使用:上位機Processing上畫出8x8點陣圖案,發(fā)送數(shù)據(jù)到Arduino驅(qū)動8x8點陣顯示.數(shù)據(jù)很簡單就是點陣的 1111100011110000.....(64位)發(fā)送串口.
問題: 點陣第64位總是不對(黑圈處),希望有高手指點哪里出問題.
Arduino代碼: - int R[] = {2,7,A5,5,13,A4,12,A2}; //行
- int C[] = {6,11,10,3,A3,4,8,9}; //列
- char command;
- int mark = 0;
- int numdata[8][8];
- int data;
- char xh;
- void setup(){
- Serial.begin(9600);
- for(int i = 0;i<8;i++){
- pinMode(R[i],OUTPUT);
- pinMode(C[i],OUTPUT);
- for(int j = 0;j<8;j++){
- numdata[i][j]=0;
- void loop(){
- recv_data();
- updateServo();
- void recv_data(){
- while(Serial.available()){
- for(int i=0;i<8;i++){
- numdata[i][0]=Serial.read();
- delay(10);
- numdata[i][1]=Serial.read();
- delay(10);
- numdata[i][2]=Serial.read();
- delay(10);
- numdata[i][3]=Serial.read();
- delay(10);
- numdata[i][4]=Serial.read();
- delay(10);
- numdata[i][5]=Serial.read();
- delay(10);
- numdata[i][6]=Serial.read();
- delay(10);
- numdata[i][7]=Serial.read();
- delay(10);
- mark = 1;
- void updateServo(){
- if(mark == 1){
- for(int i = 0 ; i < 100 ; i++) {
- for(int c = 0; c< 8;c++){
- digitalWrite(C[c],LOW);//選通第c列
- for(int r = 0;r< 8;r++){
- digitalWrite(R[r],numdata[r][c]);
- delay(1);
- Clear(); //清空顯示去除余暉
- mark == 0;
- void Clear(){
- digitalWrite(R[i],LOW);
- digitalWrite(C[i],HIGH);
- Processing 代碼:
- //processing端程序
- import processing.serial.*;
- String comname="COM4";
- Serial port;
- boolean serial;
- byte Serial_StopFlag = 0;
- boolean Serial_OpenFlag = false;
- boolean Serial_DatareadFlag = false;
- boolean Serial_GetdataFlag = false;
- PFont myFont;
- PFont font;
- String[] mesg = new String[8];
- String[] command = new String[8];
- int a1=0;
- int a2=0;
- int a3=0;
- int a4=0;
- int a5=0;
- int a6=0;
- int a7=0;
- int a8=0;
- int b1=0;
- int b2=0;
- int b3=0;
- int b4=0;
- int b5=0;
- int b6=0;
- int b7=0;
- int b8=0;
- int c1=0;
- int c2=0;
- int c3=0;
- int c4=0;
- int c5=0;
- int c6=0;
- int c7=0;
- int c8=0;
- int d1=0;
- int d2=0;
- int d3=0;
- int d4=0;
- int d5=0;
- int d6=0;
- int d7=0;
- int d8=0;
- int e1=0;
- int e2=0;
- int e3=0;
- int e4=0;
- int e5=0;
- int e6=0;
- int e7=0;
- int e8=0;
- int f1=0;
- int f2=0;
- int f3=0;
- int f4=0;
- int f5=0;
- int f6=0;
- int f7=0;
- int f8=0;
- int g1=0;
- int g2=0;
- int g3=0;
- int g4=0;
- int g5=0;
- int g6=0;
- int g7=0;
- int g8=0;
- int h1=0;
- int h2=0;
- int h3=0;
- int h4=0;
- int h5=0;
- int h6=0;
- int h7=0;
- int h8=0;
- byte click = 0;
- //初試化
- void setup(){
- size(700,500);
- frameRate(53);
- port=new Serial(this,"COM4",9600);
- font = createFont("宋體.vlw",48);
- textFont(font);
- frameRate(30);
- smooth();
- mesg[i]="0,0,0,0,0,0,0,0";
- for(int j=0;j<8;j++){
- command[j]="0,0,0,0,0,0,0,0,0";
- //主程序
- void draw(){
- background(255);
- inter_face();
- CheckBoxHandle1();
- CheckBoxHandle2();
- CheckBoxHandle3();
- CheckBoxHandle4();
- CheckBoxHandle5();
- CheckBoxHandle6();
- CheckBoxHandle7();
- CheckBoxHandle8();
- void inter_face(){
- textSize(18);
- strokeWeight(2);
- fill(0);
- text("Processing 控制 8 x 8 點陣",280,20);
- line(0,25,700,25);
- line(0,450,700,450);
- line(0,280,700,280);
- textSize(16);
- strokeWeight(2);
- fill(0);
- text("向Arduino發(fā)送數(shù)據(jù):",5,480);
- mesg[0]=a1+","+a2+","+a3+","+a4+","+a5+","+a6+","+a7+","+a8+",";
- mesg[1]=b1+","+b2+","+b3+","+b4+","+b5+","+b6+","+b7+","+b8+",";
- mesg[2]=c1+","+c2+","+c3+","+c4+","+c5+","+c6+","+c7+","+c8+",";
- mesg[3]=d1+","+d2+","+d3+","+d4+","+d5+","+d6+","+d7+","+d8+",";
- mesg[4]=e1+","+e2+","+e3+","+e4+","+e5+","+e6+","+e7+","+e8+",";
- mesg[5]=f1+","+f2+","+f3+","+f4+","+f5+","+f6+","+f7+","+f8+",";
- mesg[6]=g1+","+g2+","+g3+","+g4+","+g5+","+g6+","+g7+","+g8+",";
- mesg[7]=h1+","+h2+","+h3+","+h4+","+h5+","+h6+","+h7+","+h8+",";
- text(mesg[i],400,50+i*20);
- if(button(500, 400,"發(fā) 送") != 0){
- send_data();
- if(button(590, 400,"退 出") != 0){
- exit();
- //send data to Arduino
- void send_data(){
- command=split(mesg[i],',');
- print(command[0]);
- print(command[1]);
- print(command[2]);
- print(command[3]);
- print(command[4]);
- print(command[5]);
- print(command[6]);
- print(command[7]);
- port.write(int(command[0]));
- port.write(int(command[1]));
- port.write(int(command[2]));
- port.write(int(command[3]));
- port.write(int(command[4]));
- port.write(int(command[5]));
- port.write(int(command[6]));
- port.write(int(command[7]));
- //delay(1);
- serial=false;
- //鼠標
- boolean mousePressedFlag = false;
- void mousePressed() {
- mousePressedFlag = true;
- boolean SaveFlag = false;
- //按鈕
- byte button(float x , float y , String str){
- byte ret = 0;
- fill(0,0,0);
- strokeWeight(2);
- //stroke(255,255,0);
- if((mouseX > x) && (mouseY > y) && (mouseX < (x + 100) ) &&(mouseY < (y + 30))){
- fill(128,255,255);
- if (mousePressedFlag && (mouseButton == LEFT)) {
- mousePressedFlag = false;
- fill(0,128,128);
- ret = 1;
- rect(x,y, 80, 30);
- fill(255,255,255);
- textSize(16);
- text(str, x + 24, y + 22);
- return ret;
- //舵機角度選擇
- boolean a1_checkBox = false;
- boolean a2_checkBox = false;
- boolean a3_checkBox = false;
- boolean a4_checkBox = false;
- boolean a5_checkBox = false;
- boolean a6_checkBox = false;
- boolean a7_checkBox = false;
- boolean a8_checkBox = false;
- void CheckBoxHandle1(){
- if(CheckBox(20,30,a1_checkBox, "")== 1){
- a1_checkBox = (a1_checkBox == false) ? true: false;
- if(a1_checkBox == true){
- a1=1;
- }else{
- a1=0;
- if(CheckBox(60,30,a2_checkBox, "") == 1){
- a2_checkBox = (a2_checkBox == false) ? true: false;
- if(a2_checkBox == true){
- a2=1;
- }else{
- a2=0;
- if(CheckBox(100,30, a3_checkBox, "") == 1){
- a3_checkBox = (a3_checkBox == false) ? true: false;
- if(a3_checkBox == true){
- a3=1;
- }else{
- a3=0;
- if(CheckBox(140,30, a4_checkBox, "") == 1){
- a4_checkBox = (a4_checkBox == false) ? true: false;
- if(a4_checkBox == true){
- a4=1;
- }else{
- a4=0;
- if(CheckBox(180,30, a5_checkBox, "") == 1){
- a5_checkBox = (a5_checkBox == false) ? true: false;
- if(a5_checkBox == true){
- a5=1;
- }else{
- a5=0;
- if(CheckBox(220,30, a6_checkBox, "") == 1){
- a6_checkBox = (a6_checkBox == false) ? true: false;
- if(a6_checkBox == true){
- a6=1;
- }else{
- a6=0;
- if(CheckBox(260,30, a7_checkBox, "") == 1){
- a7_checkBox = (a7_checkBox == false) ? true: false;
- if(a7_checkBox == true){
- a7=1;
- }else{
- a7=0;
- if(CheckBox(300,30, a8_checkBox, "") == 1){
- a8_checkBox = (a8_checkBox == false) ? true: false;
- if(a8_checkBox == true){
- a8=1;
- }else{
- a8=0;
- boolean checkBox_Geta1Flag(){
- return a1_checkBox;
- boolean checkBox_Geta2Flag(){
- return a2_checkBox;
- boolean checkBox_Geta3Flag(){
- return a3_checkBox;
- boolean checkBox_Geta4lag(){
- return a4_checkBox;
- boolean checkBox_Geta5Flag(){
- return a5_checkBox;
- boolean checkBox_Geta6Flag(){
- return a6_checkBox;
- boolean checkBox_Geta7Flag(){
- return a7_checkBox;
- boolean checkBox_Geta8lag(){
- return a8_checkBox;
- //舵機角度選擇
- boolean b1_checkBox = false;
- boolean b2_checkBox = false;
- boolean b3_checkBox = false;
- boolean b4_checkBox = false;
- boolean b5_checkBox = false;
- boolean b6_checkBox = false;
- boolean b7_checkBox = false;
- boolean b8_checkBox = false;
- void CheckBoxHandle2(){
- if(CheckBox(20,60,b1_checkBox, "")== 1){
- b1_checkBox = (b1_checkBox == false) ? true: false;
- if(b1_checkBox == true){
- b1=1;
- }else{
- b1=0;
- if(CheckBox(60,60,b2_checkBox, "") == 1){
- b2_checkBox = (b2_checkBox == false) ? true: false;
- if(b2_checkBox == true){
- b2=1;
- }else{
- b2=0;
- if(CheckBox(100,60, b3_checkBox, "") == 1){
- b3_checkBox = (b3_checkBox == false) ? true: false;
- if(b3_checkBox == true){
- b3=1;
- }else{
- b3=0;
- if(CheckBox(140,60, b4_checkBox, "") == 1){
- b4_checkBox = (b4_checkBox == false) ? true: false;
- if(b4_checkBox == true){
- b4=1;
- }else{
- b4=0;
- if(CheckBox(180,60, b5_checkBox, "") == 1){
- b5_checkBox = (b5_checkBox == false) ? true: false;
- if(b5_checkBox == true){
- b5=1;
- }else{
- b5=0;
- if(CheckBox(220,60, b6_checkBox, "") == 1){
- b6_checkBox = (b6_checkBox == false) ? true: false;
- if(b6_checkBox == true){
- b6=1;
- }else{
- b6=0;
- if(CheckBox(260,60, b7_checkBox, "") == 1){
- b7_checkBox = (b7_checkBox == false) ? true: false;
- if(b7_checkBox == true){
- b7=1;
- }else{
- b7=0;
- if(CheckBox(300,60, b8_checkBox, "") == 1){
- b8_checkBox = (b8_checkBox == false) ? true: false;
- if(b8_checkBox == true){
- b8=1;
- }else{
- b8=0;
- boolean checkBox_Getb1Flag(){
- return b1_checkBox;
- boolean checkBox_Getb2Flag(){
- return b2_checkBox;
- boolean checkBox_Getb3Flag(){
- return b3_checkBox;
- boolean checkBox_Getb4lag(){
- return b4_checkBox;
- boolean checkBox_Getb5Flag(){
- return b5_checkBox;
- boolean checkBox_Getb6Flag(){
- return b6_checkBox;
- boolean checkBox_Getb7Flag(){
- return b7_checkBox;
- boolean checkBox_Getb8lag(){
- return b8_checkBox;
- //舵機角度選擇
- boolean c1_checkBox = false;
- boolean c2_checkBox = false;
- boolean c3_checkBox = false;
