查看: 7132|回復: 9
鬧著玩-數(shù)控電源
ID:489769 發(fā)表于 2019-3-13 11:03 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
一直想弄個數(shù)控電源,今天把手里的東西搜羅一下感覺可以整在一起就動手了,事后算了一下成本, 35元左右,而且都是淘寶可以買到的東西
電壓用手機軟件調(diào)節(jié)
lm2596 DCDC降壓模塊¥4.00
Mini360 DCDC¥2.00
LM393 電壓比較模塊¥4.00
ESP32 NodeMCU¥24.00
電阻三只(20k左右)¥1.00
合計¥35.00
ACDC電源適配器(12-19)自備
手機自備
收藏收藏6 分享淘帖 頂1 踩
ID:1 發(fā)表于 2019-3-13 22:08 | 只看該作者
樓主能分享制作資料嗎?
ID:489769 發(fā)表于 2019-3-13 23:28 | 只看該作者
admin 發(fā)表于 2019-3-13 22:08
樓主能分享制作資料嗎?
明天補上
ID:489769 發(fā)表于 2019-3-14 10:36 | 只看該作者
ID:489769 發(fā)表于 2019-3-14 10:45 | 只看該作者
ESP32 上的程序 基于 Arduino 和 Blynk
  Download latest Blynk library here:
    https://github.com/blynkkk/blynk-library/releases/latest
  Blynk is a platform with iOS and Android apps to control
  Arduino, Raspberry Pi and the likes over the Internet.
  You can easily build graphic interfaces for all your
  projects by simply dragging and dropping widgets.
  Blynk library is licensed under MIT license
  This example code is in public domain.
  This example runs directly on ESP32 chip.
  Note: This requires ESP32 support package:
    https://github.com/espressif/arduino-esp32
  Please be sure to select the right ESP32 module
  in the Tools -> Board menu!
  Change WiFi ssid, pass, and Blynk auth token to run :)
  Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "your_auth";          //改成你自己的 auth
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "wifi_name";      //改成你自己的 wifi 名稱
char pass[] = "wifi_password";  //改成你自己的 wifi 密碼
int powerPin = 25;  //dac輸出腳
BLYNK_WRITE(V1)
    float tmpVal;
    tmpVal = param.asInt();
    tmpVal = tmpVal / 100; // assigning incoming value from pin V1 to a variable
    tmpVal = tmpVal / 6;   //根據(jù)分壓電阻調(diào)整系數(shù)
    tmpIntVal = tmpVal * 256 /3.3;
    dacWrite(powerPin, tmpIntVal);
void setup()
  // Debug console
  Serial.begin(115200);
  Blynk.begin(auth, ssid, pass);
void loop()
  Blynk.run();
ID:489769 發(fā)表于 2019-3-14 10:55 | 只看該作者
手機端在應用市場搜索Blynk安裝就好,ios,android 都可以,設置比較簡單控制V1端口輸出值就行,用blynk掃描 我提供的二維碼也可以
ID:472506 發(fā)表于 2019-3-19 08:46 | 只看該作者
好文章,收藏一個先。
ID:128989 發(fā)表于 2020-2-4 12:24 | 只看該作者
不錯的文章,學習了
ID:712493 發(fā)表于 2021-6-14 21:11 | 只看該作者
不錯的玩法 贊一個
ID:712493 發(fā)表于 2021-10-25 09:24 | 只看該作者
EP32的開發(fā)環(huán)境搭建可以講講  ESP32 上的程序 基于 Arduino
