本帖最后由 mp3 于 2019-3-25 08:48 編輯
只在STC11F04E單片機(jī)上試用過,其它型號(hào)可能要修改通信協(xié)議,可通過串口監(jiān)控工具分析。
單片機(jī)脫機(jī)燒錄源程序如下:
- #include <stdio.h>
- #include <unistd.h>
- #include <stdlib.h>
- #include <sys/types.h>
- #include <sys/stat.h>
- #include <fcntl.h>
- #include <termios.h>
- #include <sys/ioctl.h>
- #include <string.h>
- #include <arpa/inet.h>
- #include <sys/time.h>
- #include <ctype.h>
- #pragma pack(1)
- // config MCU clock
- #define MCU_CONFIG
- //#define MCU_6TO6
- //#define MCU_6TO12
- //#define MCU_12TO12
- //#define MCU_12TO6
- #ifdef MCU_6TO6
- #define MCU_CLOCK
- #endif
- #ifdef MCU_6TO12
- #define MCU_CLOCK
- #endif
- #ifdef MCU_12TO12
- #define MCU_CLOCK
- #define MCU_CLOCK_12MHZ
- #undef MCU_CONFIG
- #endif
- #ifdef MCU_12TO6
- #define MCU_CLOCK
- #endif
- #ifndef MCU_CLOCK
- #error "You must define MCU clock!"
- #endif
- #define VERSION "0.1"
- #define DEFAULT_PORT "/dev/ttyS1"
- #define LOW_BAUD B2400
- #ifdef MCU_CLOCK_12MHZ
- #define HIGH_BAUD B57600
- #define MSG_HIGH_BAUD "57600bps"
- #else
- #define HIGH_BAUD B38400
- #define MSG_HIGH_BAUD "38400bps"
- #endif
- #define BUFFSIZE 1024
- #define TIMEOUT 2
- #define BLOCK_SIZE 128
- #define PKG_MINIMAL_LEN 9
- #define PKG_SIGN1 '\x46'
- #define PKG_SIGN2 '\xb9'
- #define PKG_SIGN3 '\x16'
- #define PKG_SIGN 0x46b9
- enum pkg_type {
- PKG_TYPE1=0x68,
- PKG_TYPE2=0x6a,
- enum pkg_code {
- CODE_INFO=0x50,
- CODE_MODI=0x8f,
- CODE_NEWB=0x8e,
- CODE_ERASE=0x84,
- CODE_DATA=0x00,
- CODE_END =0x69,
- CODE_CONF=0x8d,
- CODE_BYE =0x82,
- int port_fd=-1;
- FILE *rom_file;
- int file_length;
- int debug=0;
- enum pkg_code step;
- int block_no;
- struct timeval start_tv;
- typedef unsigned int uint32;
- typedef unsigned short int uint16;
- typedef unsigned char uint8;
- // Package format: head + data + tail
- typedef struct _pkg_head {
- uint16 sign; // 0x46b9
- uint8 type; // 68: MCU to PC; 6a: PC to MCU
- uint16 lenth; // from 'type' to 'pkg_tail.sign'
- uint8 code;
- } pkg_head, *ppkg_head;
- typedef struct _pkg_tail {
- uint16 cksum; // from 'pkg_head.type' to 'data'
- uint8 sign; // 0x16
- } pkg_tail, *ppkg_tail;
- typedef struct _pkg_data_head {
- uint16 dummy; // always 0x0000
- uint16 addr; // start addr
- uint16 lenth; // 0x0080
- } pkg_data_head, *ppkg_data_head;
- void print_data(char *data, int len)
- unsigned char ch;
- int i, j;
- printf("Length: %x\n", len);
- for(i=0; i<len; i++) {
- ch=data[i];
- if((i&0x0f)==0)
- printf("%04x: ", i);
- if((i&0x07)!=0x07)
- printf("%02x ", ch);
- else
- if((i&0x0f)!=0x0f)
- printf("%02x-", ch);
- else {
- for(j=0x0f; j>=0; j--) {
- ch=data[i-j];
- if(!isascii(ch) || iscntrl(ch))
- ch='.';
- putchar(ch);
- putchar('\n');
- if(len&0x0f) {
- for(; i<(len&~0x0f)+0x10; i++)
- printf(" ");
- putchar(' ');
- for(j=len&~0x0f; j<len; j++) {
- ch=data[j];
- ch='.';
- putchar(ch);
- putchar('\n');
- enum dbg_type {RECV, SEND};
- void print_dbg(int type, char *buf, int buf_len)
- struct timeval tv;
- unsigned int sec, usec;
