8路溫度采集器
- #include <reg52.h>
- #include <intrins.h>
- #define MAXNUM 8 //定義最多有8個(gè) DS18B20
- sbit DQ=P2^3; //定義DS18B20總線端
- sbit RS=P2^0; //液晶端口控制線端口定義
- sbit RW=P2^1; //液晶端口控制線端口定義
- sbit E= P2^2; //液晶端口控制線端口定義
- sbit keyenter =P3^2; //功能按鍵
- sbit keyup =P3^3; //報(bào)警溫度加鍵
- sbit keydown =P3^4; //報(bào)警溫度減鍵
- sbit led= P1^6; //亮燈報(bào)警
- sbit buzzer= P1^7; //蜂鳴器報(bào)警控制腳
- unsigned char code lcd0[]={"SEARCH ROMING..."};
- unsigned char code lcd1[]={"SEARCH ROM OK!"};
- unsigned char code lcd2[]={"THE TOTAL IS:"};
- unsigned char code lcd3[]={"NO.[ ]:"};
- unsigned char code lcd4[]={'0','1','2','3','4','5','6','7','8','9','.',0xdf,0x43,' '};
- unsigned char code setinfo[]={"SET ALARM POINT:"};
- unsigned char code pointinfo[]={"ALARM:"};
- signed char tempalarm=0;
- //0xdf在1602中是“℃”符號(hào)的左上角那個(gè)圓,0X43是大寫(xiě)的"C" 他們一起構(gòu)成了”℃“這個(gè)符號(hào)
- unsigned char dat[6];//用來(lái)顯示溫度的參數(shù)
- unsigned char temp_l,temp_h,negetiveflag=0,temp_over,t;
- unsigned char num=0;
- unsigned int i;
- bit keyflag=0;
- idata unsigned char al[MAXNUM];
- idata unsigned char ID[MAXNUM][8];
- signed char alarm=30; //默認(rèn)為30攝氏度報(bào)警
- /***********************液晶模塊**********************************/
- void delaylcd(void)//延時(shí)程序
- unsigned char y;
- for(y=0;y<250;y++);
- void LCD_write_com(unsigned char com)//液晶寫(xiě)命令函數(shù)
- delaylcd();
- RS=0; //RS為1 寫(xiě)命令
- RW=0;
- E=0;
- E=1;
- P0=com;
- E=0;
- delaylcd();
- void LCD_write_data(unsigned char dat)//液晶寫(xiě)數(shù)據(jù)函數(shù)
- delaylcd();
- RS=1; //RS為1 寫(xiě)數(shù)據(jù)
- RW=0;
- E=0;
- E=1;
- P0=dat;
- E=0;
- delaylcd();
- void lcdinit(void)//初始化
- LCD_write_com(0x01); //液晶清屏
- LCD_write_com(0x38); //1602”功能設(shè)置命令字“ 顯示2行 每行字體用5*8 ASCII顯示 8位數(shù)據(jù)接口
- LCD_write_com(0x0c); //顯示控制,開(kāi)始顯示,不顯示游標(biāo),游標(biāo)不閃爍
- LCD_write_com(0x06); //輸入方式為增量輸入,不移屏幕
- /************************ds18b20模塊****************************/
- void delay_nus(unsigned int n)//延時(shí) 程序 一次8+6(進(jìn)出)=14us
- while(n--);
- void reset(void) //ds18b20初始化復(fù)位操作
- unsigned char x=0;
- DQ = 1; //DQ復(fù)位
- delay_nus(8); //稍做延時(shí)
- DQ = 0; //單片機(jī)將DQ拉低
- delay_nus(80); //精確延時(shí) 大于 480us
- DQ = 1; //拉高總線
- delay_nus(10);
- x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
- delay_nus(5);
- void write_bit(unsigned char dat) //DS18B20 寫(xiě)一位 操作
- DQ = 0;
- _nop_();
- _nop_();
- DQ = dat&0x01;
- delay_nus(5);
- DQ = 1;
- void write_byte(unsigned char dat)//寫(xiě)一個(gè)字節(jié)
- unsigned char i,j;
- for (i=8; i>0; i--)
