#include <reg52.h> //調(diào)用單片機(jī)頭文件
#define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
#define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
#include <intrins.h>
//數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0xdf,0xdb
// A B C D E F 不顯示
}; //斷碼
uchar dis_smg[8] = { 0 };
bit flag_100ms,flag_1s;
bit flag_stop = 1; //用做到了相應(yīng)的樓停下
sbit xia = P2^0;
sbit zhong = P2^1;
sbit shang = P2^2;
uchar value2;
uchar flag_start ; //啟動標(biāo)志位 1為起動步進(jìn)電機(jī) 否則關(guān)閉電機(jī)
uchar flag_z_f; //正反標(biāo)志位 0為順時鐘 1為逆時史上轉(zhuǎn)
sbit led1 = P1^7; //8個發(fā)光二極管定義
sbit led2 = P1^6;
sbit led3 = P1^5;
sbit led4 = P1^4;
sbit led5 = P1^3;
sbit led6 = P1^2;
sbit led7 = P1^1;
sbit led8 = P1^0;
sbit dj1 = P2^7; //電機(jī)IO口定義
sbit dj2 = P2^5; //電機(jī)IO口定義
sbit dj3 = P2^4; //電機(jī)IO口定義
sbit dj4 = P2^3; //電機(jī)IO口定義
uchar dt_1; //1樓電梯標(biāo)志位
uchar dt_2; //2樓電梯標(biāo)志位
uchar dt_3; //3樓電梯標(biāo)志位
uchar dt_4; //4樓電梯標(biāo)志位
uchar dt_5; //5樓電梯標(biāo)志位
uchar dt_6; //6樓電梯標(biāo)志位
uchar dt_7; //7樓電梯標(biāo)志位
uchar dt_8; //8樓電梯標(biāo)志位
uchar dt_value = 1; //電梯到哪一層的變量
uchar dt_s_x ; //電梯上下的標(biāo)志位
sbit VSDA = P3^7;
sbit VCS = P2^6;
sbit VSCL = P0^5;
void Delay(unsigned int i)//延時
while(--i);
/***********************小延時函數(shù)**************************/
void delay_us (unsigned int us)
while(us--)
_nop_();
/***********************正轉(zhuǎn)****************************/
void zheng(uchar dat)
switch(dat)
case 0: dj1=1;dj2=0;dj3=0;dj4=0; break;
case 1: dj1=0;dj2=1;dj3=0;dj4=0; break;
case 2: dj1=0;dj2=0;dj3=1;dj4=0; break;
case 3: dj1=0;dj2=0;dj3=0;dj4=1; break;
void fan(uchar dat)
switch(dat)
case 0: dj1=0;dj2=0;dj3=0;dj4=1; break;
case 1: dj1=0;dj2=0;dj3=1;dj4=0; break;
case 2: dj1=0;dj2=1;dj3=0;dj4=0; break;
case 3: dj1=1;dj2=0;dj3=0;dj4=0; break;
/***********************1ms延時函數(shù)*****************************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/***********************語音程序************************/
void Send_threelines(unsigned char addr)
unsigned char i;
VCS=0;
delay_1ms(5); /* 片選拉低5ms */
for(i=0;i<8;i++)
VSCL=0;
if(addr&0x01)
VSDA=1;
VSDA=0;
addr<<=1;
delay_us(150); /* 150us */
VSCL=1;
VCS=1;
delay_1ms(30);
/********************獨(dú)立按鍵程序*****************/
uchar key_can; //按鍵值
void key() //獨(dú)立按鍵程序
static uchar key_new;
key_can = 20; //按鍵值還原
P3 |= 0xff;
if(P3 != 0xff) //按鍵按下
delay_1ms(1); //按鍵消抖動
if((P3 != 0xff) && (key_new == 1))
{ //確認(rèn)是按鍵按下
key_new = 0;
switch(P3)
case 0xfe: key_can = 1; break; //得到按鍵值
case 0xfd: key_can = 2; break; //得到按鍵值
case 0xfb: key_can = 3; break; //得到按鍵值
case 0xf7: key_can = 4; break; //得到按鍵值
case 0xef: key_can = 5; break; //得到按鍵值
case 0xdf: key_can = 6; break; //得到按鍵值
case 0xbf: key_can = 7; break; //得到按鍵值
case 0x7f: key_can = 8; break; //得到按鍵值
key_new = 1;
void key_with()
if(key_can == 1)
led1 = 1; //點(diǎn)亮發(fā)光二極管