- if(debug) {
- if(type==SEND)
- printf("\n[Send]\t\t");
- else
- printf("\n[Received]\t");
- gettimeofday(&tv, NULL);
- if(start_tv.tv_usec>tv.tv_usec) {
- usec=tv.tv_usec-start_tv.tv_usec+1000000;
- sec=tv.tv_sec-start_tv.tv_sec-1;
- } else {
- usec=tv.tv_usec-start_tv.tv_usec;
- sec=tv.tv_sec-start_tv.tv_sec;
- printf("[%d.%06d]\n", sec, usec);
- printf("Step: %02x\t", step);
- print_data(buf, buf_len);
- int checksum(char *buf, int buf_len)
- int i, sum=0;
- for(i=0; i<buf_len; i++)
- sum+=(unsigned char)buf[i];
- return sum;
- // return: -1: bad pkg; >=0: pkg start position
- int check_pkg(int code, char *buf, int buf_len)
- int i, len;
- ppkg_head ph=NULL;
- ppkg_tail pt=NULL;
- for(i=0; i<buf_len; i++) {
- if(buf[i]==PKG_SIGN1 && buf[i+1]==PKG_SIGN2 && i+PKG_MINIMAL_LEN<=buf_len) {
- ph=(ppkg_head)buf+i;
- if(ph->type==PKG_TYPE1 && ph->code==code) {
- len=ntohs(ph->lenth);
- pt=(ppkg_tail)((char *)ph+len-1);
- if(pt->sign==PKG_SIGN3 && ntohs(pt->cksum)==checksum((char *)ph+2, len-3)) break;
- pt=NULL;
- break;
- if(ph==NULL || pt==NULL)
- i=-1;
- return i;
- typedef struct port_info {
- int port_fd;
- int baud_rate;
- char parity;
- char stop_bit;
- char flow_ctrl;
- char data_bits;
- } *pport_info;
- int set_port(pport_info p_info)
- struct termios old_opt,new_opt;
- memset(&old_opt,0,sizeof(old_opt));
- memset(&new_opt,0,sizeof(new_opt));
- cfmakeraw(&new_opt);
- tcgetattr(p_info->port_fd,&old_opt);
- //修改new_opt結(jié)構(gòu)中的串口輸入/輸出波特率參數(shù)
- cfsetispeed(&new_opt,p_info->baud_rate);
- cfsetospeed(&new_opt,p_info->baud_rate);
- //修改控制模式,保證程序不會(huì)占用串口
- new_opt.c_cflag |=CLOCAL;
- //修改控制模式,使得能夠從串口中讀取輸入數(shù)據(jù)
- new_opt.c_cflag |=CREAD;
- /*===========設(shè)置數(shù)據(jù)流控制==========*/
- switch(p_info->flow_ctrl){
- case '0':
- //不使用流控制
- new_opt.c_cflag &=~CRTSCTS;
- break;
- case '1':
- //使用硬件進(jìn)行流控制
- new_opt.c_cflag |=CRTSCTS;
- break;
- case '2':
- new_opt.c_cflag |= IXON | IXOFF | IXANY;
- break;
- /*===========設(shè)置數(shù)據(jù)位============*/
- new_opt.c_cflag &=~CSIZE;
- switch(p_info->data_bits){
- case '5':
- new_opt.c_cflag |=CS5;
- break;
- case '6':
- new_opt.c_cflag |=CS6;
- break;
- case '7':
- new_opt.c_cflag |=CS7;
- break;
- case '8':
- new_opt.c_cflag |=CS8;
- break;
- default:
- /*===========設(shè)置奇偶效驗(yàn)位==========*/
- switch(p_info->parity){
- case '0': //不使用奇偶效驗(yàn)
- new_opt.c_cflag &=~PARENB;
- break;
- case '1': //使用偶效驗(yàn)
- new_opt.c_cflag |=PARENB;
- new_opt.c_cflag &=~PARODD;
- break;
- case '2': //使用奇效驗(yàn)
- new_opt.c_cflag |=PARODD;
- break;
- /*============設(shè)置停止位===========*/
- if(p_info->stop_bit=='2')
- new_opt.c_cflag |=CSTOPB;
- else
- new_opt.c_cflag &=~CSTOPB;
- //修改輸出模式,原始數(shù)據(jù)輸出
- new_opt.c_oflag &=~OPOST;
- //修改控制字符,讀取字符的最少個(gè)數(shù)為1
- new_opt.c_cc[VMIN]=1;
- //修改控制字符,讀取第一個(gè)字符等待1*(1/10)s
- new_opt.c_cc[VTIME]=1;
- //如果發(fā)生數(shù)據(jù)溢出,接收數(shù)據(jù),但是不再讀取
- tcflush(p_info->port_fd,TCIFLUSH);
