查看: 3961|回復(fù): 2
單片機(jī)超聲波智能小車程序里這一大串_nop_();什么意思?
         void  StartModule()                       //啟動(dòng)測(cè)距信號(hào)
          TRIG=1;
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TRIG=0;
這個(gè)nop_是什么意思??
51單片機(jī)超聲波智能小車程序:
  1.         #include<AT89x51.H>
  2.         #include <intrins.h>
  3.         #define Sevro_moto_pwm     P2_0  //接舵機(jī)信號(hào)端輸入PWM信號(hào)調(diào)節(jié)速度
  4.         sbit led1    =P2^4;
  5.     sbit led2    =P2^5;
  6.     sbit led3    =P2^6;
  7.     sbit led4    =P2^7;
  8.         #define  ECHO  P1_1                                   //超聲波接口定義
  9.         #define  TRIG  P1_2                           //超聲波接口定義
  10.           bit      flag =0;
  11.         #define moto_go      {P3_0=1,P3_1=0,P3_2=1,P3_3=0;}    //左邊兩個(gè)電機(jī)向前走
  12.         #define moto_back    {P3_0=0,P3_1=1,P3_2=0,P3_3=1;}         //左邊兩個(gè)電機(jī)向后轉(zhuǎn)
  13.         #define moto_Stop    {P3_0=0,P3_1=0,P3_2=0,P3_3=0;}    //左邊兩個(gè)電機(jī)停轉(zhuǎn)
  14.         #define moto_R       {P3_0=1,P3_1=0,P3_2=0,P3_3=1;}        //右邊兩個(gè)電機(jī)向前走
  15.         #define moto_L       {P3_0=0,P3_1=1,P3_2=1,P3_3=0;}        //右邊兩個(gè)電機(jī)向前走
  16.         unsigned char const discode[] ={0x03,0x9F,0x25,0x0D,0x99,0x49,0x41,0x1F,0x01,0x09,0x11,0xC1,0x63,0x85,0x61,0x71,0x03,0x9F,0x25,0x0D
  17.                                     }; //0,1,2,3,4....F,0,1,2,3的段碼
  18.
  19.     unsigned char LedBuff[4]={        0xFF, 0xFF, 0x03, 0x03        };
  20.     unsigned char posit=0;
  21.            unsigned char pwm_val_left  = 0;//變量定義
  22.         unsigned char push_val_left =14;//舵機(jī)歸中,產(chǎn)生約,1.5MS 信號(hào)
  23.     unsigned long S=0;
  24.         unsigned long S1=0;
  25.         unsigned long S2=0;
  26.         unsigned long S3=0;
  27.         unsigned long S4=0;
  28.         unsigned int  time=0;                    //時(shí)間變量
  29.         unsigned int  timer=0;                        //延時(shí)基準(zhǔn)變量
  30.         unsigned char timer1=0;                        //掃描時(shí)間變量
  31. /************************************************************************/
  32.                 void delay(unsigned int k)          //延時(shí)函數(shù)
  33. {
  34.      unsigned int x,y;
  35.            for(x=0;x<k;x++)
  36.              for(y=0;y<2000;y++);
  37. }
  38. /************************************************************************/
  39.     void Display(void)                                  //掃描數(shù)碼管
  40.         {
  41.         static unsigned char i = 0;
  42.         P0 = 0xFF;
  43.         switch(i)
  44.         {
  45.                 case 0: led1 = 0; led4 = 1; i++; P0=LedBuff[0];break;
  46.                 case 1: led2 = 0; led1 = 1; i++; P0=LedBuff[1];break;
  47.                 case 2: led3 = 0; led2 = 1; i++; P0=LedBuff[2];break;
  48.                 case 3: led4 = 0; led3 = 1; i = 0; P0=LedBuff[3];break;
  49.                 default:break;
  50.         }
  51.         }
  52. /************************************************************************/
  53.      void  StartModule()                       //啟動(dòng)測(cè)距信號(hào)
  54.    {
  55.           TRIG=1;
  56.           _nop_();
  57.           _nop_();
  58.           _nop_();
  59.           _nop_();
  60.           _nop_();
  61.           _nop_();
  62.           _nop_();
  63.           _nop_();
  64.           _nop_();
  65.           _nop_();
  66.           _nop_();
  67.           _nop_();
  68.           _nop_();
  69.           _nop_();
  70.           _nop_();
  71.           _nop_();
  72.           _nop_();
  73.           _nop_();
  74.           _nop_();
  75.           _nop_();
  76.           _nop_();
  77.           TRIG=0;
  78.    }
  79. /***************************************************/
  80.           void Conut(void)                   //計(jì)算距離
  81.         {
  82.           while(!ECHO);                       //當(dāng)RX為零時(shí)等待
  83.           TR0=1;                               //開啟計(jì)數(shù)
  84.           while(ECHO);                           //當(dāng)RX為1計(jì)數(shù)并等待
  85.           TR0=0;                                   //關(guān)閉計(jì)數(shù)
  86.           time=TH0*256+TL0;                   //讀取脈寬長(zhǎng)度
  87.           TH0=0;
  88.           TL0=0;
  89.           S=(time*1.7)/100;     //算出來是CM
  90.         if((S>=700)||flag==1) //超出測(cè)量范圍顯示“F”
  91.          {
  92.            flag=0;
  93.            S=0;
  94.            LedBuff[3] = discode[15];
  95.            LedBuff[2] = discode[15];
  96.            LedBuff[1] = discode[15];
  97.
