查看: 4777|回復(fù): 1
基于51單片機(jī)的羽毛球計(jì)分器設(shè)計(jì)(代碼+Proteus仿真+文檔)
單片機(jī)課程設(shè)計(jì),羽毛球積分器完整版,包含文檔keil程序c語(yǔ)言版,proteus仿真;本程序?qū)崿F(xiàn)了加減計(jì)分,液晶屏顯示,按鍵的動(dòng)態(tài)掃描,廢話不多說(shuō)直接上圖。
功能說(shuō)明圖:
使用說(shuō)明:
課程設(shè)計(jì)目錄
程序整體設(shè)計(jì)流程圖:
keil程序模塊:
液晶屏顯示模塊:
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    }while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測(cè)直到其等于0為止
/* 向LCD1602液晶寫(xiě)入一字節(jié)命令,cmd-待寫(xiě)入命令值 */
void LcdWriteCmd(unsignedchar cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E = 1;
    LCD1602_E = 0;
//顯示字母及計(jì)時(shí)器
void LcdInit()
   if(flag1s == 1)
        sec++;
        flag1s = 0;
      if(sec>=60)
     { minute++;
       sec = 0;
       if(minute>59)
       minute = 59;
      LcdShowStr(0, 1,"T");
     len = LongToString(str,minute);
     LcdShowStr(1, 1, str);
     LcdShowStr(3, 1,":");
     len = LongToString(str,sec);
     LcdShowStr(4, 1, str);
     LcdShowStr(7, 1,"A:B");
     len = LongToString(str,a);
     LcdShowStr(11, 1, str);
     LcdShowStr(13, 1,":");
     len = LongToString(str,b);
     LcdShowStr(14, 1, str);
/* 向LCD1602液晶寫(xiě)入一字節(jié)數(shù)據(jù),dat-待寫(xiě)入數(shù)據(jù)值 */
void LcdWriteDat(unsignedchar dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E = 1;
    LCD1602_E = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標(biāo)位置,(x,y)-對(duì)應(yīng)屏幕上的字符坐標(biāo) */
void LcdSetCursor(unsignedchar x, unsigned char y)
    unsigned char addr;
    if (y == 0) //由輸入的屏幕坐標(biāo)計(jì)算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對(duì)應(yīng)屏幕上的起始坐標(biāo),str-字符串指針 */
void LcdShowStr(unsigned charx, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (*str != '\0')  //連續(xù)寫(xiě)入字符串?dāng)?shù)據(jù),直到檢測(cè)到結(jié)束符
        LcdWriteDat(*str++);
/* 區(qū)域清除,清除從(x,y)坐標(biāo)起始的len個(gè)字符位 */
void LcdAreaClear(unsignedchar x, unsigned char y, unsigned char len)
    while (len--)         //連續(xù)寫(xiě)入空格
        LcdWriteDat(' ');
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
  // LcdWriteCmd(0x0C);  //顯示器開(kāi),光標(biāo)關(guān)閉
    LcdWriteCmd(0x06);  //文字不動(dòng),地址自動(dòng)+1
    LcdWriteCmd(0x01);  //清屏
定時(shí)模塊:
/* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
void ConfigTimer0(unsignedint ms)
    unsigned long tmp;  //臨時(shí)變量
    tmp = 11059200 / 12;      //定時(shí)器計(jì)數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計(jì)算所需的計(jì)數(shù)值
    tmp = 65536 - tmp;        //計(jì)算定時(shí)器重載值
    tmp = tmp + 12;           //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
    T0RH = (unsigned char)(tmp>>8);  //定時(shí)器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
字符串的轉(zhuǎn)換:
//將數(shù)字轉(zhuǎn)換為字符
unsigned charLongToString(unsigned char *str, signed long dat)
   signed char i = 0;
   signed char len = 0;
   unsigned char buf[3];
    for(i=0;i<2;i++)
     buf = dat%10;
     dat = dat/10;
   len = i;
   for(i=1;i>=0;i--)
      *str++ = buf[ i] + '0';
   *str = '\0';
   return len;
由于篇幅有限,更多詳細(xì)資料請(qǐng)下載附件。
全部資料51hei下載地址:
羽毛球計(jì)分器.rar (245.12 KB, 下載次數(shù): 118)
參與人數(shù) 1黑幣 +90 收起 理由
admin + 90 共享資料的黑幣獎(jiǎng)勵(lì)!
ID:459269 發(fā)表于 2019-3-3 11:20 | 只看該作者
附件在上面的羽毛球計(jì)分器,由于第一次用,所以位置插到上面了
