查看: 5768|回復: 7
基于51單片機的電子密碼鎖
ID:408691 發(fā)表于 2019-3-14 19:51 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
//包含頭文件
#include <REG51.h>
#include<intrins.h>
//宏定義
#define LCM_Data  P0                  //將P0口定義為LCM_Data
#define uint  unsigned int
//1602的控制腳
sbit lcd1602_rs=P2^5;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^7;
sbit Scl=P3^4;                        //24C02串行時鐘
sbit Sda=P3^5;                        //24C02串行數據
sbit ALAM = P2^1;                //報警
sbit KEY = P3^6;                //開鎖
bit  pass=0;                        //密碼正確標志
bit  ReInputEn=0;                //重置輸入允許標志
bit  s3_keydown=0;                //3秒按鍵標志位
bit  key_disable=0;                //鎖定鍵盤標志
unsigned char countt0,second;        //t0中斷計數器,秒計數器
void Delay5Ms(void);                //聲明延時函數
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盤掃描控制表
//液晶顯示數據數組
unsigned char code start_line[]        = {"password:       "};
unsigned char code name[]                  = {"===Coded Lock==="};        //顯示名稱
unsigned char code Correct[]         = {"     correct    "};                //輸入正確
unsigned char code Error[]           = {"      error     "};          //輸入錯誤
unsigned char code codepass[]        = {"      pass      "};
unsigned char code LockOpen[]        = {"      open      "};                //OPEN
unsigned char code SetNew[]         = {"SetNewWordEnable"};
unsigned char code Input[]           = {"input:          "};                //INPUT
unsigned char code ResetOK[]         = {"ResetPasswordOK "};
unsigned char code initword[]        = {"Init password..."};
unsigned char code Er_try[]                = {"error,try again!"};
unsigned char code again[]                = {"input again     "};
unsigned char InputData[6];        //輸入密碼暫存區(qū)
unsigned char CurrentPassword[6]={0,0,0,0,0,0};                         //讀取EEPROM密碼暫存數組
unsigned char TempPassword[6];
unsigned char N=0;                                //密碼輸入位數記數
unsigned char ErrorCont;                        //錯誤次數計數
unsigned char CorrectCont;                        //正確輸入計數
unsigned char ReInputCont;                         //重新輸入計數
unsigned char code initpassword[6]={0,0,0,0,0,0};                        //輸入管理員密碼后將密碼初始為000000
unsigned char code adminpassword[6]={1,3,1,4,2,0};                        //輸入管理員密碼后將密碼初始為000000
//=====================5ms延時==============================
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//===================400ms延時==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延時
        uchar i;
           while(t--)
                   for(i=0;i<125;i++)
void Nop(void)                  //空操作
        _nop_();                  //僅作延時用一條語句大約1us
        _nop_();
        _nop_();
        _nop_();
/*****24c02程序參照24c02時序圖*****/
/*起始條件*/
void Start(void)
        Sda=1;
        Scl=1;
        Nop();
        Sda=0;
        Nop();
/*停止條件*/
void Stop(void)
        Sda=0;
        Scl=1;
        Nop();
        Sda=1;
        Nop();
/*應答位*/
void Ack(void)
        Sda=0;
        Nop();
        Scl=1;
        Nop();
        Scl=0;
/*反向應答位*/
void NoAck(void)
        Sda=1;
        Nop();
        Scl=1;
        Nop();
        Scl=0;
/*發(fā)送數據子程序,Data為要求發(fā)送的數據*/
void Send(uchar Data)
           uchar BitCounter=8;
           uchar temp;
           do
                   temp=Data;                                           //將待發(fā)送數據暫存temp
                   Scl=0;
                   Nop();
                   if((temp&0x80)==0x80)                   //將讀到的數據&0x80
                   Sda=1;
                   Sda=0;
                   Scl=1;
                   temp=Data<<1;                                   //數據左移
                   Data=temp;                                           //數據左移后重新賦值Data
                   BitCounter--;                                   //該變量減到0時,數據也就傳送完成了
           while(BitCounter);                                   //判斷是否傳送完成
           Scl=0;
/*讀一字節(jié)的數據,并返回該字節(jié)值*/
uchar Read(void)
    uchar temp=0;
        uchar temp1=0;
        uchar BitCounter=8;
        Sda=1;
        do
                Scl=0;
                Nop();
                Scl=1;
                Nop();
                if(Sda)                                   //數據位是否為1
                        temp=temp|0x01;           //為1 temp的最低位為1(|0x01,就是將最低位變?yōu)?)
