查看: 2756|回復(fù): 1
有STC8A8K64S4A12單片機呼吸燈程序嗎 求幫助
ID:490151 發(fā)表于 2019-3-17 16:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
ID:155507 發(fā)表于 2019-4-6 22:17 | 只看該作者
我給你來個程序試試
  1. //STC8A8K64S4A12單片機呼吸燈程序
  2. #include "reg51.h"
  3. #include "intrins.h"
  4. //測試工作頻率為11.0592MHz
  5. #define CYCLE           0x1000
  6. sfr     P_SW2       =   0xba;
  7. sfr     PWMCFG      =   0xf1;
  8. sfr     PWMIF       =   0xf6;
  9. sfr     PWMFDCR     =   0xf7;
  10. sfr     PWMCR       =   0xfe;
  11. #define PWMC            (*(unsigned int volatile xdata *)0xfff0)
  12. #define PWMCKS          (*(unsigned char volatile xdata *)0xfff2)
  13. #define TADCP           (*(unsigned int volatile xdata *)0xfff3)
  14. #define PWM0T1          (*(unsigned int volatile xdata *)0xff00)
  15. #define PWM0T2          (*(unsigned int volatile xdata *)0xff02)
  16. #define PWM0CR          (*(unsigned char volatile xdata *)0xff04)
  17. #define PWM0HLD         (*(unsigned char volatile xdata *)0xff05)
  18. #define PWM1T1          (*(unsigned int volatile xdata *)0xff10)
  19. #define PWM1T2          (*(unsigned int volatile xdata *)0xff12)
  20. #define PWM1CR          (*(unsigned char volatile xdata *)0xff14)
  21. #define PWM1HLD         (*(unsigned char volatile xdata *)0xff15)
  22. #define PWM2T1          (*(unsigned int volatile xdata *)0xff20)
  23. #define PWM2T2          (*(unsigned int volatile xdata *)0xff22)
  24. #define PWM2CR          (*(unsigned char volatile xdata *)0xff24)
  25. #define PWM2HLD         (*(unsigned char volatile xdata *)0xff25)
  26. #define PWM3T1          (*(unsigned int volatile xdata *)0xff30)
  27. #define PWM3T2          (*(unsigned int volatile xdata *)0xff32)
  28. #define PWM3CR          (*(unsigned char volatile xdata *)0xff34)
  29. #define PWM3HLD         (*(unsigned char volatile xdata *)0xff35)
  30. #define PWM4T1          (*(unsigned int volatile xdata *)0xff40)
  31. #define PWM4T2          (*(unsigned int volatile xdata *)0xff42)
  32. #define PWM4CR          (*(unsigned char volatile xdata *)0xff44)
  33. #define PWM4HLD         (*(unsigned char volatile xdata *)0xff45)
  34. #define PWM5T1          (*(unsigned int volatile xdata *)0xff50)
  35. #define PWM5T2          (*(unsigned int volatile xdata *)0xff52)
  36. #define PWM5CR          (*(unsigned char volatile xdata *)0xff54)
  37. #define PWM5HLD         (*(unsigned char volatile xdata *)0xff55)
  38. #define PWM6T1          (*(unsigned int volatile xdata *)0xff60)
  39. #define PWM6T2          (*(unsigned int volatile xdata *)0xff62)
  40. #define PWM6CR          (*(unsigned char volatile xdata *)0xff64)
  41. #define PWM6HLD         (*(unsigned char volatile xdata *)0xff65)
  42. #define PWM7T1          (*(unsigned int volatile xdata *)0xff70)
  43. #define PWM7T2          (*(unsigned int volatile xdata *)0xff72)
  44. #define PWM7CR          (*(unsigned char volatile xdata *)0xff74)
  45. #define PWM7HLD         (*(unsigned char volatile xdata *)0xff75)
  46. void PWM_Isr() interrupt 22
  47. {
  48.     static bit dir = 1;
  49.     static int val = 0;
  50.     if (PWMCFG & 0x80)
  51.     {
  52.         PWMCFG &= ~0x80;                        //清中斷標志
  53.         if (dir)
  54.         {
  55.             val++;
  56.             if (val >= CYCLE) dir = 0;
  57.         }
  58.         else
  59.         {
  60.             val--;
  61.             if (val <= 1) dir = 1;
  62.         }
  63.         _push_(P_SW2);
  64.         P_SW2 |= 0x80;
  65.         PWM0T2 = val;
  66.         _pop_(P_SW2);
  67.     }
  68. }
  69. void main()
  70. {
  71.     P_SW2 = 0x80;
  72.     PWMCKS = 0x00;                              // PWM時鐘為系統(tǒng)時鐘
  73.     PWMC = CYCLE;                               //設(shè)置PWM周期為
  74.     PWM0T1= 0x0000;
  75.     PWM0T2= 0x0001;
  76.     PWM0CR= 0x80;                               //使能PWM0/P2.0輸出
  77.     P_SW2 = 0x00;
  78.     PWMCR = 0xc0;                               //啟動PWM模塊
  79.     EA = 1;
  80.     while (1);
  81. }
