STM32 ST LIS3DH 三軸加速度傳感器參考代碼
- /******************** (C) COPYRIGHT 2012 STMicroelectronics ********************
- * File Name : example_main.c
- * Author : MSH Application Team
- * Author : Abhishek Anand,Fabio Tota
- * Revision : $Revision: 1.5 $
- * Date : $Date: 16/06/2011 12:19:08 $
- * Description : Example main file for MKI109V1 board
- * HISTORY:
- * Date | Modification | Author
- * 16/06/2011 | Initial Revision | Fabio Tota
- * 11/06/2012 | Support for multiple drivers in the same program | Abhishek Anand
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * THIS SOFTWARE IS SPECIFICALLY DESIGNED FOR EXCLUSIVE USE WITH ST PARTS.
- /* Includes ------------------------------------------------------------------*/
- //include files for MKI109V1 board
- #include "stm32f10x.h"
- #include "usb_lib.h"
- #include "usb_desc.h"
- #include "hw_config.h"
- #include "usb_pwr.h"
- #include "led.h"
- #include "button.h"
- #include "adc_mems.h"
- #include "string.h"
- #include "spi_mems.h"
- #include <stdio.h>
- //include MEMS driver
- #include "lis3dh_driver.h"
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- uint8_t response;
- uint8_t USBbuffer[64];
- /* Extern variables ----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- //define for example1 or example2
- //#define __EXAMPLE1__H
- #define __EXAMPLE2__H
- * Function Name : main.
- * Description : Main routine.
- * Input : None.
- * Output : None.
- * Return : None.
- int main(void)
- uint8_t buffer[26];
- uint8_t position=0, old_position=0;
- AxesRaw_t data;
- //Initialize your hardware here
- //function for MKI109V1 board
- InitHardware();
- SPI_Mems_Init();
- EKSTM32_LEDOff(LED1);
- EKSTM32_LEDOff(LED2);
- EKSTM32_LEDOff(LED3);
- //wait until the USB is ready (MKI109V1 board)
- while(bDeviceState != CONFIGURED);
- //Inizialize MEMS Sensor
- //set ODR (turn ON device)
- response = LIS3DH_SetODR(LIS3DH_ODR_100Hz);
- if(response==1){
- sprintf((char*)buffer,"\n\rSET_ODR_OK \n\r\0");
- USB_SIL_Write(EP1_IN, buffer, 19);
- SetEPTxValid(ENDP1);
- //set PowerMode
- response = LIS3DH_SetMode(LIS3DH_NORMAL);
- if(response==1){
- sprintf((char*)buffer,"SET_MODE_OK \n\r\0");
- //set Fullscale
- response = LIS3DH_SetFullScale(LIS3DH_FULLSCALE_2);
- if(response==1){
- sprintf((char*)buffer,"SET_FULLSCALE_OK\n\r\0");
- //set axis Enable
- response = LIS3DH_SetAxis(LIS3DH_X_ENABLE | LIS3DH_Y_ENABLE | LIS3DH_Z_ENABLE);
- if(response==1){
- sprintf((char*)buffer,"SET_AXIS_OK \n\r\0");
- /******Example 1******/
- #ifdef __EXAMPLE1__H
- while(1){
- //get Acceleration Raw data
- response = LIS3DH_GetAccAxesRaw(&data);
- if(response==1){
- //print data values
- EKSTM32_LEDToggle(LED1);
- sprintf((char*)buffer, "X=%6d Y=%6d Z=%6d \r\n", data.AXIS_X, data.AXIS_Y, data.AXIS_Z);
- USB_SIL_Write(EP1_IN, buffer, 29);
- old_position = position;
- #endif /* __EXAMPLE1__H */
- /******Example 2******/
- #ifdef __EXAMPLE2__H
- //configure Mems Sensor
- //set Interrupt Threshold
- response = LIS3DH_SetInt1Threshold(20);
- if(response==1){
- sprintf((char*)buffer,"SET_THRESHOLD_OK\n\r\0");
- //set Interrupt configuration (all enabled)
- response = LIS3DH_SetIntConfiguration(LIS3DH_INT1_ZHIE_ENABLE | LIS3DH_INT1_ZLIE_ENABLE |
- LIS3DH_INT1_YHIE_ENABLE | LIS3DH_INT1_YLIE_ENABLE |
- LIS3DH_INT1_XHIE_ENABLE | LIS3DH_INT1_XLIE_ENABLE );
- if(response==1){
- sprintf((char*)buffer,"SET_INT_CONF_OK \n\r\0");
- //set Interrupt Mode
- response = LIS3DH_SetIntMode(LIS3DH_INT_MODE_6D_POSITION);
- if(response==1){
- sprintf((char*)buffer,"SET_INT_MODE \n\r\0");
- while(1){
- //get 6D Position
- response = LIS3DH_Get6DPosition(&position);
- if((response==1) && (old_position!=position)){
- switch (position){
- case LIS3DH_UP_SX: sprintf((char*)buffer,"\n\rposition = UP_SX \n\r\0"); break;
- case LIS3DH_UP_DX: sprintf((char*)buffer,"\n\rposition = UP_DX \n\r\0"); break;
- case LIS3DH_DW_SX: sprintf((char*)buffer,"\n\rposition = DW_SX \n\r\0"); break;
- case LIS3DH_DW_DX: sprintf((char*)buffer,"\n\rposition = DW_DX \n\r\0"); break;
- case LIS3DH_TOP: sprintf((char*)buffer,"\n\rposition = TOP \n\r\0"); break;
- case LIS3DH_BOTTOM: sprintf((char*)buffer,"\n\rposition = BOTTOM \n\r\0"); break;
- default: sprintf((char*)buffer,"\n\rposition = unknown\n\r\0"); break;
- USB_SIL_Write(EP1_IN, buffer, 23);
- #endif /*__EXAMPLE2__H */
- } // end main
- #ifdef USE_FULL_ASSERT
LIS3DH_MCU_Driver.7z
(9.55 KB, 下載次數(shù): 92)
2019-2-26 11:43 上傳
點(diǎn)擊文件名下載附件
參考代碼 下載積分: 黑幣 -5