                else                                   //如果為0
                        temp=temp&0xfe;           //temp最低位為0(&0xfe(11111110)最低位就是0)
                if(BitCounter-1)           //BitCounter減1后是否為真
                        temp1=temp<<1;           //temp左移
                        temp=temp1;
                BitCounter--;                   //BitCounter減到0時,數據就接收完了
        while(BitCounter);                   //判斷是否接收完成
        return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Send(*(PData+i));
  Ack();
  Stop();
  mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Start();
  Send(0xa1);
  Ack();
  *(PData+i)=Read();
  Scl=0;
  NoAck();
  Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
//----------------延時函數,后面經常調用----------------------
void delay(uint xms)//延時函數,有參函數
        uint x,y;
        for(x=xms;x>0;x--)
         for(y=110;y>0;y--);
//--------------------------寫指令---------------------------
void write_1602com(uchar com)//****液晶寫入指令函數****
        lcd1602_rs=0;//數據/指令選擇置為指令
        lcd1602_rw=0; //讀寫選擇置為寫
        P0=com;//送入數據
        delay(1);
        lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
        delay(1);
        lcd1602_en=0;//en由高變低,產生下降沿,液晶執(zhí)行命令
//-------------------------寫數據-----------------------------
void write_1602dat(uchar dat)//***液晶寫入數據函數****
        lcd1602_rs=1;//數據/指令選擇置為數據
        P0=dat;//送入數據
        delay(1);
        lcd1602_en=1; //en置高電平,為制造下降沿做準備
        delay(1);
        lcd1602_en=0; //en由高變低,產生下降沿,液晶執(zhí)行命令
//-------------------------初始化-------------------------
void lcd_init(void)
        write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
        write_1602com(0x0c);//開顯示不顯示光標
        write_1602com(0x06);//整屏不移動,光標自動右移
        write_1602com(0x01);//清顯示
//==============將按鍵值編碼為數值=========================
unsigned char coding(unsigned char m)
        unsigned char k;
        switch(m)
                case (0x11): k=1;break;
                case (0x21): k=2;break;
                case (0x41): k=3;break;
                case (0x81): k='A';break;
                case (0x12): k=4;break;
                case (0x22): k=5;break;
                case (0x42): k=6;break;
                case (0x82): k='B';break;
                case (0x14): k=7;break;
                case (0x24): k=8;break;
                case (0x44): k=9;break;
                case (0x84): k='C';break;
                case (0x18): k='*';break;
                case (0x28): k=0;break;
                case (0x48): k='#';break;
                case (0x88): k='D';break;
        return(k);
//=====================按鍵檢測并返回按鍵值===============================
unsigned char keynum(void)
        unsigned char row,col,i;
        P1=0xf0;
        if((P1&0xf0)!=0xf0)
                   Delay5Ms();
        Delay5Ms();
                   if((P1&0xf0)!=0xf0)
                    row=P1^0xf0;          //確定行線
                        i=0;
                        P1=a[i];                  //精確定位
                        while(i<4)
                                 if((P1&0xf0)!=0xf0)
                                           col=~(P1&0xff);          //確定列線
                                           break;            //已定位后提前退出
                                           i++;
                                           P1=a[i];
                        return 0;
                while((P1&0xf0)!=0xf0);
                return (row|col);                         //行線與列線組合后返回
        else return 0;                                 //無鍵按下時返回0
//=======================一聲提示音,表示有效輸入========================
void OneAlam(void)
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================二聲提示音,表示操作成功========================
void TwoAlam(void)
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================三聲提示音,表示錯誤========================
void ThreeAlam(void)
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//=======================顯示提示輸入=========================
void DisplayChar(void)
        unsigned char i;
        if(pass==1)
                //DisplayListChar(0,1,LockOpen);
                write_1602com(er);                                   //在二行開始顯示
                for(i=0;i<16;i++)
                        write_1602dat(LockOpen[i]);           //顯示open 開鎖成功
                if(N==0)
                        //DisplayListChar(0,1,Error);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(Error[i]);        //顯示錯誤
                        //DisplayListChar(0,1,start_line);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(start_line[i]);//顯示開始輸入
//========================重置密碼==================================================
void ResetPassword(void)
        unsigned char i;
        unsigned char j;
        if(pass==0)
                pass=0;
                DisplayChar();           //顯示錯誤
                ThreeAlam();           //沒開鎖時按下重置密碼報警3聲
