查看: 2811|回復(fù): 0
STM8L051F3寄存器版EEPROM源程序
ID:46381 發(fā)表于 2019-3-10 18:14 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "Config.h"
u8      Eeprom_text     =       0;
void EEPROM_write(unsigned char addr, unsigned char dat)
   u8 *Ptr_SegAddr; //Segment pointer
   Ptr_SegAddr = (u8 *)(EP_HEADER_ADDR+addr);  //Initialize  pointer
   FLASH_DUKR=0xAE;
   FLASH_DUKR=0x56;
   while(!FLASH_IAPSR_DUL);//如果DUL沒(méi)有置位,說(shuō)明解鎖不成功,最好加入超時(shí)判斷
   asm("sim");//關(guān)閉中斷
   *Ptr_SegAddr=dat; //指定地址,寫(xiě)1 字節(jié)
   while(!FLASH_IAPSR_EOP);//等待寫(xiě)操作完成,最好加入超時(shí)判斷
   asm("rim");//打開(kāi)中斷
   FLASH_IAPSR_DUL=0;//上鎖,對(duì)DATA EEPROM寫(xiě)保護(hù)
//EEPROM指定地址讀出一個(gè)數(shù)據(jù) addr:相對(duì)地址
unsigned char EEPROM_read(unsigned char addr)
   uint16_t Data=0;
   uint8_t *Ptr_SegAddr;
   Ptr_SegAddr = (uint8_t *)(EP_HEADER_ADDR+addr);  //Initialize  pointer
   Data=*Ptr_SegAddr;
   return Data;