- boolean c4_checkBox = false;
- boolean c5_checkBox = false;
- boolean c6_checkBox = false;
- boolean c7_checkBox = false;
- boolean c8_checkBox = false;
- void CheckBoxHandle3(){
- if(CheckBox(20,90,c1_checkBox, "")== 1){
- c1_checkBox = (c1_checkBox == false) ? true: false;
- if(c1_checkBox == true){
- c1=1;
- }else{
- c1=0;
- if(CheckBox(60,90,c2_checkBox, "") == 1){
- c2_checkBox = (c2_checkBox == false) ? true: false;
- if(c2_checkBox == true){
- c2=1;
- }else{
- c2=0;
- if(CheckBox(100,90, c3_checkBox, "") == 1){
- c3_checkBox = (c3_checkBox == false) ? true: false;
- if(c3_checkBox == true){
- c3=1;
- }else{
- c3=0;
- if(CheckBox(140,90, c4_checkBox, "") == 1){
- c4_checkBox = (c4_checkBox == false) ? true: false;
- if(c4_checkBox == true){
- c4=1;
- }else{
- c4=0;
- if(CheckBox(180,90, c5_checkBox, "") == 1){
- c5_checkBox = (c5_checkBox == false) ? true: false;
- if(c5_checkBox == true){
- c5=1;
- }else{
- c5=0;
- if(CheckBox(220,90, c6_checkBox, "") == 1){
- c6_checkBox = (c6_checkBox == false) ? true: false;
- if(c6_checkBox == true){
- c6=1;
- }else{
- c6=0;
- if(CheckBox(260,90, c7_checkBox, "") == 1){
- c7_checkBox = (c7_checkBox == false) ? true: false;
- if(c7_checkBox == true){
- c7=1;
- }else{
- c7=0;
- if(CheckBox(300,90, c8_checkBox, "") == 1){
- c8_checkBox = (c8_checkBox == false) ? true: false;
- if(c8_checkBox == true){
- c8=1;
- }else{
- c8=0;
- boolean checkBox_Getc1Flag(){
- return c1_checkBox;
- boolean checkBox_Getc2Flag(){
- return c2_checkBox;
- boolean checkBox_Getc3Flag(){
- return c3_checkBox;
- boolean checkBox_Getc4lag(){
- return c4_checkBox;
- boolean checkBox_Getc5Flag(){
- return c5_checkBox;
- boolean checkBox_Getc6Flag(){
- return c6_checkBox;
- boolean checkBox_Getc7Flag(){
- return c7_checkBox;
- boolean checkBox_Getc8lag(){
- return c8_checkBox;
- //舵機角度選擇
- boolean d1_checkBox = false;
- boolean d2_checkBox = false;
- boolean d3_checkBox = false;
- boolean d4_checkBox = false;
- boolean d5_checkBox = false;
- boolean d6_checkBox = false;
- boolean d7_checkBox = false;
- boolean d8_checkBox = false;
- void CheckBoxHandle4(){
- if(CheckBox(20,120,d1_checkBox, "")== 1){
- d1_checkBox = (d1_checkBox == false) ? true: false;
- if(d1_checkBox == true){
- d1=1;
- }else{
- d1=0;
- if(CheckBox(60,120,d2_checkBox, "") == 1){
- d2_checkBox = (d2_checkBox == false) ? true: false;
- if(d2_checkBox == true){
- d2=1;
- }else{
- d2=0;
- if(CheckBox(100,120, d3_checkBox, "") == 1){
- d3_checkBox = (d3_checkBox == false) ? true: false;
- if(d3_checkBox == true){
- d3=1;
- }else{
- d3=0;
- if(CheckBox(140,120, d4_checkBox, "") == 1){
- d4_checkBox = (d4_checkBox == false) ? true: false;
- if(d4_checkBox == true){
- d4=1;
- }else{
- d4=0;
- if(CheckBox(180,120, d5_checkBox, "") == 1){
- d5_checkBox = (d5_checkBox == false) ? true: false;
- if(d5_checkBox == true){
- d5=1;
- }else{
- d5=0;
- if(CheckBox(220,120, d6_checkBox, "") == 1){
- d6_checkBox = (d6_checkBox == false) ? true: false;