- j=dat&0x01;
- write_bit(j);
- dat>>=1;
- unsigned char read_2bit(void)//讀二位 子程序
- unsigned char i;
- unsigned char dat = 0;
- for (i=2;i>0;i--)
- DQ = 0; // 給脈沖信號(hào)
- dat<<=1;
- DQ = 1; // 給脈沖信號(hào)
- if(DQ)
- dat|=0x01;
- delay_nus(4);
- return(dat);
- unsigned char read_byte(void)//讀一個(gè)字節(jié) 子程序
- unsigned char i=0;
- for (i=8;i>0;i--)
- dat>>=1;
- if(DQ)
- dat|=0x80;
- delay_nus(4);
- return(dat);
- void delay_nms(unsigned int n)
- unsigned int j=0;
- for(j=0;j<n;j++)
- for(i=0;i<120;i++)
- _nop_();
- * 函 數(shù) 名 : read_temp
- * 函數(shù)功能 : 讀取某一個(gè)DS18B20的溫度
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void read_temp(unsigned char num_data)//讀取溫度 子程序 參數(shù)表示讀第幾個(gè)傳感器
- unsigned char f;
- reset(); //DS18B20復(fù)位
- write_byte(0xcc);//發(fā)送跳過(guò)ROM號(hào)命令
- write_byte(0x44);//發(fā)送溫度轉(zhuǎn)換命令
- delay_nms(2000);//等待溫度轉(zhuǎn)換完
- reset();
- write_byte(0x55);//發(fā)送匹配ROM號(hào)命令
- for(f=0;f<8;f++) //一個(gè)ROM為8位
- write_byte(ID[num_data][f]);//發(fā)匹配ROM
- delay_nus(100);
- write_byte(0xbe);//發(fā)送讀溫度命令
- delay_nus(100);
- temp_l=read_byte();
- temp_h=read_byte();
- * 函 數(shù) 名 : temp_convert
- * 函數(shù)功能 : 將讀取到的溫度轉(zhuǎn)換
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void temp_convert(void)//溫度轉(zhuǎn)換
- negetiveflag=0; //溫度的符號(hào)標(biāo)志位
- negetiveflag=temp_h&0x80;
- if(negetiveflag) //溫度為負(fù)
- negetiveflag=1; //溫度為負(fù),溫度標(biāo)志位為1
- temp_h=~temp_h;
- if(temp_l==0)
- temp_h++; //若低8位全為0且溫度為負(fù),取補(bǔ)時(shí)就要向高位進(jìn)1
- temp_l=~temp_l+1; //若溫度為負(fù),則求溫度的絕對(duì)值(補(bǔ)碼)
- temp_h<<=4;
- temp_l>>=4; //去除溫度的小數(shù)部分
- temp_over=temp_h|temp_l; //留下8位的溫度整數(shù)部分
- tempalarm=temp_over;
- if(negetiveflag==1)
- tempalarm=tempalarm*(-1);
- * 函 數(shù) 名 : search_cartoon
- * 函數(shù)功能 : 搜索ROM動(dòng)畫(huà)的顯示
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void search_cartoon(void)//搜索ROM動(dòng)畫(huà)
- lcdinit();
- LCD_write_com(0x80);//液晶第一行地址
- for(i=0;i<16;i++)
- LCD_write_data(lcd0[i]); //顯示"SEARCH ROMING..."字符
- LCD_write_com(0xc0);//液晶第二行地址
- for(i=0;i<16;i++)
- LCD_write_data(0xff);//顯示類(lèi)似進(jìn)度條的黑點(diǎn)
- delay_nms(num*80);
- * 函 數(shù) 名 : display_alarm_normal
- * 函數(shù)功能 : 顯示報(bào)警溫度
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void display_alarm_normal(signed char alarm_data)//顯示報(bào)警溫度
- unsigned int data_b,data_temp,l,datx[6]={0};
- data_b=alarm_data;
- negetiveflag=0; //默認(rèn)報(bào)警溫度為正
- for(l=0;l<6;l++)
- LCD_write_data(pointinfo[l]); //顯示"ALARM:"字符
