2019-1-29 03:34 上傳
#include<reg51.h>
#include<intrins.h>
#include <absacc.h>
#define BUSY 0x80
#define DATAPORT P0
#define PLAYE_ADDR XBYTE[0XBFFF]
sbit RED_ALARM=P1^0;
sbit WRITE_ALARM=P1^1;
sbit GREEN_ALARM=P1^2;
sbit P1_4=P1^4;
sbit P1_5=P1^5;
sbit P1_6=P1^6;
sbit DQ = P1^7;
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
sbit ad_busy=P3^2;
sbit RECLED_EOC=P3^5;
sbit OUT=P3^7;
uchar ad_data;
uchar seconde=0;
uchar minite=0;
uchar hour=12;
uchar mstcnt=0;
uchar temp1,temp2,temp;
uchar t,set;
uchar K;
bit ON_OFF=0;
bit outflag;
uchar code str0[]={"--- : : --- "};
uchar code str1[]={"SET: C SA: . C"};
void delay_LCM(uint);
void initLCM( void);
void lcd_wait(void);
void WriteCommandLCM(uchar WCLCM,uchar BusyC);
void WriteDataLCM(uchar WDLCM);
void DisplayOneChar(uchar X,uchar Y,uchar DData);
void DisplayListChar(uchar X,uchar Y,uchar code *DData);
void init_timer0(void);
void displayfun1(void);
void displayfun2(void);
void displayfun3(void);
void displayfun4(void);
void keyscan(void );
void set_adj(void);
void inc_key(void);
void dec_key(void);
void delay_18B20(unsigned int i);
void Init_DS18B20(void) ;
uchar ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void ReadTemperature(void);
void ad0809(void);
void playalarm(void);
void delay_LCM(uint k)
uint i,j;
for(i=0;i<k;i++)
for(j=0;j<60;j++)
if(BusyC)lcd_wait();
DATAPORT=WCLCM;
LCM_RS=0;
LCM_RW=0;
LCM_EN=1;
_nop_();
_nop_();
_nop_();
LCM_EN=0;
lcd_wait( );
DATAPORT=WDLCM;
LCM_RS=1;
LCM_RW=0;
LCM_EN=1;
_nop_();
_nop_();
_nop_();
LCM_EN=0;
void lcd_wait(void)
DATAPORT=0xff;
LCM_EN=1;
LCM_RS=0;
LCM_RW=1;
_nop_();
while(DATAPORT&BUSY)
{ LCM_EN=0;
_nop_();
_nop_();
LCM_EN=1;
_nop_();
_nop_();
LCM_EN=0;
void initLCM( )
DATAPORT=0;
delay_LCM(15);
WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
delay_LCM(5);
delay_LCM(5);
delay_LCM(5);
WriteCommandLCM(0x38,1); //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測(cè)忙信號(hào)
WriteCommandLCM(0x08,1); //關(guān)閉顯示,檢測(cè)忙信號(hào)
WriteCommandLCM(0x01,1); //清屏,檢測(cè)忙信號(hào)
WriteCommandLCM(0x06,1); //顯示光標(biāo)右移設(shè)置,檢測(cè)忙信號(hào)
WriteCommandLCM(0x0c,1); //顯示屏打開,光標(biāo)不顯示,不閃爍,檢測(cè)忙信號(hào)
uchar ListLength=0;
Y&=0x01;
X&=0x0f;
while(X<16)
DisplayOneChar(X,Y,DData[ListLength]);
ListLength++;
X++;
while(i--);
unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(8); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
delay_18B20(80); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線
delay_18B20(14);
x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
delay_18B20(20);
/***********ds18b20讀一個(gè)字節(jié)**************/
unsigned char ReadOneChar(void)
uchar i=0;
uchar dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
delay_18B20(4);
return(dat);
/*************ds18b20寫一個(gè)字節(jié)****************/
