#include "main.h"
#include "nRF24L01.h"
/*Bit field operations*/
#define SetBit( Byte, Bit ) ( Byte ) |= ( 1<<( Bit ) )
#define ClrBit( Byte, Bit ) ( Byte ) &= ~( 1<<( Bit ) )
#define GetBit( Byte, Bit ) ( ( Byte ) & ( 1<<( Bit ) ) )
#define ComBit( Byte, Bit ) ( Bytes ) ^= ( 1<<( Bit ) )
#define SetBits( Byte, Bits ) ( Byte ) |= ( Bits )
#define ClrBits( Byte, Bits ) ( Byte ) &= ~( Bits )
#define GetBits( Byte, Bits ) ( ( Byte ) & ( Bits ) )
#define ComBits( Byte, Bits ) ( Byte ) ^= ( Bits )
#define M32_MOSI PB5
#define M32_MISO PB6
#define M32_SCK PB7
Function : USART_SendChar( )
Description: Send a single byte via the USART
InPut : -dt, The value you want to send
Output : None
void USART_SendChar( unsigned char dt )
UCSRA |= ( 1<<TXC );
UDR = dt;
while( !( UCSRA & ( 1<<TXC ) ) );
Function : USART_SendArray( )
Description: Send a array of data via the USART port
InPut : -pBuff, The buffer to store the data
-nBytes, How many bytes do you want to send ?
Output : None
void USART_SendArray( unsigned char* pBuff, unsigned char nBytes )
unsigned char btmp;
for( btmp = 0; btmp < nBytes; btmp ++ )
USART_SendChar( *( pBuff + btmp ) );
Function : USART_SendStr( )
Description: Send a string of data via the USART port
InPut : pstr->the string to be sent
Output : None
void USART_SendStr( char *pstr )
while( *pstr )
USART_SendChar( *pstr++ );
Function : USART_Init( ),
Description: Initialize the USART port
InPut : None
Output : None
#define Bandrate 9600
#define F_CPU 12000000
void USART_Init( void )
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = 0x86;
UBRRL = ( F_CPU / 16 / Bandrate - 1 ) % 256;
UBRRH = ( F_CPU / 16 / Bandrate - 1 ) >> 8;
UCSRB = 0x98;
Function : SPI_Init( )
Description : Initialize the SPI bus
Input : None
Output: None
/*void SPI_Init( void )
//IO config
PORTB |= ( 1<<0 ) | ( 1<<5 ) | ( 1<<3 ) | ( 1<<2 ) | ( 1<<4 );
DDRB |= ( 1<<0 ) | ( 1<<2 ) | ( 1<<3 ) | ( 1<<5 );
DDRB &= ~( 1<<4 );
SPCR = (1<<SPE) | (1<<MSTR);
/*IO config*/
PORTB |= ( 1<<0 ) | ( 1<<5 ) | ( 1<<6 ) | ( 1<<7 ) | ( 1<<4 );
DDRB |= ( 1<<7 ) | ( 1<<5 ) | ( 1<<0 ) | ( 1<<4 );
DDRB &= ~( 1<<6 );
Function : SPI_ExchangeByte( )
Description : Exchange a byte via the SPI bus
Input : -value, The byte sent
Output: The byte read.
INT8U SPI_ExchangeByte( INT8U value )
SPDR = value;
while ( !(SPSR & (1<<SPIF)) );
return SPDR;
INT8U testbuffer[32];
int main( void )
INT8U tmp;
unsigned char ReplayData[] = {"我很好!\r\n"};
SPI_Init( );
USART_Init( );
L01_Init( );
L01_SetRXMode( );
L01_WriteHoppingPoint( 0 );
USART_SendStr( "nRF24L01P接收測(cè)試開始!\r\n" );
while( 1 )
for( tmp = 0; tmp < 32; tmp ++ )
testbuffer[tmp] = tmp+0x20;
L01_FlushRX( );
L01_FlushTX( );
L01_WriteRXPayload_InAck( ReplayData, sizeof( ReplayData ) );
while( 1 )
tmp = L01_ReadStatusReg( );
// USART_SendChar(tmp); //for test
tmp &= ( 1<<TX_DS ) | ( 1<<MAX_RT ) | ( 1<<RX_DR );
if( tmp != 0 )
break;
if( tmp & ( 1<<TX_DS ) )
// USART_SendStr( "發(fā)送成功\r\n" );
else if( tmp & ( 1<<MAX_RT ) )
// USART_SendStr( "發(fā)送失敗\r\n" );
else if( tmp & ( 1<<RX_DR ) )
L01_WriteRXPayload_InAck( testbuffer, 32 );
USART_SendStr( "收到數(shù)據(jù):" );
tmp = L01_ReadRXPayload( testbuffer );
USART_SendArray( testbuffer, tmp );
USART_SendStr( "回復(fù)數(shù)據(jù):" );
USART_SendStr( ( char*) ReplayData );
L01_ClearIRQ( IRQ_ALL );
return 0;
AVR_M16(ICC).rar
2019-4-2 19:24 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
161.42 KB, 下載次數(shù): 32, 下載積分: 黑幣 -5