- if(alarm_data>=0)
- data_b=alarm_data/100;//顯示報(bào)警溫度百位
- else
- negetiveflag=1; //報(bào)警溫度為負(fù)
- alarm_data=alarm_data*(-1);//變成正溫度
- data_temp=alarm_data%100;//對(duì)100取余,也就是十位數(shù)和個(gè)位數(shù)
- datx[0]=data_temp/10;//十位
- datx[1]=data_temp%10;//個(gè)位
- datx[2]=13;//空格符號(hào)
- datx[3]=13;//空格符號(hào)
- datx[4]=11;//攝氏度符號(hào)
- datx[5]=12;//攝氏度符號(hào)
- LCD_write_com(0x88);
- LCD_write_data(0x2d);//顯示"-" “負(fù)號(hào)”
- else
- LCD_write_data(lcd4[data_b]);//如果大于0就顯示百位數(shù),否則百位數(shù)就顯示“負(fù)號(hào)”
- for(l=0;l<6;l++)//顯示報(bào)警值和攝氏度符號(hào)
- LCD_write_data(lcd4[datx[l]]);
- * 函 數(shù) 名 : display_total
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void display_total(void) //顯示搜索到的DS18B20傳感器數(shù)目
- lcdinit();
- LCD_write_com(0x80);//第一行地址
- for(i=0;i<14;i++)
- LCD_write_data(lcd1[i]); //顯示"SEARCH ROM OK!"字符
- LCD_write_com(0xc0);//第二行地址
- for(i=0;i<13;i++)
- LCD_write_data(lcd2[i]); //顯示"THE TOTAL IS:"字符
- LCD_write_data(lcd4[num]);
- delay_nms(2000);
- lcdinit(); //清屏,準(zhǔn)備顯示溫度
- display_alarm_normal(alarm);//顯示報(bào)警溫度
- * 函 數(shù) 名 : display_ds18b20
- * 函數(shù)功能 : 顯示編號(hào)為i的DS18B20的溫度
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void display_ds18b20(i)//顯示編號(hào)為i的DS18B20的溫度
- unsigned int data_b,data_temp,l;
- data_b=temp_over/100;//百位
- data_temp=temp_over%100;
- dat[0]=data_temp/10;//十位
- dat[1]=data_temp%10;//個(gè)位
- dat[2]=13; //空格
- dat[3]=13; //空格
- dat[4]=11; //攝氏度符號(hào)
- dat[5]=12; //攝氏度符號(hào)
- for(l=0;l<7;l++)
- LCD_write_data(lcd3[l]); //顯示"NO.[ ]:"字符
- LCD_write_com(0xc4);
- LCD_write_data(lcd4[++i]);// 依次顯示"NO.[ ]:"字符串[ ]里的內(nèi)容12345678
- LCD_write_com(0xc8);
- LCD_write_data(0x2d); //如果溫度為負(fù),顯示“—"負(fù)號(hào)
- else
- LCD_write_data(lcd4[data_b]); //如果溫度為正,顯示溫度百位
- for(l=0;l<6;l++)
- LCD_write_data(lcd4[dat[l]]); //顯示溫度的十位和個(gè)位
- delay_nms(1000);
- * 函數(shù)功能 : 顯示 報(bào)警溫度調(diào)節(jié) 的部分
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void display_alarm(signed char alarm_data)//顯示報(bào)警溫度
- negetiveflag=0;
- if(alarm_data>=0) //報(bào)警溫度大于0
- data_b=alarm_data/100;//百位
- else //報(bào)警溫度小于0
- negetiveflag=1; //溫度符號(hào)標(biāo)志位
- dat[2]=13;//空格符號(hào)
- dat[3]=11;//攝氏度符號(hào)
- dat[4]=12;//攝氏度符號(hào)
- if(keyflag==1)//剛剛進(jìn)入設(shè)置報(bào)警溫度
- lcdinit();
- for(l=0;l<16;l++)
- LCD_write_data(setinfo[l]); //顯示"SET ALARM POINT:"字符
- for(l=0;l<8;l++)
- LCD_write_com(0xc7);
- if(negetiveflag==1) //報(bào)警溫度小于0
- else //報(bào)警溫度大于0
- for(l=0;l<5;l++)//顯示報(bào)警值和攝氏度符號(hào)