- int result=tcsetattr(p_info->port_fd,TCSANOW,&new_opt);
- if(result==-1){
- perror("Cannot set the serial port parameters");
- return -1;
- return result;
- int open_port(char *port_name, int baud_rate)
- int port_fd;
- if((port_fd=open(port_name, O_RDWR | O_NOCTTY | O_NONBLOCK))==-1){
- fprintf(stderr, "Failed to open serial port: %s\n", port_name);
- return -1;
- //設(shè)置串口通信參數(shù)
- struct port_info info;
- info.port_fd=port_fd;
- info.baud_rate=baud_rate;
- info.data_bits='8';
- info.flow_ctrl='0';
- info.stop_bit='1';
- info.parity='1';
- if(set_port(&info)==-1) {
- fprintf(stderr, "Failed to setup serial port: %s\n", port_name);
- close(port_fd);
- return -1;
- return port_fd;
- void close_port()
- if(rom_file!=NULL) {
- fclose(rom_file);
- rom_file=NULL;
- if(port_fd!=-1) {
- close(port_fd);
- port_fd=-1;
- void reopen_port(char *port_name, int baud_rate)
- if(port_fd!=-1)
- close(port_fd);
- if((port_fd=open_port(port_name, baud_rate))==-1)
- close_port();
- exit(1);
- int send_data(int fd, char *data, int data_len)
- int len=write(fd, data, data_len);
- //如果出現(xiàn)溢出的情況
- if(len!=data_len)
- tcflush(fd, TCOFLUSH);
- return len;
- int send_mcu(int fd, char *data, int data_len)
- int i, len=0, total=0;
- for(i=0; i<data_len; i++) {
- usleep(150);
- len=send_data(fd,data+i,1);
- if(len>0)
- total+=len;
- print_dbg(SEND, data, total);
- return total;
- int recv_data(int fd, char *data, int data_len)
- static int timeout=0;
- int len=0, fs_sel;
- fd_set fs_read;
- struct timeval time;
- FD_ZERO(&fs_read);
- FD_SET(fd, &fs_read);
- if(step==CODE_MODI)
- timeout=TIMEOUT;
- time.tv_sec=timeout;
- time.tv_usec=10000;
- //使用select實(shí)現(xiàn)串口的多路通信
- fs_sel=select(fd+1, &fs_read, NULL, NULL, &time);
- if(fs_sel)
- len=read(fd, data, data_len);
- return len;
- int recv_mcu(int fd, char *buf, int buf_len)
- int i, len=0;
- do {
- if(step==CODE_INFO)
- usleep(100000);
- i=recv_data(fd, buf+len, buf_len-len);
- if(i>0) len+=i;
- if(check_pkg(step, buf, len)>=0)
- break;
- } while(i>0);
- return len;
- int check_recv(int expect_code, char *buf, int buf_len) {
- int i;
- print_dbg(RECV, buf, buf_len);
- i=check_pkg(expect_code, buf, buf_len);
- if(i<0) {
- printf("\nError received data\n");
- close_port();
- exit(1);
- return i;
- void mcu_info(char *buf, int buf_len) {
- int i, len;
- ppkg_head ph;
- ppkg_tail pt;
- ph=(ppkg_head)buf;
- MCU Type is: STC11F04E
- MCU Firmware Version: 6.5K
- Next Power-Up-Reset, use External Crystal/Clock
- RESET/P3.6 is used as RESET
- Power-Up Reset,add extra Reset-Delay-Time
- Oscillator Gain: High gain
- P1.0/P1.1 are not related to STC ISP Programming
- Next ISP Programming Code,don't erase EEPROM data
- Wait n clocks after MCU is waked up: 32768
- Low Voltage Reset, when MCU-VCC < 4.1V
- WDT_CONTR be write-protected except CLR_WDT:NO
- WDT is enabled automatically during power-up:NO
- Stop WatchDog Timer counting in Idle mode: YES
- Pre-scale time of WDT(did not start): 256
- MCU Clock:12.019038MHz.