        else                                   //開鎖狀態(tài)下才能進行密碼重置程序
            if(ReInputEn==1)   //開鎖狀態(tài)下,ReInputEn置1,重置密碼允許
                        if(N==6)           //輸入6位密碼
                                ReInputCont++;                        //密碼次數計數
                                if(ReInputCont==2)                //輸入兩次密碼
                                        for(i=0;i<6;)
                                                if(TempPassword[i]==InputData[i])        //將兩次輸入的新密碼作對比
                                                        i++;
                                                else        //如果兩次的密碼不同
                                                        write_1602com(er);
                                                        for(j=0;j<16;j++)
        write_1602dat(Error[j]);        //顯示錯誤Error
                                                        ThreeAlam();                        //錯誤提示
                                                        pass=0;                                        //關鎖
                                                        ReInputEn=0;                        //關閉重置功能,
                                                        ReInputCont=0;
                                                        DisplayChar();
                                                        break;
                                        if(i==6)
                                                //DisplayListChar(0,1,ResetOK);
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(ResetOK[j]);          //密碼修改成功,顯示
                                                TwoAlam();                                //操作成功提示
                                                 WrToROM(TempPassword,0,6);                //將新密碼寫入24C02存儲
                                                ReInputEn=0;
                                        ReInputCont=0;
                                        CorrectCont=0;
                                else                                          //輸入一次密碼時
                                        OneAlam();
                                        //DisplayListChar(0, 1, again);                 //顯示再次輸入一次
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(again[j]);                        //顯示再輸入一次
                                        for(i=0;i<6;i++)
                                                TempPassword[i]=InputData[i];                //將第一次輸入的數據暫存起來
                        N=0;                                                //輸入數據位數計數器清零
//=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
void Alam_KeyUnable(void)
        P1=0x00;
                ALAM=~ALAM;                                 //蜂鳴器一直閃爍鳴響
                Delay5Ms();
//=======================取消所有操作============================================
void Cancel(void)
        unsigned char i;
        unsigned char j;
        //DisplayListChar(0, 1, start_line);
        write_1602com(er);
        for(j=0;j<16;j++)
                write_1602dat(start_line[j]);          //顯示開機輸入密碼界面
        TwoAlam();                                //提示音
        for(i=0;i<6;i++)
                InputData[i]=0;                //將輸入密碼清零
        KEY=1;                                        //關閉鎖
        ALAM=1;                                        //報警關
        pass=0;                                        //密碼正確標志清零
        ReInputEn=0;                        //重置輸入充許標志清零
        ErrorCont=0;                        //密碼錯誤輸入次數清零
        CorrectCont=0;                        //密碼正確輸入次數清零
        ReInputCont=0;                        //重置密碼輸入次數清零
        s3_keydown=0;
        key_disable=0;                        //鎖定鍵盤標志清零
        N=0;                                        //輸入位數計數器清零
//==========================確認鍵,并通過相應標志位執(zhí)行相應功能===============================
void Ensure(void)
        unsigned char i,j;
        RdFromROM(CurrentPassword,0,6);                                         //從24C02里讀出存儲密碼
    if(N==6)
            if(ReInputEn==0)                                                        //重置密碼功能未開啟
                        for(i=0;i<6;)
                                if(CurrentPassword[i]==InputData[i])        //判斷輸入密碼和24c02中的密碼是否相同
                                        i++;        //相同一位 i就+1
                                else        //如果有密碼不同
                                        ErrorCont++;                                                //錯誤次數++
                                        if(ErrorCont==3)                        //錯誤輸入計數達三次時,報警并鎖定鍵盤
                                                write_1602com(er);
                                                for(i=0;i<16;i++)
                                                do
                                                Alam_KeyUnable();
