這個(gè)是我根據(jù)網(wǎng)上相關(guān)例程修改好的有關(guān)TM1638驅(qū)動(dòng)程序,程序可以實(shí)現(xiàn)數(shù)碼管驅(qū)動(dòng),3*3個(gè)按鍵的掃描以及16個(gè)LED的顯示控制!
實(shí)測(cè)程序可以在STC15F2K60S2芯片上正常工作!
2019-4-9 10:06 上傳
2019-4-9 10:07 上傳
- #include <TM1638_drive.h>
- //共陰數(shù)碼管段碼
- unsigned char code Num_tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
- 0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
- //TM1638低8段位碼 【SEG1-SEG8】
- unsigned char code WeiL_tab[]={0xce,0xcc,0xca,0xc8,0xc6,0xc4,0xc2,0xc0};
- //TM1638高2段位碼 【SEG9-SEG10】
- unsigned char code WeiH_tab[]={0xcf,0xcd,0xcb,0xc9,0xc7,0xc5,0xc3,0xc1};
- void TM1638_W_DATA(unsigned char DATA) //寫數(shù)據(jù)函數(shù)
- unsigned char i;
- for(i=0;i<8;i++)
- CLK=0;
- if(DATA&0X01)
- DIO=1;
- else
- DIO=0;
- DATA>>=1;
- CLK=1;
- void TM1638_W_CMD(unsigned char cmd) //寫命令函數(shù)
- STB=0;
- TM1638_W_DATA(cmd);
- STB=1;
- void Write_DATA(unsigned char add,unsigned char DATA) //指定地址寫入數(shù)據(jù)
- TM1638_W_CMD(0x44);
- STB=0;
- TM1638_W_DATA(add);
- TM1638_W_DATA(DATA);
- STB=1;
- unsigned char TM1638_Read(void) //讀數(shù)據(jù)函數(shù)
- unsigned char i;
- unsigned char temp=0;
- DIO=1; //設(shè)置為輸入
- for(i=0;i<8;i++)
- temp>>=1;
- CLK=0;
- CLK=1; //CLK上升沿讀數(shù)據(jù)才有效
- if(DIO)
- temp|=0x80;
- return temp;
- unsigned char Read_Onekey(void) //讀一下按鍵值,不支持組合鍵
- unsigned char key_val[4],i,key=0;
- STB=0;
- TM1638_W_DATA(0x42); //讀鍵掃數(shù)據(jù)命令 注意:這里要先讀完4字節(jié)鍵值才能將STB置1,否則讀鍵值無效
- for(i=0;i<4;i++)
- key_val[i]=TM1638_Read();
- STB=1; //4個(gè)字節(jié)數(shù)據(jù)合成一個(gè)字節(jié)
- if(key_val[0]!=0) //按鍵在KS1或KS2
- switch(key_val[0])
- case 1:
- key=K3S1;
- break;
- case 2:
- key=K2S1;
- break;
- case 4:
- key=K1S1;
- break;
- case 16:
- key=K3S2;
- break;
- case 32:
- key=K2S2;
- break;
- case 64:
- key=K1S2;
- break;
- else if(key_val[1]!=0) //按鍵在KS3或KS4
- switch(key_val[1])
- case 1:
- key=K3S3;
- break;
- case 2:
- key=K2S3;
- break;
- case 4:
- key=K1S3;
- break;
- case 16:
- key=K3S4;
- break;
- case 32:
- key=K2S4;
- break;
- case 64:
- key=K1S4;
- break;
- else if(key_val[2]!=0) //按鍵在KS5或KS6
- switch(key_val[2])
- case 1:
- key=K3S5;
- break;
- case 2:
- key=K2S5;
- break;
- case 4:
- key=K1S5;
- break;
- case 16:
- key=K3S6;
- break;
- case 32:
- key=K2S6;
- break;
- case 64:
- key=K1S6;
- break;
- else if(key_val[3]!=0) //按鍵在KS7或KS8
- switch(key_val[3])
- case 1:
- key=K3S7;
- break;
- case 2:
- key=K2S7;
- break;
- case 4:
- key=K1S7;
- break;
- case 16:
- key=K3S8;
- break;
- case 32:
- key=K2S8;
- break;
- case 64:
- key=K1S8;
- break;
- return key;
- void WriteSEG9_LED(unsigned char sta) //控制全部LED函數(shù),LED_flag表示各個(gè)LED狀態(tài)
- unsigned char i;
- for(i=0;i<8;i++)
- if(sta&(1<<i))
- Write_DATA(WeiH_tab[i],1);
- else
- Write_DATA(WeiH_tab[i],0);
- void WriteSEG10_LED(unsigned char sta) //控制全部LED函數(shù),LED_flag表示各個(gè)LED狀態(tài)
- unsigned char i;
- for(i=0;i<8;i++)
- if(sta&(1<<i))
- Write_DATA(WeiH_tab[i],2);
- else
- void Write_LED(unsigned char sta9,unsigned char sta10) //控制全部LED函數(shù),LED_flag表示各個(gè)LED狀態(tài)
- // 0b 1 0 0 0 0 0 0 0
- // 0b 0 1 1 0 0 0 0 0
- Write_DATA(WeiH_tab[7],((sta10&0x80)>>6)|((sta9&0x80)>>7));
- Write_DATA(WeiH_tab[6],((sta10&0x40)>>5)|((sta9&0x40)>>6));
- Write_DATA(WeiH_tab[5],((sta10&0x20)>>4)|((sta9&0x20)>>5));
- Write_DATA(WeiH_tab[4],((sta10&0x10)>>3)|((sta9&0x10)>>4));
- Write_DATA(WeiH_tab[3],((sta10&0x08)>>2)|((sta9&0x08)>>3));
- Write_DATA(WeiH_tab[2],((sta10&0x04)>>1)|((sta9&0x04)>>2));
- Write_DATA(WeiH_tab[1],(sta10&0x02)|((sta9&0x02)>>1));
- Write_DATA(WeiH_tab[0],((sta10&0x01)<<1)|(sta9&0x01));
- //TM1638初始化函數(shù)
- void init_TM1638(void)
- unsigned char i;
- TM1638_W_CMD(0x89); //亮度 (0x88-0x8f)8級(jí)亮度可調(diào)
- TM1638_W_CMD(0x40); //采用地址自動(dòng)加1
- STB=0; //
- TM1638_W_DATA(0xc0); //設(shè)置起始地址
- for(i=0;i<16;i++) //傳送16個(gè)字節(jié)的數(shù)據(jù)
- TM1638_W_DATA(0x00);
- STB=1;
2019-4-9 18:45 上傳
TM1638驅(qū)動(dòng).rar
(38.59 KB, 下載次數(shù): 260)
2019-4-9 10:09 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