void WriteOneChar(uchar dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay_18B20(5);
DQ = 1;
dat>>=1;
DisplayListChar(0,0,str0);
DisplayListChar(0,1,str1);
DisplayOneChar(3,0,hour/10+0x30); //液晶上顯示小時(shí)
DisplayOneChar(4,0,hour%10+0x30);
DisplayOneChar(6,0,minite/10+0x30); //液晶上顯示分
DisplayOneChar(7,0,minite%10+0x30);
DisplayOneChar(9,0,seconde/10+0x30); //液晶上顯示秒
DisplayOneChar(10,0,seconde%10+0x30);
DisplayOneChar(4,1,K/10+0x30); //液晶上顯示設(shè)定的溫度
DisplayOneChar(5,1,K%10+0x30);
DisplayOneChar(11,1,temp1/10+0x30); //液晶上顯示測(cè)得的溫度
DisplayOneChar(12,1,temp1%10+0x30);
DisplayOneChar(14,1,temp2/10+0x30);
if(ON_OFF==0) //若溫控標(biāo)志為0
DisplayOneChar(14,0,0x4f); // 液晶上顯示不控溫的標(biāo)志
DisplayOneChar(15,0,0x46);
DisplayOneChar(14,0,0x4f); // 液晶上顯示控溫的標(biāo)志
DisplayOneChar(15,0,0x4e);
if(outflag==1)
DisplayOneChar(0,0,0x7c);
DisplayOneChar(0,0,0xef);
WriteCommandLCM(0x0f,1); //顯示屏打開,光標(biāo)顯示,閃爍,檢測(cè)忙信號(hào)
/**************鍵盤掃描子函數(shù)******************/
void keyscan(void)
uchar xx; //局部變量
P1=0xff;
if(P1!=0xff)
delay_LCM(50);
if(P1!=0xff)
xx=P1;
switch(xx) // 根據(jù)按鍵狀態(tài),調(diào)用不同的子函數(shù)
case 0xfe:set_adj(); break;
case 0xfd:inc_key(); break;
case 0xfb:dec_key(); break;
case 0xf7:ON_OFF=!ON_OFF; break;
default:break;
/**************設(shè)定工作模式子函數(shù)****************/
void set_adj(void)
delay_LCM(100);
set++;
if(set>=4)set=0;
/****************按鍵加法子函數(shù)******************/
void inc_key(void)
delay_LCM(100);
switch(set)
case 0:if(P1==0xf7)ON_OFF=!ON_OFF; break;
case 1:hour++; if(hour>=23)hour=23; break;
case 2:minite++; if(minite>=59)minite=59;break;
case 3:K++;if(K>=99)K=99; break;
default:break;
/****************按鍵減法子函數(shù)*****************/
void dec_key(void)
delay_LCM(100);
switch(set)
case 1:hour--; if(hour<=0)hour=0; break;
case 2:minite--;if(minite<=0)minite=0;break;
case 3:K--;if(K<=1)K=1; break;
default:break;
/***************定時(shí)器t0初始化*******************/
TMOD=0x01; //time0為定時(shí)器,方式1
TH0=0x3c; //預(yù)置計(jì)數(shù)初值
TL0=0xb0;
EA=1;
ET0=1;
TR0=1;
void main(void)
P1=0xff; //初始化p1口,全設(shè)為1
delay_LCM(500); //延時(shí)500ms啟動(dòng)
initLCM( ); //LCD初始化
init_timer0( ); //時(shí)鐘定時(shí)器0初始化
Init_DS18B20( ) ; //DS18B20初始化
while (1)
keyscan(); //按鍵掃描
ReadTemperature(); //溫度采集
switch(set) //LCD根據(jù)工作模式顯示
case 0:displayfun1();delay_LCM(1000);break; //正常工作顯示
case 1:displayfun2();delay_LCM(1000);break; //調(diào)整時(shí)顯示
case 2:displayfun3();delay_LCM(1000);break; //調(diào)整分顯示
case 3:displayfun4();delay_LCM(1000);break; //溫度設(shè)定
default:break;
keyscan( ); //相當(dāng)于延時(shí)
if(ON_OFF==1) //若溫控標(biāo)志位1, 控制LAMP動(dòng)作
if(temp1>=K+1){outflag=1;OUT=0;}
if(temp1<K)
delay_LCM(1000);
if(temp1<K){outflag=0;OUT=1;} //
else{outflag=0;OUT=1;}
LCD1602溫控帶時(shí)間.rar
(21.11 KB, 下載次數(shù): 25)
2019-1-29 03:39 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