dt_1 = 1; //
if(key_can == 2)
led2 = 1; //點(diǎn)亮發(fā)光二極管
dt_2 = 1;
if(key_can == 3)
led3 = 1; //點(diǎn)亮發(fā)光二極管
dt_3 = 1;
if(key_can == 4)
led4 = 1; //點(diǎn)亮發(fā)光二極管
dt_4 = 1;
if(key_can == 5)
led5 = 1; //點(diǎn)亮發(fā)光二極管
dt_5 = 1;
if(key_can == 6)
led6 = 1; //點(diǎn)亮發(fā)光二極管
dt_6 = 1;
if(key_can == 7)
led7 = 1;
dt_7 = 1;
if(key_can == 8)
led8 = 1;
dt_8 = 1;
/*********************當(dāng)電梯不動時、判斷是向上、還是向下**********************/
void tiandi_shang_xia()
static uchar value;
if(dt_s_x == 0)
flag_stop = 1;
if(dt_value == 1) //電梯在第1層停下不走了
value = dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上
shang = 0; //顯示上
zhong = 0;
xia = 1;
if(dt_value == 2) //電梯在第2層停下不走了
value = dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 3) //電梯在第3層停下不走了
value = dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 4) //電梯在第4層停下不走了
value = + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 5) //電梯在第5層停下不走了
value = dt_6 + dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3 + dt_4;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 6) //電梯在第6層停下不走了
value = dt_7 + dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 7) //電梯在第7層停下不走了
value = dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_value == 8) //電梯在第8層停下不走了
value = dt_8;
if(value != 0)
dt_s_x = 1; //電梯向上走
shang = 0; //顯示上
zhong = 0;
xia = 1;
if(value != 0)
dt_s_x = 2; //電梯向下走
xia = 0; //顯示下
zhong = 0;
shang = 1;
if(dt_s_x == 1)
flag_start = 1 ; //運(yùn)行
flag_z_f = 0; //向上
if(dt_s_x == 2)
flag_z_f = 1; //向下
if(dt_s_x == 0)
flag_start = 0 ; //停下
flag_z_f = 1; //
/****************電梯向上、做最后的判斷是否還要繼續(xù)向上****************/
void dt_shang_guan()
uchar value;
if(dt_s_x == 1) //電梯向上 做最后的判斷是否還要繼續(xù)向上
if(dt_value == 1) //在第1層
if(value == 0) //說明上面沒有人按下
dt_s_x = 0; //電梯停下不動了
shang = 1; //關(guān)閉上字
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 2) //在第2層
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 3) //在第3層
value = + dt_6 + dt_7 + dt_8;
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 4) //在第4層
value = dt_5 + dt_6 + dt_7 + dt_8;
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 5) //在第5層
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 6) //在第6層
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 7) //在第7層
value = dt_8;
zhong = 1;
}else
flag_stop = 1;
else if(dt_value == 8) //在第8層
zhong = 1;
/****************電梯向下、做最后的判斷是否還要繼續(xù)向下****************/
void dt_xia_guan()
uchar value;
if(dt_s_x == 2) //電梯向下 做最后的判斷是否還要繼續(xù)向下
xia = 1; //關(guān)閉上字
zhong = 1;
flag_stop = 1;
value = dt_1;
zhong = 1;
}else
flag_stop = 1;
zhong = 1;
}else
flag_stop = 1;
value = dt_2 + dt_3;
zhong = 1;
}else
flag_stop = 1;
value = dt_1 + dt_2 + dt_4;
zhong = 1;
}else
flag_stop = 1;
zhong = 1;
}else
flag_stop = 1;
value = dt_1 + dt_2 + dt_4 + dt_5+ dt_6;
zhong = 1;
}else
flag_stop = 1;
