查看: 9454|回復(fù): 18
STM8單片機(jī)+TP4056+LT1935的USB移動(dòng)電源PCB原理圖和程序
ID:474374 發(fā)表于 2019-2-18 11:13 | 顯示全部樓層 |閱讀模式
內(nèi)容很詳細(xì),有電路原理圖,PCB圖,可用AD打開(kāi)編輯,還有PDF版的原理圖,可供大家參考
Altium Designer畫(huà)的原理圖和PCB圖如下:(51hei附件中可下載工程文件)
stm8單片機(jī)源程序如下:
  1. /* MAIN.C file
  2. 編譯環(huán)境:IAR
  3. 初版時(shí)間: 2013-01-18
  4. */
  5. #include "stm8s.h" //包含用到的外設(shè)的頭文件
  6. #include "stm8s_adc1.h"
  7. #include "stm8s_clk.h"
  8. #define FLG_IOUT     0
  9. #define FLG_VOUT     1
  10. #define LED1_OFF()  GPIO_WriteHigh(GPIOC,GPIO_PIN_4)
  11. #define LED1_ON()   GPIO_WriteLow(GPIOC,GPIO_PIN_4)
  12. #define LED2_OFF()  GPIO_WriteHigh(GPIOC,GPIO_PIN_5)
  13. #define LED2_ON()   GPIO_WriteLow(GPIOC,GPIO_PIN_5)
  14. #define LED3_OFF()  GPIO_WriteHigh(GPIOC,GPIO_PIN_6)
  15. #define LED3_ON()   GPIO_WriteLow(GPIOC,GPIO_PIN_6)
  16. #define LED4_OFF()  GPIO_WriteHigh(GPIOC,GPIO_PIN_7)
  17. #define LED4_ON()   GPIO_WriteLow(GPIOC,GPIO_PIN_7)
  18. //LED操作宏
  19. #define LED_ALL_OFF()   do{ LED4_OFF();LED3_OFF();LED2_OFF();LED1_OFF(); }while(0)
  20. #define LED_VOL_100()   do{ LED4_ON();LED3_ON();LED2_ON();LED1_ON(); }while(0)
  21. #define LED_VOL_75()    do{ LED4_ON();LED3_ON();LED2_ON();LED1_OFF(); }while(0)
  22. #define LED_VOL_50()    do{ LED4_ON();LED3_ON();LED2_OFF();LED1_OFF(); }while(0)
  23. #define LED_VOL_25()    do{ LED4_ON();LED3_OFF();LED2_OFF();LED1_OFF(); }while(0)
  24. #define LED_VOL_0()     LED_ALL_OFF()
  25. #define VAT_CAP_100  ((unsigned short)(4.16*1024/6.6))
  26. #define VAT_CAP_75   ((unsigned short)(3.93*1024/6.6))
  27. #define VAT_CAP_50   (((unsigned short)3.79*1024/6.6))
  28. #define VAT_CAP_25   (((unsigned short)3.72*1024/6.6))
  29. #define VAT_CAP_0    (((unsigned short)3.58*1024/6.6))
  30. #define IOUT_0_25    (((unsigned short)0.25*1024/3.3))
  31. #define IOUT_3_00    (((unsigned short)3*1024/3.3))
  32. #define GET_MIN(a,b) (((a) > (b))? (b):(a))
  33. /**************************實(shí)現(xiàn)函數(shù)********************************************
  34. *函數(shù)原型:                void Delay(unsigned int time)
  35. *功  能:                實(shí)現(xiàn)一定時(shí)間的延時(shí),延時(shí)設(shè)定時(shí)長(zhǎng)由輸入time 決定
  36. *******************************************************************************/
  37. void Delay(unsigned int time)
  38. {
  39.         volatile unsigned int i;
  40.         while(time--){
  41.                 i=300;
  42.                 while(i--); //做一些沒(méi)有用的事,打發(fā)時(shí)間
  43.         }
  44. }
  45. void Led_tig(unsigned short adc_val)
  46. {
  47.   static unsigned char flag = 0;   //反轉(zhuǎn)的標(biāo)志
  48.
