查看: 6098|回復(fù): 3
HMC5883和qmc5883來做指南針51單片機(jī)源程序
ID:268888 發(fā)表于 2019-4-4 16:35 | 顯示全部樓層 |閱讀模式
獲取原始數(shù)據(jù),然后計(jì)算
附件是使用了OLED 0.96來做的指南針,雖然YZ軸沒啥用,但是還是做了處理;
和iphone對(duì)比,基本上做到了5度之內(nèi)的偏差;
Multiple_Read_QMC5883(BUF);
magx=BUF[1] << 8 | BUF[0]; //Combine MSB and LSB of X Data output register  最高有效位
magy=BUF[3] << 8 | BUF[2]; //Combine MSB and LSB of Y Data output register
magz=BUF[5] << 8 | BUF[4]; //Combine MSB and LSB of Z Data output register
if(magx>0x7fff)magx-=0xffff;
if(magy>0x7fff)magy-=0xffff;
if(magz>0x7fff)magz-=0xffff;
  magx=magx-offsetX;magy=magy-offsetY;magz=magz-offsetZ;
  Angle_XY= atan2((double)magy,(double)magx) * (180 / 3.14159265) + 180; //計(jì)算XY平面角度
  Angle_XZ= atan2((double)magz,(double)magx) * (180 / 3.14159265) + 180; //計(jì)算XZ平面角度
  Angle_YZ= atan2((double)magz,(double)magy) * (180 / 3.14159265) + 180; //計(jì)算YZ平面角
當(dāng)然這還是不夠的,因?yàn)榇艌?chǎng)便宜,或當(dāng)?shù)卮艌?chǎng)問題會(huì)造成,xyz擬合的時(shí)候出現(xiàn)橢圓,所以要修正;
Multiple_Read_QMC5883(BUF);      //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
X=BUF[1] << 8 | BUF[0]; //Combine MSB and LSB of X Data output register  最高有效位
Y=BUF[3] << 8 | BUF[2]; //Combine MSB and LSB of Y Data output register
Z=BUF[5] << 8 | BUF[4]; //Combine MSB and LSB of Z Data output register
if(X>0x7fff)X-=0xffff;
if(Y>0x7fff)Y-=0xffff;
if(Z>0x7fff)Z-=0xffff;
    if (X > xMax)
       xMax = X;
     if (X < xMin )
       xMin = X;
     if(Y > yMax )
       yMax = Y;
     if(Y < yMin )
       yMin = Y;
     if(Z > zMax )
       zMax = Z;
     if(Z < zMin )
      zMin = Z;
if(abs(xMax - xMin) > 0 )
offsetX = (xMax + xMin)/2;
if(abs(yMax - yMin) > 0 )
offsetY = (yMax + yMin)/2;
if(abs(zMax - zMin) > 0 )
offsetZ = (zMax +zMin)/2;
Keil代碼下載:
51單片機(jī)代碼.7z (57.28 KB, 下載次數(shù): 199)
ID:504404 發(fā)表于 2019-8-21 11:52 | 顯示全部樓層
謝謝啦,很強(qiáng)啊
ID:625152 發(fā)表于 2019-10-16 16:51 | 顯示全部樓層
謝謝,終于找到了
ID:978679 發(fā)表于 2023-3-17 16:02 | 顯示全部樓層
暈,程序是51的不是STM32的大家如果要STM32的不要下
