采用A3984驅(qū)動(dòng)芯片
同時(shí)也兼容不部分驅(qū)動(dòng)器
控制主要包括三點(diǎn):PWM脈沖輸出,DIR方向選擇,EN控制使能
采用定時(shí)器輸出比較模式
- #include "stm32f4xx.h"
- #include "MicroStepDriver.h"
- #include "bsp_debug_usart.h"
- #include "mpu6050.h"
- * @brief 主函數(shù)
- * @param 無
- * @retval 無
- int main(void)
- // signed int step; //步數(shù)
- // signed int now_place; //當(dāng)前角度
- //步進(jìn)電機(jī)初始化
- MSD_Init();
- while(1)
- /*********************************************END OF FILE**********************/
復(fù)制代碼- #include "MicroStepDriver.h"
- #include <stdio.h>
- #include <math.h>
- //系統(tǒng)加減速參數(shù)
- //speedRampData srd;
- ////記錄步進(jìn)電機(jī)的位置
- //int stepPosition = 0;
- ////系統(tǒng)電機(jī)、串口狀態(tài)
- //struct GLOBAL_FLAGS status = {FALSE, FALSE,TRUE};
- * @brief 定時(shí)器中斷優(yōu)先級(jí)配置
- * @param 無
- * @retval 無
- static void TIM_NVIC_Config(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- // 設(shè)置中斷組為0
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
- // 設(shè)置中斷來源
- NVIC_InitStructure.NVIC_IRQChannel = MSD_PULSE_TIM_IRQ;
- // 設(shè)置搶占優(yōu)先級(jí)
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
- // 設(shè)置子優(yōu)先級(jí)
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- * @brief 初始化電機(jī)驅(qū)動(dòng)用到的引腳
- * @param 無
- * @retval 無
- static void MSD_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- //電機(jī)脈沖輸出 GPIO 初始化
- MSD_PULSE_AHBxClock_FUN(MSD_PULSE_GPIO_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MSD_PULSE_PIN;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(MSD_PULSE_PORT, &GPIO_InitStructure);
- /* 連接 PXx 到 定時(shí)器輸出通道*/
- GPIO_PinAFConfig(MSD_PULSE_PORT,MSD_PULSE_PIN_SOURCE,MSD_PULSE_PIN_AF);
- //電機(jī)方向輸出 GPIO 、細(xì)分、reset、sleep初始化
- MSD_DIR_AHBxClock_FUN(MSD_DIR_GPIO_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MSD_DIR_PIN;
- GPIO_Init(MSD_DIR_PORT, &GPIO_InitStructure);
- GPIO_ResetBits(MSD_DIR_PORT,MSD_DIR_PIN);
- //電機(jī)使能輸出 GPIO 初始化
- MSD_ENA_AHBxClock_FUN(MSD_ENA_GPIO_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MSD_ENA_PIN;
- GPIO_Init(MSD_ENA_PORT, &GPIO_InitStructure);
- GPIO_ResetBits(MSD_ENA_PORT,MSD_ENA_PIN);
- // * 注意:TIM_TimeBaseInitTypeDef結(jié)構(gòu)體里面有5個(gè)成員,TIM6和TIM7的寄存器里面只有
- // * TIM_Prescaler和TIM_Period,所以使用TIM6和TIM7的時(shí)候只需初始化這兩個(gè)成員即可,
- // * 另外三個(gè)成員是通用定時(shí)器和高級(jí)定時(shí)器才有.
- // *typedef struct
- // *{ TIM_Prescaler 都有
- // * TIM_CounterMode TIMx,x[6,7]沒有,其他都有
- // * TIM_Period 都有
- // * TIM_ClockDivision TIMx,x[6,7]沒有,其他都有
- // * TIM_RepetitionCounter TIMx,x[1,8,15,16,17]才有
- // *}TIM_TimeBaseInitTypeDef;
- /* ---------------- PWM信號(hào) 周期和占空比的計(jì)算--------------- */
- // ARR :自動(dòng)重裝載寄存器的值
- // CLK_cnt:計(jì)數(shù)器的時(shí)鐘,等于 Fck_int / (psc+1) = 168M/(psc+1)
- // PWM 信號(hào)的周期 T = (ARR+1) * (1/CLK_cnt) = (ARR+1)*(PSC+1) / 72M
- // 占空比P=CCR/(ARR+1)
- static void TIM_Mode_Config(void)
- // 開啟定時(shí)器時(shí)鐘,即內(nèi)部時(shí)鐘CK_INT=168M
- MSD_PULSE_TIM_APBxClock_FUN(MSD_PULSE_TIM_CLK,ENABLE);
- /*--------------------時(shí)基結(jié)構(gòu)體初始化-------------------------*/
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
- // 自動(dòng)重裝載寄存器的值,累計(jì)TIM_Period+1個(gè)周期后產(chǎn)生一個(gè)更新或者中斷
- TIM_TimeBaseStructure.TIM_Period=MSD_PULSE_TIM_PERIOD;
- // 驅(qū)動(dòng)CNT計(jì)數(shù)器的時(shí)鐘 = Fck_int/(psc+1)
- TIM_TimeBaseStructure.TIM_Prescaler= MSD_PULSE_TIM_PSC;
- // 時(shí)鐘分頻因子 ,配置死區(qū)時(shí)間時(shí)需要用到
- TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
- // 計(jì)數(shù)器計(jì)數(shù)模式,設(shè)置為向上計(jì)數(shù)
- TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
- // 重復(fù)計(jì)數(shù)器的值,最大值為255
- //TIM_TimeBaseStructure.TIM_RepetitionCounter=0;
- // 初始化定時(shí)器
- TIM_TimeBaseInit(MSD_PULSE_TIM, &TIM_TimeBaseStructure);
- /*--------------------輸出比較結(jié)構(gòu)體初始化-------------------*/
- TIM_OCInitTypeDef TIM_OCInitStructure;
- // 配置為PWM模式2
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
- // 輸出使能
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- // 互補(bǔ)輸出禁能
- TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
- // 設(shè)置占空比大小
- TIM_OCInitStructure.TIM_Pulse = MSD_PULSE_TIM_PERIOD/2;
- // 輸出通道電平極性配置
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
- // 輸出通道空閑電平極性配置
- TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
- MSD_PULSE_OCx_Init(MSD_PULSE_TIM, &TIM_OCInitStructure);
- //使能TIM1_CH1預(yù)裝載寄存器
- MSD_PULSE_OCx_PreloadConfig(MSD_PULSE_TIM, TIM_OCPreload_Enable);
- //使能TIM1預(yù)裝載寄存器
- TIM_ARRPreloadConfig(MSD_PULSE_TIM, ENABLE);
- //設(shè)置中斷源,只有溢出時(shí)才中斷
- TIM_UpdateRequestConfig(MSD_PULSE_TIM,TIM_UpdateSource_Regular);
- // 清除中斷標(biāo)志位
- TIM_ClearITPendingBit(MSD_PULSE_TIM, TIM_IT_Update);
- // 使能中斷
- TIM_ITConfig(MSD_PULSE_TIM, TIM_IT_Update, ENABLE);
- // 使能計(jì)數(shù)器
- TIM_Cmd(MSD_PULSE_TIM, ENABLE);
- * @brief 初始化電機(jī)相關(guān)的外設(shè)
- * @param 無
- * @retval 無
- void MSD_Init(void)
- MSD_GPIO_Config();
- TIM_NVIC_Config();
- TIM_Mode_Config();
- #include "string.h"
- struct STime stcTime;
- struct SAcc stcAcc;
- struct SGyro stcGyro;
- struct SAngle stcAngle;
- struct SMag stcMag;
- struct SDStatus stcDStatus;
- struct SPress stcPress;
- struct SLonLat stcLonLat;
- struct SGPSV stcGPSV;
- //unsigned char [250];
- //CopeSerialData為串口中斷調(diào)用函數(shù),串口每收到一個(gè)數(shù)據(jù),調(diào)用一次這個(gè)函數(shù)。
- //處理串口接收到的陀螺儀數(shù)據(jù)
- void CopeSerialData(unsigned char ucData)
- static unsigned char ucRxBuffer[250];
- static unsigned char ucRxCnt = 0;
- ucRxBuffer[ucRxCnt++]=ucData;
- if (ucRxBuffer[0]!=0x55) //數(shù)據(jù)頭不對(duì),則重新開始尋找0x55數(shù)據(jù)頭
- ucRxCnt=0;
- return;
- if (ucRxCnt<11) {return;}//數(shù)據(jù)不滿11個(gè),則返回
- else
- switch(ucRxBuffer[1])
- case 0x50: memcpy(&stcTime,&ucRxBuffer[2],8);break;//memcpy為編譯器自帶的內(nèi)存拷貝函數(shù),需引用"string.h",將接收緩沖區(qū)的字符拷貝到數(shù)據(jù)共同體里面,從而實(shí)現(xiàn)數(shù)據(jù)的解析。
- case 0x51: memcpy(&stcAcc,&ucRxBuffer[2],8);break;
- case 0x52: memcpy(&stcGyro,&ucRxBuffer[2],8);break;
- case 0x53: memcpy(&stcAngle,&ucRxBuffer[2],8);break;
- case 0x54: memcpy(&stcMag,&ucRxBuffer[2],8);break;
- case 0x55: memcpy(&stcDStatus,&ucRxBuffer[2],8);break;
- case 0x56: memcpy(&stcPress,&ucRxBuffer[2],8);break;
- case 0x57: memcpy(&stcLonLat,&ucRxBuffer[2],8);break;
- case 0x58: memcpy(&stcGPSV,&ucRxBuffer[2],8);break;
- ucRxCnt=0;
定時(shí)器.7z
(355.16 KB, 下載次數(shù): 37)
2019-3-27 19:01 上傳
點(diǎn)擊文件名下載附件
簡單步進(jìn)電機(jī)驅(qū)動(dòng)程序