- if(d6_checkBox == true){
- d6=1;
- }else{
- d6=0;
- if(CheckBox(260,120, d7_checkBox, "") == 1){
- d7_checkBox = (d7_checkBox == false) ? true: false;
- if(d7_checkBox == true){
- d7=1;
- }else{
- d7=0;
- if(CheckBox(300,120, d8_checkBox, "") == 1){
- d8_checkBox = (d8_checkBox == false) ? true: false;
- if(d8_checkBox == true){
- d8=1;
- }else{
- d8=0;
- boolean checkBox_Getd1Flag(){
- return d1_checkBox;
- boolean checkBox_Getd2Flag(){
- return d2_checkBox;
- boolean checkBox_Getd3Flag(){
- return d3_checkBox;
- boolean checkBox_Getd4lag(){
- return d4_checkBox;
- boolean checkBox_Getd5Flag(){
- return d5_checkBox;
- boolean checkBox_Getd6Flag(){
- return d6_checkBox;
- boolean checkBox_Getd7Flag(){
- return d7_checkBox;
- boolean checkBox_Getd8lag(){
- return d8_checkBox;
- //舵機角度選擇
- boolean e1_checkBox = false;
- boolean e2_checkBox = false;
- boolean e3_checkBox = false;
- boolean e4_checkBox = false;
- boolean e5_checkBox = false;
- boolean e6_checkBox = false;
- boolean e7_checkBox = false;
- boolean e8_checkBox = false;
- void CheckBoxHandle5(){
- if(CheckBox(20,150,e1_checkBox, "")== 1){
- e1_checkBox = (e1_checkBox == false) ? true: false;
- if(e1_checkBox == true){
- e1=1;
- }else{
- e1=0;
- if(CheckBox(60,150,e2_checkBox, "") == 1){
- e2_checkBox = (e2_checkBox == false) ? true: false;
- if(e2_checkBox == true){
- e2=1;
- }else{
- e2=0;
- if(CheckBox(100,150, e3_checkBox, "") == 1){
- e3_checkBox = (e3_checkBox == false) ? true: false;
- if(e3_checkBox == true){
- e3=1;
- }else{
- e3=0;
- if(CheckBox(140,150, e4_checkBox, "") == 1){
- e4_checkBox = (e4_checkBox == false) ? true: false;
- if(e4_checkBox == true){
- e4=1;
- }else{
- e4=0;
- if(CheckBox(180,150, e5_checkBox, "") == 1){
- e5_checkBox = (e5_checkBox == false) ? true: false;
- if(e5_checkBox == true){
- e5=1;
- }else{
- e5=0;
- if(CheckBox(220,150, e6_checkBox, "") == 1){
- e6_checkBox = (e6_checkBox == false) ? true: false;
- if(e6_checkBox == true){
- e6=1;
- }else{
- e6=0;
- if(CheckBox(260,150, e7_checkBox, "") == 1){
- e7_checkBox = (e7_checkBox == false) ? true: false;
- if(e7_checkBox == true){
- e7=1;
- }else{
- e7=0;
- if(CheckBox(300,150, e8_checkBox, "") == 1){
- e8_checkBox = (e8_checkBox == false) ? true: false;
- if(e8_checkBox == true){
- e8=1;
- }else{
- e8=0;
- boolean checkBox_Gete1Flag(){
- return e1_checkBox;
- boolean checkBox_Gete2Flag(){
- return e2_checkBox;
- boolean checkBox_Gete3Flag(){
- return e3_checkBox;
- boolean checkBox_Gete4lag(){
- return e4_checkBox;
- boolean checkBox_Gete5Flag(){
- return e5_checkBox;
- boolean checkBox_Gete6Flag(){
- return e6_checkBox;
- boolean checkBox_Gete7Flag(){
- return e7_checkBox;
- boolean checkBox_Gete8lag(){
- return e8_checkBox;
- //舵機角度選擇
- boolean f1_checkBox = false;
- boolean f2_checkBox = false;
- boolean f3_checkBox = false;
- boolean f4_checkBox = false;
- boolean f5_checkBox = false;
- boolean f6_checkBox = false;
- boolean f7_checkBox = false;
- boolean f8_checkBox = false;
- void CheckBoxHandle6(){
- if(CheckBox(20,180,f1_checkBox, "")== 1){
- f1_checkBox = (f1_checkBox == false) ? true: false;
- if(f1_checkBox == true){
- f1=1;
- }else{
- f1=0;
- if(CheckBox(60,180,f2_checkBox, "") == 1){
- f2_checkBox = (f2_checkBox == false) ? true: false;
- if(f2_checkBox == true){
- f2=1;
- }else{
- f2=0;
- if(CheckBox(100,180, f3_checkBox, "") == 1){
- f3_checkBox = (f3_checkBox == false) ? true: false;
- if(f3_checkBox == true){
- f3=1;
- }else{
- f3=0;
- if(CheckBox(140,180, f4_checkBox, "") == 1){
- f4_checkBox = (f4_checkBox == false) ? true: false;
- if(f4_checkBox == true){
- f4=1;
- }else{
- f4=0;
- if(CheckBox(180,180, f5_checkBox, "") == 1){
- f5_checkBox = (f5_checkBox == false) ? true: false;
- if(f5_checkBox == true){
- f5=1;
- }else{
- f5=0;
- if(CheckBox(220,180, f6_checkBox, "") == 1){
- f6_checkBox = (f6_checkBox == false) ? true: false;
- if(f6_checkBox == true){
- f6=1;
- }else{
- f6=0;
- if(CheckBox(260,180, f7_checkBox, "") == 1){
- f7_checkBox = (f7_checkBox == false) ? true: false;
- if(f7_checkBox == true){
- f7=1;
- }else{
- f7=0;
- if(CheckBox(300,180, f8_checkBox, "") == 1){
- f8_checkBox = (f8_checkBox == false) ? true: false;
- if(f8_checkBox == true){
- f8=1;
- }else{
- f8=0;
- boolean checkBox_Getf1Flag(){
- return f1_checkBox;
- boolean checkBox_Getf2Flag(){
- return f2_checkBox;
- boolean checkBox_Getf3Flag(){
- return f3_checkBox;
- boolean checkBox_Getf4lag(){
- return f4_checkBox;
- boolean checkBox_Getf5Flag(){
- return f5_checkBox;
- boolean checkBox_Getf6Flag(){
- return f6_checkBox;
- boolean checkBox_Getf7Flag(){
- return f7_checkBox;
- boolean checkBox_Getf8lag(){
- return f8_checkBox;
- //舵機角度選擇
- boolean g1_checkBox = false;
- boolean g2_checkBox = false;
- boolean g3_checkBox = false;
- boolean g4_checkBox = false;
- boolean g5_checkBox = false;
- boolean g6_checkBox = false;
- boolean g7_checkBox = false;
- boolean g8_checkBox = false;
- void CheckBoxHandle7(){
- if(CheckBox(20,210,g1_checkBox, "")== 1){
- g1_checkBox = (g1_checkBox == false) ? true: false;
- if(g1_checkBox == true){
- g1=1;
- }else{
- g1=0;
- if(CheckBox(60,210,g2_checkBox, "") == 1){
- g2_checkBox = (g2_checkBox == false) ? true: false;
- if(g2_checkBox == true){
- g2=1;
- }else{
- g2=0;
- if(CheckBox(100,210, g3_checkBox, "") == 1){
- g3_checkBox = (g3_checkBox == false) ? true: false;
- if(g3_checkBox == true){
- g3=1;
- }else{
- g3=0;
- if(CheckBox(140,210, g4_checkBox, "") == 1){
- g4_checkBox = (g4_checkBox == false) ? true: false;
- if(g4_checkBox == true){
- g4=1;
- }else{
- g4=0;
- if(CheckBox(180,210, g5_checkBox, "") == 1){
- g5_checkBox = (g5_checkBox == false) ? true: false;
- if(g5_checkBox == true){
- g5=1;
- }else{
- g5=0;
- if(CheckBox(220,210, g6_checkBox, "") == 1){
- g6_checkBox = (g6_checkBox == false) ? true: false;
- if(g6_checkBox == true){
- g6=1;
- }else{
- g6=0;
- if(CheckBox(260,210, g7_checkBox, "") == 1){
