學(xué)了51的掉電與空閑模式 寫了一段代碼 使用仿真 現(xiàn)象沒有如預(yù)期 預(yù)期實驗現(xiàn)象:5s后掉電/空閑,外部中斷喚醒單片機;
實際實驗現(xiàn)象:按下外部中斷,沒有喚醒。
代碼如下:
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define digTube P0
- unsigned char code table[]=
- {0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- sbit DULA = P2^0;
- sbit WELA = P2^1;
- uchar time = 0;
- uchar tube = 0;
- void Init();
- void DelayMs(uint xms);
- void Display(uint num);
- void main()
- Init();
- while (1)
- Display(tube);
- void T0time() interrupt 1
- TH0=(65536-45872)/256;
- TL0=(65536-45872)%256;
- time++;
- if (time == 20)
- time = 0;
- tube++;
- if (tube == 6)
- ET0 = 0;
- PCON = 0x01;
- void EXIT0() interrupt 0
- DelayMs(10);
- if (INT0 == 0)
- PCON = 0;
- ET0 = 1;
- void EXIT1() interrupt 2
- DelayMs(10);
- if (INT1 == 0)
- PCON = 0;
- ET0 = 1;
- void Init()
- TMOD = 0x01;
- TH0 = (65536-45872)/256;
- TL0 = (65536-45872)%256;
- TR0 = 1;
- ET0 = 1;
- EX0 = 1;
- EX1 = 1;
- EA = 1;
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=114;j>0;j--);
- uint shi, ge;
- shi = num/10;
- ge = num%10;
- DULA = 0;
- digTube = table[shi];
- DelayMs(1);
- DULA = 1;
- WELA = 0;
- digTube = table[ge];
- DelayMs(1);
- WELA = 1;
仿真圖如下:
