查看: 2109|回復(fù): 1
基于51單片機(jī),通過ds1302實現(xiàn)電子時鐘
ID:493177 發(fā)表于 2019-3-29 09:20 | 顯示全部樓層 |閱讀模式
這是一個通過ds1302時鐘芯片寫的一個電子時鐘
并且加入了紅外傳感器,用一個遙控來控制時鐘
希望對大家有用。
#include "ds1302.h"
unsigned char code READ_RTC_ADDR[7] = {0x81, 0x83, 0x85, 0x87, 0x89, 0x8b, 0x8d}; //DS1302讀時間寄存器地址
unsigned char code WRITE_RTC_ADDR[7] = {0x80, 0x82, 0x84, 0x86, 0x88, 0x8a, 0x8c};//DS1302寫時間寄存器地址
unsigned char code qq[16]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x9,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f};
unsigned char code qdm[]={0x02,0x9f,0x25,0x0d,0x99,0x49,0x40,0x1f,0x00,0x08,0xff};
unsigned char code hh[12]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10,0x11,0x12};
unsigned char tim[7]; //存放時間數(shù)據(jù)臨時數(shù)組
unsigned char s[16],t[16];
unsigned char c = 0,u = 0;wei = 0,zx = 0,o = 0,date = 0,xw = 0;
unsigned char month = 0,day = 0,h = 0,m = 0,send = 0;
bit zt = 0,x = 0,f = 0,stop = 0;
unsigned char key = 0,ke = 0,PH1 = 0,PL1 = 0;
unsigned int js = 0,js1 = 0,year = 0,Time;
sbit IRIN = P3^2;
unsigned char IrValue[5];  // IrValue的0-3用來放原始數(shù)據(jù),4用來放經(jīng)過校驗確認(rèn)無誤的鍵值
sbit SHCP=P3^3;
sbit DS=P3^4;
sbit STCP=P3^6;
sbit OE=P3^5;
sbit KEY1 = P2^0;
sbit KEY2 = P2^1;
sbit KEY3 = P2^2;
void Init(void)
    SHCP=DS=STCP=1;    //DS1302初始化
    TMOD = 0x20;
    TH1 = TL1 = 56;
    ET1 = 1;
    TR1 = 1;
    OE=0;
    PH1 = PL1 = 0;
    IPH = 0x08;
void IrInit(void)
    IT0  = 1;//下降沿觸發(fā)
    EX0  = 1;//打開中斷0允許
    EA = 1;
    IRIN = 1;//初始化端口
    PX0 = 1;
* 函 數(shù) 名       :延時函數(shù)
* 函數(shù)功能         :
* 輸    入       :X
* 輸    出         :無
void DelayMs(unsigned int x)
    unsigned char i;
    while(x--)
        for (i = 0; i<114; i++);
void Delay(unsigned int i)
    unsigned int j;
    while(i--)
        for(j=1;j>0;j--);
//毫秒級延時
void Delay_1ms(unsigned int i)
    unsigned int j;
    while(i--)
        for(j=600;j>0;j--);
* 函 數(shù) 名       : ds1302_write_reg
* 函數(shù)功能         : 寫入寄存器地址,向?qū)懭氲募拇嫫鞯刂穼懭霐?shù)據(jù)(僅在內(nèi)部使用)
* 輸    入       : 寄存器地址reg_addr 數(shù)據(jù) value
* 輸    出         : 無
static void ds1302_write_reg(unsigned char reg_addr,unsigned char value)
      unsigned char i = 0;
      unsigned char dat = 0;
    //第一部分:時序起始部分
        DS_SCLK = 0; //DS_SCLK為低時,DS_RST由低變高,
        Delay(1);
        DS_RST  = 0;
        Delay(1);
        DS_RST  = 1;
        Delay(1);
    //第二部分:寫入地址
        for(i=0;i<8;i++)
            dat = reg_addr & 0x01;
            DS_IO = dat;
            DS_SCLK = 1;//制造上升沿
            Delay(1);
            DS_SCLK = 0;//小周期結(jié)束,給下一個周期做準(zhǔn)備
            Delay(1);
            reg_addr>>=1;
ds1302.c.tar.gz
3.83 KB, 下載次數(shù): 16, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
ID:518884 發(fā)表于 2019-4-23 08:43 | 顯示全部樓層
寫的不錯、、、、、