- i=sizeof(pkg_head)+16;
- printf("\n\nMCU Type: \n");
- printf("MCU Firmware Version: %1d.%1d%c\n", buf[i]>>4&0x0f, buf[i]&0x0f, buf[i+1]);
- i=ntohl(*((int *)((char *)pt-4)));
- printf("MCU Internal Clock: %2d.%6dMhz\n", i/1000000, i%1000000);
- //return: pkg length
- int make_pkg(int code, char *inbuf, int ibuf_len, char *outbuf, int obuf_len)
- int i, len;
- ppkg_head ph;
- ppkg_tail pt;
- ppkg_data_head pd;
- static char request_mcu[]={
- 0x46,0xB9,0x6A,0x00,0x0D,0x50,0x09,0x00,0x36,0x01,0xE2,0x24,0x02,0x0D,0x16};
- static char erase[]={
- 0x46,0xB9,0x6A,0x00,0x8C,0x84,0xFF,0x00,0x02,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- static char end[]={
- 0x46,0xB9,0x6A,0x00,0x0D,0x69,0x09,0x00,0x36,0x01,0xE2,0x24,0x02,0x26,0x16};
- static char bye[]={
- 0xFE,0xFE,0xFE,0xFE,0x46,0xB9,0x6A,0x00,0x07,0x82,0x00,0xF3,0x16};
- /* 38400bps @ 6.2MHz, internal clock */
- #ifdef MCU_6TO6
- static char inform_change[]={
- 0x46,0xB9,0x6A,0x00,0x0D,0x8F,0xC0,0xF6,0x3F,0x14,0x2D,0x84,0x03,0xC0,0x16};
- static char confirm_newrate[]={
- 0x46,0xB9,0x6A,0x00,0x0C,0x8E,0xC0,0xF6,0x3F,0x14,0x2D,0x03,0x3A,0x16};
- static char config[]={
- 0x46,0xB9,0x6A,0x00,0x1B,0x8D,0xBF,0x7D,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x5E,0x90,0x04,0x11,0x2A,0x16};
- #endif
- /* 38400bps @ 6.2MHz, change 6.2MHz to 12MHz */
- #ifdef MCU_6TO12
- 0x46,0xB9,0x6A,0x00,0x1B,0x8D,0xBF,0x7F,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x5E,0x27,0x41,0x11,0x00,0x16};
- #endif
- /* 57600bps @ 12MHz, change back to 6.2MHz if run conf_mcu() */
- 0x46,0xB9,0x6A,0x00,0x0D,0x8F,0xC0,0xF3,0x3F,0x1A,0x2D,0x83,0x03,0xC2,0x16};
- 0x46,0xB9,0x6A,0x00,0x0C,0x8E,0xC0,0xF3,0x3F,0x1A,0x2D,0x03,0x3D,0x16};
- 0x46,0xB9,0x6A,0x00,0x1B,0x8D,0xBF,0x7D,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xB7,0x65,0x5E,0x11,0xB2,0x16};
- #endif
- switch(code) {
- case CODE_INFO:
- len=sizeof(request_mcu);
- memcpy(outbuf, request_mcu, len);
- break;
- case CODE_MODI:
- len=sizeof(inform_change);
- memcpy(outbuf, inform_change, len);
- break;
- case CODE_NEWB:
- len=sizeof(confirm_newrate);
- memcpy(outbuf, confirm_newrate, len);
- break;
- case CODE_ERASE:
- len=sizeof(erase);
- memcpy(outbuf, erase, len);
- *(short int *)(outbuf+7)=htons((file_length+255)>>8);
- for(i=0x80; i>=0x0e; i--)
- outbuf[len++]=i;
- i=htons(checksum(outbuf+2, len-2));
- *(int *)(outbuf+len)=i;
- len+=2;
- outbuf[len++]=PKG_SIGN3;
- break;
- case CODE_DATA:
- ph=(ppkg_head)outbuf;
- ph->sign=htons(PKG_SIGN);
- ph->type=PKG_TYPE2;
- i=sizeof(pkg_head)+sizeof(pkg_data_head);
- len=i+ibuf_len+sizeof(pkg_tail);
- ph->lenth=htons(len-2);
- ph->code=CODE_DATA;
- pd=(ppkg_data_head)(outbuf+sizeof(pkg_head));
- pd->dummy=htons(0x0000);
- pd->addr=htons(block_no*BLOCK_SIZE);
- pd->lenth=htons(ibuf_len);
- memcpy(outbuf+i, inbuf, ibuf_len);
- pt=(ppkg_tail)(outbuf+i+ibuf_len);
- pt->cksum=htons(checksum(outbuf+2, i+ibuf_len-2));
- pt->sign=PKG_SIGN3;
- break;
- case CODE_END:
- len=sizeof(end);
- memcpy(outbuf, end, len);
- break;
- case CODE_CONF:
- len=sizeof(config);
- memcpy(outbuf, config, len);
- break;
- case CODE_BYE:
- len=sizeof(bye);
- memcpy(outbuf, bye, len);
- break;
- default:
- fprintf(stderr, "make_pkg(): invalid package code\n");
- len=0;
- return len;