  98.          }
  99.          else
  100.          {
  101.            LedBuff[3] = discode[S%10];
  102.            LedBuff[2] = discode[S/10%10];
  103.            LedBuff[1] = discode[S/100%10];
  104.          }
  105.         }
  106. /************************************************************************/
  107. //前速前進(jìn)
  108.      void  run(void)
  109. {
  110.          moto_go ;     //左電機(jī)往前走
  111.
  112. }
  113. /************************************************************************/
  114. //前速后退
  115.      void  backrun(void)
  116. {
  117.          moto_back ;
  118.
  119. }
  120. /************************************************************************/
  121. //左轉(zhuǎn)
  122.      void  leftrun(void)
  123. {
  124.          moto_L ;
  125. }
  126. /************************************************************************/
  127. //右轉(zhuǎn)
  128.      void  rightrun(void)
  129. {
  130.          moto_R ;
  131.
  132. }
  133. /************************************************************************/
  134. //STOP
  135.      void  stoprun(void)
  136. {
  137.          moto_Stop ;
  138. }
  139. /************************************************************************/
  140. void  COMM( void )
  141.   {
  142.
  143.
  144.                   push_val_left=7;          //舵機(jī)向左轉(zhuǎn)90度
  145.                   timer=0;
  146.                   while(timer<=4000); //延時(shí)400MS讓舵機(jī)轉(zhuǎn)到其位置
  147.                   StartModule();          //啟動(dòng)超聲波測(cè)距
  148.           Conut();                           //計(jì)算距離
  149.                   S2=S;
  150.                   push_val_left=17;          //舵機(jī)向右轉(zhuǎn)90度
  151.                   timer=0;
  152.                   while(timer<=4000); //延時(shí)400MS讓舵機(jī)轉(zhuǎn)到其位置
  153.                   StartModule();          //啟動(dòng)超聲波測(cè)距
  154.           Conut();                          //計(jì)算距離
  155.                   S4=S;
  156.
  157.                   push_val_left=12;          //舵機(jī)歸中
  158.                   timer=0;
  159.                   while(timer<=4000); //延時(shí)400MS讓舵機(jī)轉(zhuǎn)到其位置
  160.                   StartModule();          //啟動(dòng)超聲波測(cè)距
  161.           Conut();                          //計(jì)算距離
  162.                   S1=S;
  163.            if((S2>25)&&(S4>25)&&(S1>60)) //只要左右各有距離小于,20CM小車后退
  164.                   {
  165.                 goto  AA;
  166.                             }
  167.
  168.                   if((S2<20)||(S4<20)) //只要左右各有距離小于,20CM小車后退
  169.                   {
  170.                   backrun();                   //后退
  171.                   timer=0;
  172.                   while(timer<=2000);
  173.                     stoprun();
  174.                         timer=0;
  175.                   while(timer<=1000);
  176.                           if(S2>S4)
  177.                      {
  178.                                 rightrun();          //車的左邊比車的右邊距離小        右轉(zhuǎn)
  179.                         timer=0;
  180.                         while(timer<=1000);
  181.                      }
  182.                        else
  183.                      {
  184.                        leftrun();                //車的左邊比車的右邊距離大        左轉(zhuǎn)
  185.                        timer=0;
  186.                        while(timer<=1000);
  187.                      }
  188.                   }
  189.                     else
  190.                         {
  191.                   if(S2>S4)
  192.                      {
  193.                                 rightrun();          //車的左邊比車的右邊距離小        右轉(zhuǎn)
  194.                         timer=0;
  195.                         while(timer<=1600);
  196.                      }
  197.                        else
  198.                      {
  199.                        leftrun();                //車的左邊比車的右邊距離大        左轉(zhuǎn)
  200.                        timer=0;
  201.                        while(timer<=1600);
  202.                      }
  203.
