作者:李剴 出處:
歡迎轉(zhuǎn)載,但也請(qǐng)保留上面這段聲明。謝謝!
<上面那個(gè)連接是我的博客,現(xiàn)在將這篇隨筆分享給51hei的朋友>
2019-3-14 17:03 上傳
2019-3-14 17:03 上傳
2019-3-14 17:04 上傳
**PC2LCD2002取模方式設(shè)置:陰碼+逐列式+順向+C51格式**
附: 代碼
- //24*24的OLED漢字點(diǎn)陣,包括三個(gè)漢字:開(kāi)、發(fā)、板。這三個(gè)漢字的點(diǎn)陣庫(kù),是利用PCtoLCD2002生產(chǎn)的,
- //軟件設(shè)置的取模方式同OLED實(shí)驗(yàn)ASCII的取模方式一模一樣,字體采用12*大小,一個(gè)漢字點(diǎn)陣占用24字節(jié)。
- const unsigned char OLED_HZK_TBL[14][24]=
- {0x00,0x00,0x1F,0x80, 0x11,0x00, 0x11,0x00, 0x11,0x00, 0xFF,0xF0, 0x11,0x00,0x11, 0x00,0x11, 0x00,0x1F, 0x80,0x00,0x00,0x00,0x00},/*"中",0*/
- {0xFF,0xF0,0x80,0xA0,0xA4,0xA0,0xA4,0xA0,0xA4,0xA0,0xBF,0xA0,0xA4,0xA0,0xA6,0xA0,0xA5,0xA0,0x80,0xA0,0xFF,0xF0,0x00,0x00},/*"國(guó)",1*/
復(fù)制代碼同理,若想要32個(gè)字節(jié)的漢字矩陣,可以將字寬,字高都設(shè)為16。 其他大小的也可以這樣去設(shè)置 ps : 32字節(jié)矩陣,字高字寬設(shè)為16之后,還得新建一個(gè)數(shù)組存儲(chǔ)。 二維數(shù)組列設(shè)為36,如下
- const unsigned char OLED_HZK_TBL[14][36]=
- {0x00,0x00,0x00,0x00,0x0F,0xF0,0x08,0x20,0x08,0x20,0x08,0x20,0x08,0x20,0xFF,0xFF,0x08,0x20,0x08, 0x20,0x08,0x20,0x08,0x20,0x0F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00},/*"中",0*/
- {0x00,0x00,0x7F,0xFF,0x40,0x02,0x48,0x12,0x49,0x12,0x49,0x12,0x49,0x12,0x4F,0xF2,0x49,0x12,0x49, 0x52,0x49,0x32,0x48,0x12,0x40,0x02,0x7F,0xFF,0x00,0x00,0x00,0x00},/*"國(guó)",1*/
