查看: 5188|回復(fù): 7
[求助]大家?guī)臀铱纯匆粋(gè)小程序什么毛病,急!!!
ID:32490 發(fā)表于 2012-6-16 10:48 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本人菜鳥 只有C語(yǔ)言基礎(chǔ)和單片機(jī)概念(開始就是只知道單片機(jī)包括那幾大類東東,具體的不懂,就這種水平,現(xiàn)在對(duì)單片機(jī)有了基本的印象和了解)剛買板子幾個(gè)月 邊看書邊做,花了好久好久這么個(gè)程序,目的是用8*8數(shù)碼管用00-00-00這樣的格式表示電子鐘,但是燒進(jìn)程序后,數(shù)碼管全部顯示8.(就是全部亮,數(shù)碼管每段都亮),打擊啊,左思右想就是不知道哪里的毛病,求大手點(diǎn)化啊,新手需要鼓勵(lì)啊
//數(shù)碼管時(shí)鐘
#include "REGX52.H"
#define LED_PORT P0
#define uint8 unsigned char
#define uint16 unsigned int
#define A 20
#define B 30
#define C 40
uint8 Time2Ms= 0 ; // 2msLED 動(dòng)態(tài)掃描時(shí)標(biāo)消息
uint8 Time1S= 0 ; //時(shí)鐘1S 時(shí)標(biāo)消息
static uint16 flag2MS= 0 ; //對(duì)2 ms 時(shí)標(biāo)進(jìn)行計(jì)數(shù)
uint8 LEDBuffer[8] = {0} ; //顯示緩沖區(qū)
uint8 DisplayCode[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x40};//共陰數(shù)碼管使用
/*uint8 code  DisplayCode[]=
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,
0xbf, //'-'號(hào)代碼
} ;//共陽(yáng)數(shù)碼管使用
//初始化定時(shí)器0
void Timer0Init(void)
 TMOD &= 0xf0 ;
 TMOD |= 0x01 ; //定時(shí)器0 工作方式1
 //TH0=(65536-50000)/256;  //12M賦值
    //TL0=(65536-50000)%256;
 TH0 = 0xf8 ; //定時(shí)器初始值,2MS
 TL0 = 0xcc ;
 TR0 = 1 ;
 ET0 = 1 ;
//在定時(shí)器0 中斷處理程序中,設(shè)置時(shí)標(biāo)消息,11.0592M晶振
void Time0(void) interrupt 1
 TH0 = 0xf8 ; //定時(shí)器重新賦初值
 TL0 = 0xcc ;
 //TH0=(65536-50000)/256;  //送初值12M晶振
 //50ms_flag=1;
 Time2Ms= 1 ; //2MS 時(shí)標(biāo)標(biāo)志位置位
 if(++flag2MS== 500)
  flag2MS= 0 ;
  Time1S= 1 ;
void SetClock(uint8 nHour, uint8 nMinute, uint8 nSecond)
 LEDBuffer[0] = nHour / 10 ;
 LEDBuffer[1] = nHour % 10 ;
 LEDBuffer[2] = '-' ;
 LEDBuffer[3] = nMinute / 10 ;
 LEDBuffer[4] = nMinute % 10 ;
 LEDBuffer[5] = '-' ;
 LEDBuffer[6] = nSecond / 10 ;
 LEDBuffer[7] = nSecond % 10 ;
void RunClock(void)//數(shù)碼管電子鐘程序
if(Time1S )
 Time1S = 0 ;
 if(++LEDBuffer[7] == 10)
  LEDBuffer[7] = 0 ;
  if(++LEDBuffer[6] == 6)
   LEDBuffer[6] = 0 ;
   if(++LEDBuffer[4] == 10)
    LEDBuffer[4] = 0 ;
    if(++LEDBuffer[3] == 6)
     LEDBuffer[3] = 0 ;
     if( LEDBuffer[0]<2)
      if(++LEDBuffer[1]==10)
      LEDBuffer[1] = 0 ;
      LEDBuffer[0]++;
      if(++LEDBuffer[1]==4)
       LEDBuffer[1] = 0 ;
       LEDBuffer[0] = 0 ;
//再分別編寫送數(shù)碼管段碼函數(shù),以及位選通函數(shù)。
void SendLedSegData(uint8 dat)
 LED_PORT = dat ;
 P2_6 = 1 ; //開段碼鎖存,送段碼數(shù)據(jù)
 P2_6 = 0 ;
void SendLedBitData(uint8 dat)
 uint8 temp ;
 temp = (0x01 << dat ) ; //根據(jù)要選通的位計(jì)算出位碼
 LED_PORT = temp ;
 P2_7 = 1 ; //開位碼鎖存,送位碼數(shù)據(jù)
 P2_7 = 0 ;
void LedDisplay(uint8 * pBuffer)