- // return: 0: fail; 1: success
- int conf_mcu(char *port_name, int baud_rate)
- int i, len=0;
- char recv_buf[BUFFSIZE], send_buf[BUFFSIZE];
- reopen_port(port_name, baud_rate);
- step=CODE_CONF;
- len=make_pkg(step, recv_buf, len, send_buf, BUFFSIZE);
- len=send_mcu(port_fd, send_buf, len);
- step=CODE_INFO;
- len=recv_mcu(port_fd, recv_buf, BUFFSIZE);
- i=check_recv(step, recv_buf, len);
- step=CODE_BYE;
- len=make_pkg(step, recv_buf+i, len-i, send_buf, BUFFSIZE);
- len=send_data(port_fd, send_buf, len);
- close_port();
- if(i>=0)
- i=1;
- else
- i=0;
- return i;
- void help(char *cmd_name)
- printf("STC MCU flash ROM programmer, Version " VERSION " (2011), GPLv2 Lisence\n");
- printf("Warning: this is not an official release, use it on your own risk.\n\n");
- printf("Surpport MCU type: STC11F04E\n\n");
- printf("Usage:\n %s [options] [.bin filename]\n\n", cmd_name);
- printf("Options:\n -h\t\tprint this text\n"
- " -d dev\tuse given device, default: " DEFAULT_PORT "\n"
- " -D\t\tenable debug output\n");
- exit(0);
- int main(int argc, char *argv[])
- static char default_dev[]=DEFAULT_PORT;
- char *port_name=default_dev;
- char *file_name=NULL;
- int i, len;
- while((i=getopt(argc, argv, "hd:D"))!=-1) {
- switch(i) {
- case 'h':
- help(argv[0]);
- break;
- case 'd':
- port_name=optarg;
- break;
- case 'D':
- debug=1;
- break;
- case '?':
- exit(1);
- for(; optind<argc; optind++) {
- file_name=argv[optind];
- break;
- if(file_name!=NULL) {
- if(strcasestr(file_name, ".bin")==NULL) {
- fprintf(stderr, "Invalid file name\n");
- exit(1);
- rom_file=fopen(file_name, "rb");
- if(rom_file==NULL) {
- fprintf(stderr, "Cannot open file\n");
- exit(1);
- i=fileno(rom_file);
- if(fstat(i, (struct stat *)recv_buf)==-1) {
- perror("Cannot get length of the file\n");
- close_port();
- exit(1);
- file_length=((struct stat *)recv_buf)->st_size;
- printf("Use port %s\n", port_name);
- printf("Connecting to target MCU at 2400bps ... ");
- if((port_fd=open_port(port_name, LOW_BAUD))==-1)
- exit(1);
- // Power off and power on MCU via DTR & RTS signal
- ioctl(port_fd, TIOCMGET, &i);
- i&=~(TIOCM_RTS | TIOCM_DTR);
- ioctl(port_fd, TIOCMSET, &i);
- usleep(100000);
- i|=TIOCM_RTS | TIOCM_DTR;
- step=CODE_INFO;
- for(i=150; i>0; i--) {
- len=send_data(port_fd, "\x7f\x7f\x7f\x7f", 4);
- if(len<1) {
- printf("\b\bSend data failed\n");
- close_port();
- exit(1);
- if(i%5==0) {
- printf("\b\b%2d", i/5);
- fflush(stdout);
- if(len>=PKG_MINIMAL_LEN)
- break;
- if(len<PKG_MINIMAL_LEN) {
- printf("\b\bFailed\n");
- close_port();
- exit(1);
- gettimeofday(&start_tv, NULL);
- mcu_info(recv_buf+i, len-i);
- close_port();
- exit(0);
- // confirm MCU, procedure: make_pkg -> send -> recv -> check_recv
- step=CODE_MODI;
- // Inform to modify baud rate
- if(debug) printf("\nInform MCU to modify baud rate ...\n");
- reopen_port(port_name, HIGH_BAUD);
- // Send at 2400bps to confirm the new baud rate
- if(debug) printf("\nConfirm MCU with new baud rate ... \n");
- step=CODE_NEWB;
- reopen_port(port_name, LOW_BAUD);
- // Change to new baud rate
- printf("\nReconnecting to target MCU at " MSG_HIGH_BAUD " ... ");
- step=CODE_ERASE;
- ********余下代碼下載附件*********
stc-isp.rar
(5.88 KB, 下載次數(shù): 68)
2019-3-24 10:38 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