- * 函數(shù)功能 : 自動(dòng)搜索ROM
- * 輸 入 : 無(wú)
- * 輸 出 : 無(wú)
- void search_rom(void)//搜索ROM
- unsigned char k=0,l=0,chongtuwei=0,m=0,n=0;
- unsigned char s=0;
- unsigned char zhan[MAXNUM];
- unsigned char ss[64]; //用來(lái)存放ROM,共m=8行,n=8列,一個(gè)RONM存放一行(即8位)
- do
- reset();
- write_byte(0xf0); //發(fā)送搜索ROM命令
- for(m=0;m<8;m++) //
- for(n=0;n<8;n++)
- k=read_2bit();//讀兩位數(shù)據(jù)
- k=k&0x03;
- s>>=1;
- if(k==0x01)//01 有器件相連,在此為數(shù)據(jù)為上它們的數(shù)據(jù)為0
- write_bit (0);
- ss[(m*8+n)]=0;
- else if(k==0x02)//01 有器件相連,在此為數(shù)據(jù)為上它們的數(shù)據(jù)為1
- s=s|0x80;
- write_bit (1);
- ss[(m*8+n)]=1;
- else if(k==0x00)//00 有器件相連,在此為數(shù)據(jù)為上它們的數(shù)據(jù)發(fā)送沖突即就有1也有0
- { //如果沖突位大于棧頂寫(xiě)0 小于棧頂寫(xiě)以前數(shù)據(jù) 等于棧頂寫(xiě)1
- chongtuwei=m*8+n+1;
- if(chongtuwei>zhan[l])
- write_bit (0);
- ss[(m*8+n)]=0;
- zhan[++l]=chongtuwei;
- else if(chongtuwei<zhan[l])
- s=s|((ss[(m*8+n)]&0x01)<<7);
- write_bit (ss[(m*8+n)]);
- else if(chongtuwei==zhan[l])
- s=s|0x80;
- write_bit (1);
- ss[(m*8+n)]=1;
- l=l-1;
- else
- goto loop;
- ID[num][m]=s;
- num++;
- while(zhan[l]!=0&&(num<MAXNUM));
- loop:
- search_cartoon();
- display_total();
- void main (void)
- unsigned char i=0,t=0;
- delay_nms(50);
- IT0=0;
- EX0=1;
- EA=1;
- search_rom();//搜索ROM并且存儲(chǔ),把18B20的每一個(gè)ROM讀取出來(lái),方便下次調(diào)用
- reset();
- while(1)
- if(keyflag==0)
- for(i=0;i<num;i++) //每一個(gè) ds18b20 循環(huán)顯示
- if(keyflag==1) break;
- read_temp(i); //讀編號(hào) i 的ds18b20 的溫度
- temp_convert(); //調(diào)用溫度轉(zhuǎn)換
- if(tempalarm>alarm)//報(bào)警判斷
- for(t=0;t<3;t++)
- buzzer=0;//打開(kāi)報(bào)警蜂鳴器
- led=0; //打開(kāi)報(bào)警指示燈
- delay_nms(100);
- buzzer=1;//關(guān)閉報(bào)警蜂鳴器
- led=1; //關(guān)閉報(bào)警指示燈
- delay_nms(100);
- display_ds18b20(i);//顯示 編號(hào) i 的溫度
- else//設(shè)置按鍵按下 進(jìn)行按鍵掃描動(dòng)作
- display_alarm(alarm);
- keyflag=0;
- while(1)
- if(keyenter==0&&keyflag==0)//進(jìn)入設(shè)置以后,再按設(shè)置按鍵,就退出設(shè)置,重新顯示每一個(gè)通道溫度
- delay_nms(200);
- if(keyenter==0)
- while(keyenter==0);
- lcdinit();
- break;//退出按鍵掃描
- if(keyup==0)//
- delay_nms(200);
- if(keyup==0&&alarm<125)
- alarm++;//報(bào)警溫度加1
- if(keydown==0&&alarm>-55)//
- delay_nms(200);
- if(keydown==0)
- alarm--;//報(bào)警溫度減1
- delay_nms(50);
- EX0=1;
- }//while(1)結(jié)束
- void key_init0(void) interrupt 0
- if(keyenter==0)
- delay_nms(10);
- if(keyenter==0)
- EX0=0;
- keyflag=1;
仿真文件.zip
(49.24 KB, 下載次數(shù): 142)
2019-3-15 10:06 上傳
點(diǎn)擊文件名下載附件
仿真圖
程序.doc
(61.5 KB, 下載次數(shù): 80)
2019-3-15 10:06 上傳
點(diǎn)擊文件名下載附件
51程序