 static uint8 LED_BIT = 0 ;
 if(flag2MS)
  flag2MS= 0 ;
  SendLedBitData(8) ; //消隱
  if(pBuffer[LED_BIT] == '-') //顯示'-'號(hào)
   SendLedSegData(DisplayCode[16]) ;
   SendLedSegData(DisplayCode[pBuffer[LED_BIT]]) ;
  SendLedBitData(LED_BIT);
  if(++LED_BIT > 7)
   LED_BIT = 0 ;
void main_init()
 P1_4 = 1 ; //關(guān)閉LED燈
    P3_4=0;//關(guān)閉液晶
 Timer0Init() ;
 SetClock(A,B,C) ; //設(shè)置初始時(shí)間
 EA = 1 ;
    main_init();
 LedDisplay(LEDBuffer);
 RunClock();
附:板子為本站的VER51HEI-5,keil 編譯通過,無錯(cuò)誤無警告,附圖如下:
[此貼子已經(jīng)被作者于2012-6-16 16:12:48編輯過]
ID:32490 發(fā)表于 2012-6-20 18:12 | 只看該作者
怎么沒人回答啊,給點(diǎn)建議哇
ID:1 發(fā)表于 2012-6-21 04:39 | 只看該作者
這個(gè)程序是網(wǎng)上找了修改的 還是完全自己寫的 問題比較多
ID:35727 發(fā)表于 2012-6-25 18:35 | 只看該作者
你寫的好復(fù)雜啊
ID:32490 發(fā)表于 2012-6-29 18:02 | 只看該作者
以下是引用wy704972600在2012-6-25 18:35:09的發(fā)言:
你寫的好復(fù)雜啊
我是新手啊 已經(jīng)盡力了 怎么能優(yōu)化啊 有沒有效率高代碼簡(jiǎn)單的啊 發(fā)我一份啊
ID:32490 發(fā)表于 2012-6-29 18:04 | 只看該作者
以下是引用admin在2012-6-21 4:39:14的發(fā)言:
管理員幫忙指出我的問題啊 我進(jìn)入自己的死胡同了轉(zhuǎn)不出來
ID:42637 發(fā)表于 2012-7-9 20:36 | 只看該作者
寫復(fù)雜了
[此貼子已經(jīng)被作者于2012-7-9 20:44:30編輯過]
ID:41987 發(fā)表于 2012-7-14 16:13 | 只看該作者
你好!
你應(yīng)該是寫得顯示函數(shù)有問題,段與位選之間可能有問題。我改寫顯示函數(shù)以后可以正常運(yùn)行。
void display(uint8 aa, uint8 bb,uint8 cc,uint8 dd, uint8 ee,uint8 ff,uint8 gg, uint8 hh)
P0=table[aa];   //送段選數(shù)據(jù)
dula=1;         //打開段選
dula=0;         //關(guān)閉斷選
P0=0xff;    //送位選數(shù)據(jù)前關(guān)閉所有顯示,防止打開位選鎖存時(shí)原來段選數(shù)據(jù)通過位鎖存端造成混亂
P0=0xfe;        //送位選數(shù)據(jù)
wela=1;         //打開位選
wela=0;         //關(guān)閉位選
delayms(1);     //延時(shí)
P0=table[bb];    //送段選數(shù)據(jù)
dula=1;         //打開段選
P0=0xff;//送位選數(shù)據(jù)前關(guān)閉所有顯示,防止打開位選鎖存時(shí)原來段選數(shù)據(jù)通過位鎖存端造成混亂
P0=0xfd;      //送位選數(shù)據(jù)
wela=1;        //打開位選
P0=table[cc]; //送段選數(shù)據(jù)
dula=1;       //打開段選
P0=0xfb;     //送位選數(shù)據(jù)
wela=1;      //打開位選
P0=table[dd];   //送段選數(shù)據(jù)
dula=1;         //打開段選
P0=0xf7;        //送位選數(shù)據(jù)
wela=1;         //打開位選
P0=table[ee];    //送段選數(shù)據(jù)
dula=1;         //打開段選
P0=0xef;      //送位選數(shù)據(jù)
wela=1;        //打開位選
P0=table[ff]; //送段選數(shù)據(jù)
dula=1;       //打開段選
P0=0xdf;     //送位選數(shù)據(jù)
wela=1;      //打開位選
P0=table[gg];   //送段選數(shù)據(jù)
dula=1;         //打開段選
P0=0xbf;        //送位選數(shù)據(jù)
wela=1;         //打開位選
P0=table[hh];    //送段選數(shù)據(jù)
dula=1;         //打開段選
P0=0x7f;      //送位選數(shù)據(jù)
wela=1;        //打開位選
void delayms(uint16 z)
uint16 x,y;
for(x=z;x>0;x--)
 for(y=110;y>0;y--);
這個(gè)顯示函數(shù)是我根據(jù)光盤里的程序改寫的
