查看: 2571|回復: 4
單片機程序功能:檢測DS18B20并顯示數(shù)碼管上;問題初始化失敗
ID:323005 發(fā)表于 2019-3-4 20:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
50黑幣
程序功能:檢測DS18B20并顯示數(shù)碼管上;奈何數(shù)碼管一直顯示A959;
晶振12 ;問題好像初始化不成功求大佬解答
#include<STC8.h>
#include<intrins.h>
#define uint  unsigned int
#define FOSC  12000000L
sbit w1=P1^0;
sbit w2=P1^1;
sbit w3=P1^2;
sbit w4=P1^3;//數(shù)碼管位選
sbit k1=P1^4;
sbit k2=P1^5;
sbit k3=P1^6;
sbit k4=P1^7;
sbit DS=P5^4;數(shù)據(jù)口
sbit g=P5^5;
           //define interface
uint temp;             // variable of temperature
uchar flag1;            // sign of the result positive or negative
uchar code SM[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code SM5[]={
0xbf,0x86,0xdb,0xcf,
0xe6,0xed,0xfd,0x87,
0xff,0xef,0x77,0x7c,
void nb(uint z)   //??
uint x,y;
     x=z;
for(x;x>0;x--)
   for(y=110;y>0;y--);
void delay(uint count)      //delay
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)       //send reset and initialization command
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)       //read a bit
   uint i;
   bit dat;
   DS=0;i++;          //i++ for delay
   DS=1;i++;i++;
   dat=DS;
   i=8;while(i>0)i--;
   return (dat);
uchar tmpread(void)   //read a byte date
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);
  return(dat);
void tmpwritebyte(uchar dat)   //write a byte to ds18b20
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)     //write 1
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
      DS=0;       //write 0
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)  //DS18B20 begin change
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);  // address all drivers on bus
  tmpwritebyte(0x44);  //  initiates a single temperature conversion
uint tmp()               //get the temperature
  float tt;
  uchar a,b;
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0xbe);
  a=tmpread();
  b=tmpread();
  temp=b;
  temp<<=8;             //two byte  compose a int variable
  temp=temp|a;
  tt=temp*0.0625;
  temp=tt*10+0.5;
  return temp;
void display(uint temp)   //ÏÔʾ³ÌÐò
   uchar A1,A2,A2t,A3;
      A1=temp%10;
     A2=temp/10%10;
    A3=temp/100%10;
    w1=0;
    P3=SM[A1];
    nb(50);
    w1=1;
    w2=0;
    P3=SM[A2];
    nb(50);
    w2=1;
    w3=0;
    P3=SM[A3];
    nb(50);
    w3=1;
    w4=0;
    P3=0x77;nb(50);
    w4=1;
uchar a;
    tmpchange();
    display(tmp());
  {tmpchange();
  display(tmp());
ID:494672 發(fā)表于 2019-3-20 15:06 | 只看該作者
DS18B20對時序的要求是很高的,有問題基本上都是時序的問題。當然軟模的話可以排除硬件損壞的問題。另外注意連線的問題,才3個腳不容易錯的。
時序的問題,關鍵的是延時的問題
ID:481641 發(fā)表于 2019-4-1 13:52 | 只看該作者
可以用仿真,調一下程序
ID:52944 發(fā)表于 2019-4-1 16:42 | 只看該作者
給你一個參考程序,帶proteus仿真
DS18B20溫度計.zip
90.8 KB, 下載次數(shù): 23
可參考源碼仿真
ID:229821 發(fā)表于 2019-4-1 19:22 | 只看該作者
你是stc8系列的單片機。速度是很快的。檢查一下延時吧。初始化的時候。延時大致是這樣的。
  uint i;
DS = 1;
de_us(10); // 10us
  DS=0;
de_us(500); // 500us
  DS=1;
de_us(60); // 60us
