.Text.Encoding.Default.GetBytes(receiveData);// 將接受到的字符串據(jù)轉(zhuǎn)化成數(shù)組;
- foreach (byte str in recData)
- richtxtbox_ShowGetNumber.AppendText(string.Format("{0:X2} ", str));
- lbl_TxRx.Text = "Tx:" + sendBytesCount.ToString()+" " + "Rx:" + receiveBytesCount.ToString();
- private void btn_GetCom_Click(object sender, EventArgs e) //自動獲取串口號
- string[] serialPortName = System.IO.Ports.SerialPort.GetPortNames();
- foreach (string name in serialPortName)
- comboBox_Com.Text = name;
- private void btn_Send_Click(object sender, EventArgs e)
- MessageBox.Show("請打開串口!", "錯誤",MessageBoxButtons.OK, MessageBoxIcon.Information);
- else
- if (checkBox_SendByItself.Checked)
- Timer_SendDate.Interval = Convert.ToInt32(textBox_SendTime.Text);
- sendData = richTextBox_Send.Text;
- if (checkBox_SendIn16.Checked == false)
- sp.Write(sendData);
- else
- try
- sendData.Replace("0x", ""); //去掉0x
- sendData.Replace("0X", ""); //去掉0X
- // sendData.
- string[] strArray = sendData.Split(new char[] { ',', ',', '\r', '\n', ' ', '\t' });
- int decNum = 0;
- int i = 0;
- byte[] sendBuffer = new byte[strArray.Length]; //發(fā)送數(shù)據(jù)緩沖區(qū)
- foreach (string str in strArray)
- try
- decNum = Convert.ToInt16(str, 16);
- sendBuffer[i] = Convert.ToByte(decNum);
- i++;
- catch
- sp.Write(sendBuffer, 0, sendBuffer.Length);
- //更新發(fā)送數(shù)據(jù)計數(shù)
- sendBytesCount += (UInt32)sendBuffer.Length;
- catch
- private void Timer_SendDate_Tick(object sender, EventArgs e)
- richtxtbox_ShowGetNumber.Text = null;
- if (sp.IsOpen)
- else
- try
- // sendData.
- int decNum = 0;
- int i = 0;
- try
- i++;
- catch
- catch
- sendBytesCount += (UInt32)sendData.Length;
- else
- checkBox_SendByItself.CheckState=CheckState .Unchecked ;
- else
- else
- MessageBox.Show("串口已經(jīng)關(guān)閉!", "錯誤", MessageBoxButtons.OK, MessageBoxIcon.Information);
- private void btn_ClearAll_Click(object sender, EventArgs e)
- richTextBox_Send.Text = null;
WinFormSeriport.zip
(88.05 KB, 下載次數(shù): 311)
2019-1-27 11:35 上傳
點(diǎn)擊文件名下載附件