- g7_checkBox = (g7_checkBox == false) ? true: false;
- if(g7_checkBox == true){
- g7=1;
- }else{
- g7=0;
- if(CheckBox(300,210, g8_checkBox, "") == 1){
- g8_checkBox = (g8_checkBox == false) ? true: false;
- if(g8_checkBox == true){
- g8=1;
- }else{
- g8=0;
- boolean checkBox_Getg1Flag(){
- return g1_checkBox;
- boolean checkBox_Getg2Flag(){
- return g2_checkBox;
- boolean checkBox_Getg3Flag(){
- return g3_checkBox;
- boolean checkBox_Getg4lag(){
- return g4_checkBox;
- boolean checkBox_Getg5Flag(){
- return g5_checkBox;
- boolean checkBox_Getg6Flag(){
- return g6_checkBox;
- boolean checkBox_Getg7Flag(){
- return g7_checkBox;
- boolean checkBox_Getg8lag(){
- return g8_checkBox;
- //舵機角度選擇
- boolean h1_checkBox = false;
- boolean h2_checkBox = false;
- boolean h3_checkBox = false;
- boolean h4_checkBox = false;
- boolean h5_checkBox = false;
- boolean h6_checkBox = false;
- boolean h7_checkBox = false;
- boolean h8_checkBox = false;
- void CheckBoxHandle8(){
- if(CheckBox(20,240,h1_checkBox, "")== 1){
- h1_checkBox = (h1_checkBox == false) ? true: false;
- if(h1_checkBox == true){
- h1=1;
- }else{
- h1=0;
- if(CheckBox(60,240,h2_checkBox, "") == 1){
- h2_checkBox = (h2_checkBox == false) ? true: false;
- if(h2_checkBox == true){
- h2=1;
- }else{
- h2=0;
- if(CheckBox(100,240, h3_checkBox, "") == 1){
- h3_checkBox = (h3_checkBox == false) ? true: false;
- if(h3_checkBox == true){
- h3=1;
- }else{
- h3=0;
- if(CheckBox(140,240, h4_checkBox, "") == 1){
- h4_checkBox = (h4_checkBox == false) ? true: false;
- if(h4_checkBox == true){
- h4=1;
- }else{
- h4=0;
- if(CheckBox(180,240, h5_checkBox, "") == 1){
- h5_checkBox = (h5_checkBox == false) ? true: false;
- if(h5_checkBox == true){
- h5=1;
- }else{
- h5=0;
- if(CheckBox(220,240, h6_checkBox, "") == 1){
- h6_checkBox = (h6_checkBox == false) ? true: false;
- if(h6_checkBox == true){
- h6=1;
- }else{
- h6=0;
- if(CheckBox(260,240, h7_checkBox, "") == 1){
- h7_checkBox = (h7_checkBox == false) ? true: false;
- if(h7_checkBox == true){
- h7=1;
- }else{
- h7=0;
- if(CheckBox(300,240, h8_checkBox, "") == 1){
- h8_checkBox = (h8_checkBox == false) ? true: false;
- if(h8_checkBox == true){
- h8=1;
- }else{
- h8=0;
- boolean checkBox_Geth1Flag(){
- return h1_checkBox;
- boolean checkBox_Geth2Flag(){
- return h2_checkBox;
- boolean checkBox_Geth3Flag(){
- return h3_checkBox;
- boolean checkBox_Geth4lag(){
- return h4_checkBox;
- boolean checkBox_Geth5Flag(){
- return h5_checkBox;
- boolean checkBox_Geth6Flag(){
- return h6_checkBox;
- boolean checkBox_Geth7Flag(){
- return h7_checkBox;
- boolean checkBox_Geth8lag(){
- return h8_checkBox;
- byte CheckBox(float x, float y, boolean sL, String str){
- noFill();
- if(sL){
- fill(0,255,0);
- rect(x, y, 22, 22);
- textSize(16);
- fill(0);
- strokeWeight(2);
- text(str, x + 30, y + 20);
- if((mouseX > x) && (mouseY > y) && (mouseX < (x + 20) ) &&(mouseY < (y + 20))){
- return 1;
- return 0;
- void Serial_SetClick()
- click = 1;
