51單片機(jī)WS2812BRGB
可以控制200個(gè)RGB
- #include<reg52.h>
- #include<intrins.h>
- //單片機(jī)為15系列 晶振內(nèi)部27M 分頻為0X02
- //可以控制1024 個(gè)RGB
- #define uchar unsigned char
- sfr PLC=0X97;
- sbit Send_Dat=P3^5;
- unsigned char RGB_BUF[24];
- void delay();
- void RGBA(); //流動效果
- void RGBB( unsigned int w);//靜態(tài)顯示全彩
- void RGBC (); //全體變色效果
- uchar n;
- uchar r;
- unsigned char *p;
- uchar a []={ 0xff,0x00,0x00} ; //綠
- uchar b []={ 0x00,0xff,0x00} ; //紅
- uchar c []={ 0x00,0x00,0xff} ; //藍(lán)
- uchar d []={ 0xff,0xff,0x00} ; //黃
- uchar e []={ 0xff,0x00,0xff} ; //青
- uchar f []={ 0x00,0xff,0xff} ; //紫
- uchar g []={ 0xff,0xff,0xff} ; //白
- uchar h []={ 0x00,0x00,0x00} ;
- uchar shuzud [8] [3]={
- { 0xff,0x00,0x00}, //綠
- { 0x00,0xff,0x00} , //紅
- { 0x00,0x00,0xff} , //藍(lán)
- { 0xff,0xff,0x00} , //黃
- { 0xff,0x00,0xff} , //青
- { 0x00,0xff,0xff} , //紫
- { 0xff,0xff,0xff} , //白
- { 0x00,0x00,0x00} ,
- sfr P3M1 = 0xb1;
- sfr P3M0 = 0xb2;
- struct shuzu
- uchar a [3];
- uchar b[3] ;
- struct shuzu;
- void delays(uchar t);
- void Send_A_bit(uchar v)
- if (v==1)
- Send_Dat=1;
- _nop_();
- Send_Dat=0;
- else
- Send_Dat=1;
- Send_Dat=0;
- _nop_();
- void Send_192bits( uchar *p1,uchar z)
- unsigned int i=0; uchar s; uchar x; unsigned char k;
- s=8;
- x=0;
- // 1
- for (i=x;i<s;i++)
- RGB_BUF[i]=p1[0]>>(i-x)&0x01; //轉(zhuǎn)化R_VAL
- s=s+8;
- x=x+8;
- for (i=x;i<s;i++)
- RGB_BUF[i]=p1[1]>>(i-x)&0x01; //轉(zhuǎn)化G_VAL
- s=s+8;
- x=x+8;
- for (i=x;i<s;i++)
- RGB_BUF[i]=p1[2]>>(i-x)&0x01;
- //轉(zhuǎn)化R_VAL
- s=s+8;
- x=x+8;
- for (k=0;k<z;k++) //循環(huán)RGB數(shù)量
- for (i=0;i<24;i++)
- Send_A_bit(RGB_BUF[i]);
- void main()
- P3M0 = 0x00;
- P3M1 = 0x00;
- PLC=0X02;
- while(1)
- RGBB(65000); //全體靜態(tài)顯示全彩效果
- delays(10 );
- RGBA();//全體流動效果
- delays(5);
- RGBC();//全體變色效果
- delays(5);
- void RGBA() // 流動效果
- Send_192bits(shuzud[0],9);
- delays(1);
- for (n=0;n<10;n++)
- Send_192bits(shuzud[1],n);
- delays(1);
- Send_192bits(shuzud[2],n);
- delays(1);
- void RGBB( unsigned int w ) //全體靜態(tài)顯示全彩效果
- unsigned int t;
- for (t=0;t< w;t++);
- Send_192bits(shuzud[2],9);
- for (t=0;t< w;w++);
- Send_192bits(shuzud[1],8);
- Send_192bits(shuzud[0],7);
- Send_192bits(shuzud[5],6);
- Send_192bits(shuzud[4],5);
- Send_192bits(shuzud[3],4);
- Send_192bits(shuzud[2],3);
- Send_192bits(shuzud[1],2);
- Send_192bits(shuzud[0],1);
- void RGBC() //全體變色效果
- delays(5);
- Send_192bits(shuzud[1],9);
- delays(5);
- delays(5);
- Send_192bits(shuzud[3],9);
- delays(5);
- Send_192bits(shuzud[4],9);
- delays(5);
- Send_192bits(shuzud[5],9);
- delays(5);
- void delay()
- unsigned int i,j;
- for (i=0;i<250;i++)
- for (j=0;j<200;j++);
- /*大延時(shí)函數(shù)*/
- /*十幾秒*/
- uchar p;
- for (p=0; p<t;p++)
- delay();
優(yōu)化RGB.rar
(25.16 KB, 下載次數(shù): 583)
2019-2-28 11:25 上傳
點(diǎn)擊文件名下載附件
