查看: 2194|回復(fù): 3
單片機(jī)pwm和三個(gè)超聲波一起,但是超聲波用不了,不知道問題出在哪,求大神指點(diǎn)
ID:480013 發(fā)表于 2019-3-5 22:19 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include"reg51.h"
#include<intrins.h>
#define PWM_T 100    //pwm周期100
unsigned char speed_L;    //左輪脈寬調(diào)值
unsigned char speed_R;     //右輪脈寬調(diào)值
unsigned char pwm_speed;  //定義自加變量
unsigned long time;     //讀取時(shí)間
unsigned long s;
unsigned long s1;
unsigned long s2;    //保存計(jì)算距離
sbit DA_L=P3^6;
sbit DA_R=P3^7;          //PWM高低電平輸出口
sbit L_1=P2^0;
sbit L_2=P2^1;          //左電機(jī)
sbit R_1=P2^2;
sbit R_2=P2^3;           //右電機(jī)
sbit RX=P1^0;                    //超聲波接收
sbit TX=P1^1;        //超聲波發(fā)送
sbit RX_1=P1^2;                    ///超聲波接收
sbit TX_1=P1^3;         //超聲波發(fā)送
sbit RX_2=P1^4;                    //超聲波接收
sbit TX_2=P1^5;       //?超聲波發(fā)送
void delay(unsigned char x)
  while(x--);
void count()
while(!RX);
TR0=1;
while(RX);
TR0=0;
    time=TH0*256+TL0;
TH0=0;
TL0=0;
s=(time*1.7)/100;
void count1()
while(!RX_1);
TR0=1;
while(RX_1);
TR0=0;
    time=TH0*256+TL0;
TH0=0;
TL0=0;
s1=(time*1.7)/100;
void count2()
while(!RX_2);
TR0=1;
while(RX_2);
TR0=0;
    time=TH0*256+TL0;
TH0=0;
TL0=0;
s2=(time*1.7)/100;
void status(unsigned char i)
   switch(i)
     case 0: L_1=1; L_2=0; R_1=1; R_2=0;    break;     //前進(jìn)
  case 1: L_1=0; L_2=1; R_1=0; R_2=1;    break;     //后退
  case 2: L_1=1; L_2=0; R_1=0; R_2=1;    break;     //右轉(zhuǎn)
  case 3: L_1=0; L_2=1; R_1=1; R_2=0;    break;     //左轉(zhuǎn)
  case 4: L_1=0; L_2=0; R_1=0; R_2=0;    break;     //停止
   TMOD|=0x11;
   TH0=0;
   TL0=0;
   ET0=1;
   TH1=(65536-1000)/256;
   TL1=(65536-1000)%256;
   ET1=1;
   EA=1;
   TR1=1;
   TX=1;
   delay(2);
   TX=0;
   count();
   TX_1=1;
   delay(2);
   TX_1=0;
   count1();
   TX_2=1;
   delay(2);
   TX_2=0;
      count2();
   if(s<=20&&s1<=20&&s2<=20)
    speed_L=100;
    speed_R=100;
    status(1);
   else if(s1<=20&&s<=20&&s2>=20)
    speed_L=20;
    speed_R=100;
    status(0);
   else if(s1>=20&&s<=20&&s2<=20)
    speed_L=100;
    speed_R=20;
    status(0);
    speed_L=100;
    speed_R=100;
    status(0);
void csbyc() interrupt 1
void time0_pwm()interrupt 3
  if(pwm_speed<=PWM_T)
     pwm_speed++;
    pwm_speed=0;
  if(pwm_speed<speed_L)
    DA_L=1;
    DA_L=0;
  if(pwm_speed<speed_R)
    DA_R=1;
    DA_R=0;
/*加一個(gè)超聲波就能用,但是兩個(gè)以上就不行了,試了好多種方法了,兩個(gè)以上時(shí)pwm也能用,F(xiàn)在是程序燒進(jìn)去小車總保持第一個(gè)狀態(tài)有時(shí)候改了些東西就沒反應(yīng)了。求大神指點(diǎn)下,哪里出的毛病,想好幾天了,一點(diǎn)進(jìn)展都沒有。*/
收藏收藏 分享淘帖 頂1 踩
ID:480013 發(fā)表于 2019-3-5 22:21 | 只看該作者
原程序里if中s<=20有括號括著
ID:480013 發(fā)表于 2019-3-7 15:26 來自手機(jī) | 只看該作者
求大神指點(diǎn)啊
ID:480013 發(fā)表于 2020-10-31 09:28 | 只看該作者
這個(gè)問題以前已經(jīng)解決了,能用的,只是因?yàn)闆]有連接外設(shè),程序被卡在了循環(huán)等待超聲波返回