value = dt_3 + dt_4 + dt_5 + dt_6 + dt_7;
zhong = 1;
}else
flag_stop = 1;
/***********************電梯處理函數(shù)************************/
void td_dis()
uchar value,value1;
value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
if(value != 0)
{ //100ms
if(flag_stop == 1) //到相應(yīng)的樓了 要停下
/***************************向上走電梯***********************************/
if(dt_s_x != 0) //向上走電梯
value1 ++;
if(value1 >= 10) //1s
value1 = 0;
if(dt_s_x == 1) //向上走電梯
dt_value ++;
shang = 0; //顯示上字
zhong = 0;
if(dt_s_x == 2) //向下走電梯
dt_value --;
xia = 0; //顯示下字
zhong = 0;
if(dt_value == 1) //當(dāng)?shù)搅说谝粚拥臅r候
if(dt_1 == 1)
led1 = 0; //關(guān)閉第一層發(fā)光二極管
dt_1 = 0; //清零電機(jī)在的標(biāo)志
flag_stop = 0; //到停下
Send_threelines(1) ; //1樓到了
else if(dt_value == 2) //當(dāng)?shù)搅说诙䦟拥臅r候
if(dt_2 == 1)
led2 = 0; //關(guān)閉第二層發(fā)光二極管
dt_2 = 0; //清零電機(jī)在的標(biāo)志
Send_threelines(2) ; //2樓到了 }
else if(dt_value == 3) //當(dāng)?shù)搅说?層的時候
if(dt_3 == 1)
led3 = 0; //關(guān)閉第3層發(fā)光二極管
dt_3 = 0; //清零電機(jī)在的標(biāo)志
Send_threelines(3) ; //3樓到了 }
else if(dt_value == 4) //當(dāng)?shù)搅说?層的時候
if(dt_4 == 1)
led4 = 0; //關(guān)閉第4層發(fā)光二極管
dt_4 = 0; //清零電機(jī)在的標(biāo)志
else if(dt_value == 5) //當(dāng)?shù)搅说?層的時候
if(dt_5 == 1)
led5 = 0; //關(guān)閉第5層發(fā)光二極管
dt_5 = 0; //清零電機(jī)在的標(biāo)志
Send_threelines(5) ; //5樓到了 }
else if(dt_value == 6) //當(dāng)?shù)搅说?層的時候
if(dt_6 == 1)
led6 = 0; //關(guān)閉第6層發(fā)光二極管
dt_6 = 0; //清零電機(jī)在的標(biāo)志
Send_threelines(6) ; //6樓到了 }
else if(dt_value == 7) //當(dāng)?shù)搅说?層的時候
if(dt_7 == 1)
led7 = 0; //關(guān)閉第7層發(fā)光二極管
dt_7 = 0; //清零電機(jī)在的標(biāo)志
Send_threelines(7) ; //7樓到了 }
else if(dt_value == 8) //當(dāng)?shù)搅说?層的時候
if(dt_8 == 1)
led8 = 0; //關(guān)閉第8層發(fā)光二極管
dt_8 = 0; //清零電機(jī)在的標(biāo)志
Send_threelines(8) ; //8樓到了 }
if(flag_stop == 0)
value2 ++;
if(value2 % 5 == 0)
if(dt_s_x == 1) //上
shang = ~shang;
zhong = ~zhong;
if(dt_s_x == 2) //下
zhong = ~zhong;
xia = ~xia;
if(value2 >= 20)
value2 = 0;
dt_shang_guan(); //電梯向上 做最后的判斷是否還要繼續(xù)向上
dt_xia_guan(); //電梯向下 做最后的判斷是否還要繼續(xù)向下
/*************定時器0初始化程序***************/
void time_init()
EA = 1; //開總中斷
TMOD = 0X01; //定時器0、工作方式1
ET0 = 1; //開定時器0中斷
TR0 = 1; //允許定時器0定時
/******************主程序**********************/
uchar i;
P1 = 0x00;
P0 = 0X00; //單片機(jī)IO口初始化
time_init(); //定時器初始化
key(); //按鍵程序
if(key_can < 20)
if(dt_s_x == 0)
value2 = 0;
flag_stop = 1;
key_with();
tiandi_shang_xia(); //當(dāng)電梯不動時、判斷是向上、還是向下
P0 = smg_du[dt_value]; //顯示
if(flag_100ms == 1)
flag_100ms = 0;
td_dis(); //電梯處理函數(shù)
if(flag_start == 1)
for(i=0;i<4;i++) //4相
if(flag_z_f == 0)
zheng(i); //電機(jī)正轉(zhuǎn)
fan(i); //電機(jī)反轉(zhuǎn)
Delay(650); //改變這個參數(shù)可以調(diào)整電機(jī)轉(zhuǎn)速
/*************定時器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
static uchar value;
TH0 = 0x3c;
TL0 = 0xb0; // 50ms
value ++;
if(value % 2 == 0)
flag_100ms = 1 ;