  49.        if(adc_val >= VAT_CAP_100)
  50.        {
  51.          LED_VOL_100();
  52.        }
  53.        else if(adc_val >= VAT_CAP_75)
  54.        {
  55.          if(flag)LED_VOL_100();
  56.          else LED_VOL_75();
  57.        }
  58.        else if(adc_val >= VAT_CAP_50)
  59.        {
  60.          if(flag)LED_VOL_75();
  61.          else LED_VOL_50();
  62.        }
  63.        else if(adc_val >= VAT_CAP_25)
  64.        {
  65.          if(flag)LED_VOL_50();
  66.          else LED_VOL_25();
  67.        }
  68.        else
  69.        {
  70.          if(flag)LED_VOL_25();
  71.          else LED_VOL_0();
  72.        }
  73.      flag = !flag;
  74. }
  75. unsigned short ADC_val_get(unsigned char ch)
  76. {
  77.   unsigned short buf[3] , temp;
  78.   unsigned char i;
  79.   if(FLG_IOUT)
  80.     ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE , ADC1_CHANNEL_3, ADC1_ALIGN_RIGHT);
  81.   else
  82.     ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_4 , ADC1_ALIGN_RIGHT);
  83.   for(i=0 ; i<3 ; i++)
  84.   {
  85.      ADC1_StartConversion();
  86.      while(SET == ADC1_GetFlagStatus(ADC1_FLAG_EOC)){;}
  87.      buf[i] =  ADC1_GetConversionValue();
  88.      ADC1_ClearFlag(ADC1_FLAG_EOC);
  89.   }
  90.
  91.   temp = GET_MIN( buf[0] ,  buf[1]);
  92.   temp = GET_MIN( temp ,  buf[2]);
  93.
  94.   return temp;
  95. }
  96. volatile short adc_val;
  97. volatile u32 u32_clk_freq;
  98. /**************************實(shí)現(xiàn)函數(shù)********************************************
  99. *函數(shù)原型:                main() 主程序
  100. *功  能:                設(shè)置LED的端口為輸出,并使開(kāi)發(fā)板上的LED2閃爍
  101. *******************************************************************************/
  102. main()
  103. {
  104.   CLK_DeInit();
  105.   CLK_LSICmd(ENABLE);
  106.   CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV8);
  107.
  108.   GPIO_DeInit(GPIOD);
  109.   GPIO_Init(GPIOD, GPIO_PIN_4, GPIO_MODE_OUT_PP_HIGH_SLOW);  // PW_ON高電平
  110.   u32_clk_freq = CLK_GetClockFreq();
  111.   GPIO_DeInit(GPIOC);//把LED1-4設(shè)置為高電平輸出,關(guān)燈
  112.   GPIO_Init(GPIOC, GPIO_PIN_HNIB , GPIO_MODE_OUT_PP_HIGH_SLOW); //LED1-4 滅
  113.   //ADC 初始化
  114.   ADC1_DeInit();
  115.   ADC1_Init(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_4 | ADC1_CHANNEL_3,
  116.             ADC1_PRESSEL_FCPU_D2,ADC1_EXTTRIG_TIM, DISABLE,
  117.             ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL4 | ADC1_SCHMITTTRIG_CHANNEL3, DISABLE);
  118.
  119. //  ADC1_Init(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_2,
  120. //           ADC1_PRESSEL_FCPU_D2,ADC1_EXTTRIG_TIM, DISABLE,
  121.       //      ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL2, DISABLE);
  122.   ADC1_Cmd(ENABLE);
  123.   ADC1_ITConfig(ADC1_IT_AWDIE, DISABLE);
  124.   while (1)
  125.    { //主循環(huán)體
  126.        Delay(100);//延時(shí)。
  127.        adc_val =  ADC_val_get(FLG_VOUT);
  128.