  204. }
  205.    AA:  run();
  206.         }
  207. /************************************************************************/
  208. /*                    PWM調(diào)制電機(jī)轉(zhuǎn)速                                   */
  209. /************************************************************************/
  210. /*                    左電機(jī)調(diào)速                                        */
  211. /*調(diào)節(jié)push_val_left的值改變電機(jī)轉(zhuǎn)速,占空比            */
  212. void pwm_Servomoto(void)
  213. {
  214.     pwm_val_left++;
  215.     if(pwm_val_left<=push_val_left)
  216.                Sevro_moto_pwm=1;
  217.         else
  218.                Sevro_moto_pwm=0;
  219.         if(pwm_val_left>=200)
  220.         pwm_val_left=0;
  221. }
  222. /***************************************************/
  223. ///*TIMER1中斷服務(wù)子函數(shù)產(chǎn)生PWM信號(hào)*/
  224.         void time1()interrupt 3            using 2
  225. {
  226.      TH1=(65536-100)/256;          //0.1MS定時(shí)
  227.          TL1=(65536-100)%256;
  228.          timer++;                                  //定時(shí)器0.1MS為準(zhǔn)。在這個(gè)基礎(chǔ)上延時(shí)
  229.          pwm_Servomoto();
  230.          timer1++;                                 //2MS掃一次數(shù)碼管
  231.          if(timer1>=20)
  232.          {
  233.          timer1=0;
  234.          Display();
  235.          }
  236.
  237. }
  238. /***************************************************/
  239. ///*TIMER0中斷服務(wù)子函數(shù)產(chǎn)生PWM信號(hào)*/
  240.         void timer0()interrupt 1             using 0
  241. {
  242.    flag=1;
  243.    StartModule();
  244. }
  245. /***************************************************/
  246.         void main(void)
  247. {
  248.         TMOD=0X11;
  249.         TH1=(65536-100)/256;          //100US定時(shí)
  250.         TL1=(65536-100)%256;
  251.         TH0=0;
  252.         TL0=0;
  253.         TR1= 1;
  254.         ET1= 1;
  255.         ET0= 1;
  256.         EA = 1;
  257.         delay(100);
  258.     push_val_left=14;          //舵機(jī)歸中
  259.         while(1)                       /*無限循環(huán)*/
  260.         {
  261.          if(timer>=1000)          //100MS檢測(cè)啟動(dòng)檢測(cè)一次
  262.            {
  263.                timer=0;
  264.                    StartModule(); //啟動(dòng)檢測(cè)
  265.            Conut();                  //計(jì)算距離
  266.            if(S<30)                  //距離小于20CM
  267.                    {
  268.                    StartModule(); //啟動(dòng)檢測(cè)
  269.            Conut();                  //計(jì)算距離
  270.            if(S<30)                  //距離小于20CM
  271.                         {
  272.                    stoprun();          //小車停止
  273.                    COMM();                   //方向函數(shù)
  274.                    }
  275.                    }
  276.                    else
  277.                    if(S>40)                  //距離大于,30CM往前走
  278.                    run();
  279.            }
  280.         }
  281. }
  282.
ID:234075 發(fā)表于 2019-3-23 01:11 | 只看該作者
_nop_();是一個(gè)空語句子函數(shù),包含在"intrins.h"頭文件中(如果使用這個(gè)子函數(shù),則必須在前面使用“#include"intrins.h"對(duì)頭文件進(jìn)行聲明”);
常用于延時(shí),在C51中,如果晶振主頻=12MHZ,運(yùn)行一次_nop_();相當(dāng)于1us的延時(shí);
ID:164602 發(fā)表于 2019-3-23 14:11 | 只看該作者
HC-HR04超聲波測(cè)距模塊的使用手冊(cè)上說:
所以,發(fā)波時(shí)就要讓控制口保持10us以上的高電平,你的程序多了幾個(gè)us,也是沒問題的。
這個(gè)_nop_()函數(shù),就叫空指令,即什么事兒都不干,相當(dāng)于延時(shí)了。
它延時(shí)的時(shí)間,就是一個(gè)同期,對(duì)51單片機(jī)、12M晶振而,一個(gè)_nop_()函數(shù),正好一個(gè)us。