                                                while(1);
                                        else                                         //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
                                                TR0=1;                                //開啟定時
                                                key_disable=1;                        //鎖定鍵盤
                                                pass=0;                                        //pass位清零
                                                break;                                        //跳出
                        if(i==6)                                         //密碼輸入對時
                                if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
                                        WrToROM(initpassword,0,6);                                 //強制將初始密碼寫入24C02存儲
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(initword[j]);                                //顯示初始化密碼
                                        TwoAlam();        //成功提示音
                                        Delay400Ms();        //延時400ms
                                        TwoAlam();        //成功提示音
                                        N=0;        //輸入位數計數器清零
                                        CorrectCont++;                                        //輸入正確變量++
                                        if(CorrectCont==1)                                //正確輸入計數,當只有一次正確輸入時,開鎖
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(LockOpen[j]);                  //顯示open開鎖畫面
                                                TwoAlam();                        //操作成功提示音
                                                KEY=0;        //開鎖
                                                pass=1;        //置正確標志位
                                                TR0=1;        //開啟定時
                                                for(j=0;j<6;j++)        //將輸入清除
                                                        InputData[i]=0;        //開鎖后將輸入位清零
                                        else        //當兩次正確輸入時,開啟重置密碼功能
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(SetNew[j]);                                        //顯示重置密碼界面
                                                TwoAlam();        //操作成功提示
                                                ReInputEn=1;        //允許重置密碼輸入
                                                CorrectCont=0;        //正確計數器清零
                        else                        //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                        TwoAlam();        //成功提示音
                                        TwoAlam();        //成功提示音
                                        N=0;        //輸入位數計數器清零
                                else        //密碼輸入錯誤
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(Error[j]);                                 //顯示錯誤信息
                                        ThreeAlam();        //錯誤提示音
                                        pass=0;
                else        //當已經開啟重置密碼功能時,而按下開鎖鍵,
                        //DisplayListChar(0,1,Er_try);
                        write_1602com(er);
                        for(j=0;j<16;j++)
                                write_1602dat(Er_try[j]);                          //錯誤,請重新輸入
        else                                   //密碼沒有輸入到6位時,按下確認鍵時
                write_1602com(er);
                for(j=0;j<16;j++)
                pass=0;
        N=0;        //將輸入數據計數器清零,為下一次輸入作準備
//==============================主函數===============================
void main(void)
        unsigned char KEY,NUM;
        unsigned char i,j;
        P1=0xFF;                                    //P1口復位
        TMOD=0x11;                                   //定義工作方式
        TL0=0xB0;
        TH0=0x3C;                                   //定時器賦初值
        EA=1;                                           //打開中斷總開關
        ET0=1;                                           //打開中斷允許開關
        TR0=0;                                           //打開定時器開關
        Delay400Ms();         //啟動等待,等LCM講入工作狀態(tài)
        lcd_init();         //LCD初始化
        write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
        for(i=0;i<16;i++)
                write_1602dat(name[i]);//向液晶屏寫開機畫面
        write_1602com(er);
        for(i=0;i<16;i++)
                write_1602dat(start_line[i]);//寫輸入密碼等待界面
        write_1602com(er+9);        //設置光標位置
        write_1602com(0x0f);        //設置光標為閃爍
        Delay5Ms(); //延時片刻(可不要)
        N=0;        //初始化數據輸入位數
        while(1)                 //進入循環(huán)
                if(key_disable==1)                                                //鎖定鍵盤標志為1時
                        Alam_KeyUnable();                                        //報警鍵盤鎖
                        ALAM=1;        //關報警
