查看: 2308|回復: 5
請問誰有15單片機的GPS數據在1602上顯示的的代碼 求幫助
ID:476348 發(fā)表于 2019-3-8 19:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
如題
ID:476348 發(fā)表于 2019-3-8 19:05 | 只看該作者
#include "DELAY.H"
#include "lcd1602.h"
#include "uart.h"
#include<string.h>
#define Uart1_Buf_Max 70
#define Uart2_Buf_Max 70
write_com(unsigned char);
u8 count = 0;
u8 idata  Rec_Buf[Uart1_Buf_Max];
u8 point1 = 0;
u8 a,flag;
u8 xdata  Uart2_Rec_Buf[Uart2_Buf_Max];
u8 point2 = 0;
bit        B_TX2_Busy = 0;
void        GPIO_config(void)
        P5M0 &= ~(1<<5);
        P5M1 &= ~(1<<5);
void UartInit(void)                //9600bps@11.0592MHz
        PCON &= 0x7F;
        SCON = 0x50;
        AUXR |= 0x40;
        AUXR &= 0xFE;
        TMOD &= 0x0F;
        TMOD |= 0x20;
        TL1 = 0xDC;
        TH1 = 0xDC;
        ET1 = 0;
        TR1 = 1;
        S2CON = 0x50;
        AUXR |= 0x04;
        T2L = 0xE0;
        T2H = 0xFE;
        AUXR |= 0x10;
        UART2_INT_ENABLE();
        ES = 1;
        EA = 1;
void SendData(unsigned char ch)
    SBUF = ch;
                while(TI == 0);
                TI = 0;
void SendString(char *s)
    while (*s)
        SendData(*s++);
void Send(unsigned char *s,unsigned int len)
    for(a = 0;a<len;a++)
          SendData(*s++);
bit Hand(unsigned char *a)
    if(strstr(Rec_Buf,a)!=NULL)
            return 1;
                return 0;
void CLR_Buf(void)
        memset(Rec_Buf, 0, Uart1_Buf_Max);
       point1 = 0;
void Uart2SendData(unsigned char ch)
        while(B_TX2_Busy);
    S2BUF = ch;
        B_TX2_Busy = 1;
void Uart2SendString(char *s)
    while (*s)
        Uart2SendData(*s++);
bit Uart2Hand(unsigned char *a)
    if(strstr(Uart2_Rec_Buf,a)!=NULL)
            return 1;
                return 0;
void Uart2CLR_Buf(void)
        memset(Uart2_Rec_Buf, 0, Uart2_Buf_Max);
    point2 = 0;
void main(void)
                unsigned char add;
        unsigned char hh;
        hh=Uart2_Rec_Buf[20],10;
        GPIO_config();
        UartInit();
        Init_LCD1602();
        LCD1602_write_com(0x80);
        LCD1602_write_word("weidu ");
        LCD1602_write_com(0x80+0x40);
        LCD1602_write_word("jingdu ");
        Send(&Uart2_Rec_Buf[32],11);
        hh=Uart2_Rec_Buf[32];
        LCD1602_write_word("hh  ");
        write_com(0x80+0x40+add);
write_date(0x30+hh);
        delay_ms(200);
                SendString("\r\n");
                        Send(&Uart2_Rec_Buf[0],70);
                        SendString("\r\nweidu:\r\n");
                        Send(&Uart2_Rec_Buf[20],10);
                        SendString("\r\nnanbeibanqiu:\r\n");
                        Send(&Uart2_Rec_Buf[30],1);
                        SendString("\r\n");
                        SendString("jindu:\r\n");
                        SendString("\r\n");
                        SendString("dongxibanqiu:\r\n");
                        Send(&Uart2_Rec_Buf[43],1);
                        SendString("\r\n");
                        SendString("shijian(shi fen miao):\r\n");
                        Send(&Uart2_Rec_Buf[7],6);
                        SendString("\r\n");
                        SendString("shijian(nian yue ri):\r\n");
                        Send(&Uart2_Rec_Buf[61],2);
                        Send(&Uart2_Rec_Buf[59],2);
                        Send(&Uart2_Rec_Buf[57],2);
                        SendString("\r\n");
                        SendString("dimiansudu:\r\n");
                        Send(&Uart2_Rec_Buf[45],6);
                        SendString("\r\n");
                        SendString("dimianhangxiang:\r\n");
                        Send(&Uart2_Rec_Buf[51],6);
                        SendString("\r\n");
                        SendString("cipianjiaofangxiang:\r\n");
                        Send(&Uart2_Rec_Buf[66],1);
                        SendString("\r\n");
                        flag = 0;
                        point1=0;
                        point2=0;
                         ES = 1;   */
                                clrStruct();
                         SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
                        SendString("\r\n");
void Usart2() interrupt 8 using 1
        UART2_INT_DISABLE();
        if(RI2)
                CLR_RI2();
                Uart2_Rec_Buf[point2] = S2BUF;
                if(Uart2_Rec_Buf[0]!='$')
                        point2=0;
                        return;
                point2++;
                if(point2>=Uart2_Buf_Max)
                        //flag=1;
                        point2 = 0;
                        return;
    if (TI2)
        CLR_TI2();
                B_TX2_Busy = 0;
           Uart2CLR_Buf()  ;
        UART2_INT_ENABLE();
void Usart() interrupt 4 using 1
        ES = 0;
        if (RI)
        RI = 0;
                Rec_Buf[point1] = SBUF;
                point1++;
                if(point1>=Uart1_Buf_Max)
                        point1 = 0;
                //        flag=1;
    if (TI)
        TI = 0;
    //        CLR_Buf();
                ES =  1;
這個代碼只能提取出數據,不能在液晶上顯示數據
ID:253599 發(fā)表于 2019-3-9 09:09 | 只看該作者
我剛剛發(fā)了一個,你看看能不能用
ID:476348 發(fā)表于 2019-3-9 10:45 | 只看該作者
非常帥 發(fā)表于 2019-3-9 09:09
我剛剛發(fā)了一個,你看看能不能用
在哪里啊????
ID:253599 發(fā)表于 2019-3-9 14:49 | 只看該作者
heaven666 發(fā)表于 2019-3-9 10:45
在哪里????
論壇正在審核,你可以留下你的QQ,我私發(fā)給你,你也可以加我的QQ,
ID:631770 發(fā)表于 2020-4-19 11:01 來自手機 | 只看該作者
非常帥 發(fā)表于 2019-3-9 14:49
大佬能給個QQ嘛,想問些問題
Powered by 單片機教程網