  129.        adc_val =  ADC_val_get(FLG_IOUT);
  130.        if(adc_val >= IOUT_3_00 || adc_val < IOUT_0_25)
  131.        {
  132.          GPIO_WriteLow(GPIOD, GPIO_PIN_4);
  133.        }
  134.        else
  135.          GPIO_WriteHigh(GPIOD, GPIO_PIN_4);
  136.     //   Led_tig(adc_val);
  137.    }//如些反復(fù),用戶會(huì)觀察到LED2一直在閃爍
  138. }
USB Mobile Power Code.rar
241.67 KB, 下載次數(shù): 153, 下載積分: 黑幣 -5
USB Mobile Power PCB.rar
249.7 KB, 下載次數(shù): 150, 下載積分: 黑幣 -5
USB Mobile Power SCH.rar
32.4 KB, 下載次數(shù): 161, 下載積分: 黑幣 -5
USB Mobile Power.pdf
160.87 KB, 下載次數(shù): 160, 下載積分: 黑幣 -5
ID:482999 發(fā)表于 2019-3-1 22:39 | 顯示全部樓層
有電池保護(hù)電路部分嗎
ID:56665 發(fā)表于 2019-3-6 16:02 | 顯示全部樓層
謝謝樓主分享!
ID:136083 發(fā)表于 2019-6-27 19:28 | 顯示全部樓層
謝謝樓主分享!
ID:279411 發(fā)表于 2019-7-22 14:28 | 顯示全部樓層
學(xué)習(xí)一下
ID:595322 發(fā)表于 2019-8-5 09:23 | 顯示全部樓層
謝謝分享,學(xué)習(xí)學(xué)習(xí)!
ID:605120 發(fā)表于 2019-8-29 15:02 | 顯示全部樓層
謝謝樓主分享!
ID:56665 發(fā)表于 2019-9-3 11:23 | 顯示全部樓層
其實(shí)可以把4056電池充電IC省掉,用單片機(jī)控制MOS管來(lái)做,單片機(jī)輸出PWM并通過(guò)一個(gè)三極管使MOS管導(dǎo)通或者截止給電池充電,通過(guò)串接電池負(fù)端或者正端的檢測(cè)電流電阻來(lái)檢測(cè)充電電流,使充電電流恒定在某個(gè)值,然后檢測(cè)電池端電壓,當(dāng)電池電壓到達(dá)4.1V左右,再啟動(dòng)恒壓電路,恒壓電路就是在電池兩端用兩個(gè)10電阻取樣,電阻中間的電壓值送到單片機(jī)ADC端口,判斷電壓高低,決定PWM占空比大小,使充電電流漸漸變小充電,起碼到電池充飽。
ID:142891 發(fā)表于 2019-9-30 23:14 | 顯示全部樓層
支持一下,謝謝分享.
ID:283763 發(fā)表于 2019-10-20 14:28 | 顯示全部樓層
學(xué)習(xí)一下,謝謝分享!
ID:653068 發(fā)表于 2019-11-30 16:20 | 顯示全部樓層
謝謝分享
ID:301788 發(fā)表于 2019-12-31 12:50 來(lái)自觸屏版 | 顯示全部樓層
支持一下,謝謝分享
ID:375228 發(fā)表于 2020-1-29 20:35 | 顯示全部樓層
謝謝分享,很好的學(xué)習(xí)資料
ID:140183 發(fā)表于 2020-2-4 13:40 | 顯示全部樓層
很好的資料!有空做一個(gè)玩玩。
ID:369226 發(fā)表于 2020-6-1 10:53 | 顯示全部樓層
謝謝樓主分享!
ID:841696 發(fā)表于 2020-11-11 12:57 | 顯示全部樓層
有電池保護(hù)電路部分嗎
ID:620337 發(fā)表于 2020-11-30 13:51 | 顯示全部樓層
把所有資料做成一個(gè)壓縮包不是更好嗎?
ID:895892 發(fā)表于 2021-3-26 18:41 | 顯示全部樓層
學(xué)習(xí)一下,謝謝分享
ID:420097 發(fā)表于 2021-4-13 18:29 | 顯示全部樓層
你這最大輸出電流是多少能做PD 的么?