                KEY=keynum();                                                        //讀按鍵的位置碼
                if(KEY!=0)        //當有按鍵按下時
                                second=0;                                                //秒清零
                        else        //沒有鎖定鍵盤時
                                NUM=coding(KEY);                                //根據按鍵的位置將其編碼,編碼值賦值給NUM
                                        switch(NUM)                                        //判斷按鍵值
                                                case ('A'):         ;                                         break;
                                                case ('B'):                ;                                     break;
                                                case ('C'):
        for(i=0;i<16;i++)
        if(N>=1) N--;        OneAlam();        //按鍵提示音
        //DisplayOneChar(6+N,1,'*');
        for(j=N;j<16;j++)
        write_1602com(er+6+j);
        write_1602dat(' ');
        for(j=0;j<N;j++)
        write_1602com(er+6+j);                                //顯示位數隨輸入增加而增加
        write_1602dat('*');                                        //但不顯示實際數字,用*代替
        InputData[N]=N+4;
        break;                //ABC是無定義按鍵
                                                case ('D'): ResetPassword();                break;      //重新設置密碼
                                                case ('*'): Cancel();                                break;      //取消當前輸入
                                                case ('#'): Ensure();                                 break;           //確認鍵,
                                                default:        //如果不是功能鍵按下時,就是數字鍵按下
                                                        //DisplayListChar(0,1,Input);
                                                        if(N<6)                                                           //當輸入的密碼少于6位時,接受輸入并保存,大于6位時則無效。
        write_1602com(er);
        for(i=0;i<16;i++)
        write_1602dat(Input[i]);                                //顯示輸入畫面
        OneAlam();        //按鍵提示音
        for(j=0;j<=N;j++)
        InputData[N]=NUM;                                                //將數字鍵的碼賦值給InputData[]數組暫存
        N++;        //密碼位數加
                                                        else        //輸入數據位數大于6后,忽略輸入
        N=6;        //密碼輸入大于6位時,不接受輸入
        break;
//*********************************中斷服務函數**************************************
void  time0_int(void) interrupt 1                    //定時器T0
        TL0=0xB0;
        TH0=0x3C;                  //定時器重新賦初值
        //TR0=1;
        countt0++;                           //計時變量加,加1次時50ms
          if(countt0==20)                   //加到20次就是1s
                countt0=0;                   //變量清零
                second++;                   //秒加
                if(pass==1)                   //開鎖狀態(tài)時
                        if(second==1)                        //秒加到1s時
                                TR0=0;                                //關定時器
                                TL0=0xB0;
                                TH0=0x3C;                        //再次賦初值
                                second=0;                        //秒清零
                else                                                //不在開鎖狀態(tài)時
                        if(second==3)                        //秒加到3時
                                TR0=0;                                //關閉定時器
                                second=0;                        //秒清零
                                key_disable=0;                //鎖定鍵盤清零
                                s3_keydown=0;
                                TL0=0xB0;
                                TH0=0x3C;                        //重新賦初值
                            TR0=1;                                //打開定時器
PCB
PCB
原理圖
原理圖
參與人數 1黑幣 +50 收起 理由
admin + 50 共享資料的黑幣獎勵!
收藏收藏8 分享淘帖 頂2 踩
來自 8#
ID:76027 發(fā)表于 2024-5-13 21:26 | 只看該作者
代碼中有二段這樣的,請教一下這二段的有什么區(qū)別。
    if(i==6)                                         //密碼輸入對時
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                        TwoAlam();        //成功提示音
                                        TwoAlam();        //成功提示音
                                        N=0;        //輸入位數計數器清零
第二段是初始化密碼,那第一段呢?
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                        TwoAlam();        //成功提示音
                                        TwoAlam();        //成功提示音
                                        N=0;        //輸入位數計數器清零
ID:636476 發(fā)表于 2019-11-6 09:58 | 只看該作者
很棒、、!!
ID:656942 發(fā)表于 2019-12-6 15:26 來自觸屏版 | 只看該作者
請問有原件清單嗎
ID:662533 發(fā)表于 2019-12-17 16:00 | 只看該作者
你好,請問有protues仿真文件嗎
ID:166102 發(fā)表于 2019-12-25 08:57 | 只看該作者
請問有原件清單嗎
ID:673033 發(fā)表于 2019-12-27 00:13 來自觸屏版 | 只看該作者
如果有原件清單就更好了
ID:1120342 發(fā)表于 2024-5-12 15:15 | 只看該作者
很棒,我的大神
Powered by 單片機教程網
