20 黑幣
這是仿真電子秤
//線性區(qū)間標(biāo)度變換公式: y=(115-15)/(243-13)*X+15kpa
#include <AT89X52.h>
#include <intrins.h>
#include <stdio.h>
#define R24C04ADD 0xA1
#define W24C04ADD 0xA0
//ADC0832的引腳
sbit ADCS =P2^2; //ADC0832 chip seclect
sbit ADDI =P2^4; //ADC0832 k in
sbit ADDO =P2^4; //ADC0832 k out
sbit ADCLK =P2^3; //ADC0832 clock signal
sbit SDA = P2 ^ 1; //數(shù)據(jù)線
sbit SCL = P2 ^ 0; //時(shí)鐘線
bit bAck; //應(yīng)答標(biāo)志 當(dāng)bbAck=1是為正確的應(yīng)答
unsigned char dispbitcode[8]={0xf7,0xfb,0xfd,0xfe,0xef,0xdf,0xbf,0x7f}; //位掃描
unsigned char dispcode[11]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff}; //共陽(yáng)數(shù)碼管字段碼
unsigned char dispbuf[4];
unsigned int temp;
unsigned char getdata; //獲取ADC轉(zhuǎn)換回來(lái)的值
void delay_1ms(void) //12mhz delay 1.01ms
unsigned char x,y;
x=3;
while(x--)
y=40;
while(y--);
void display(void) //數(shù)碼管顯示函數(shù)
char k;
for(k=0;k<4;k++)
P1 = dispbitcode[k];
P0 = dispcode[dispbuf[k]];
if(k==1) //加上數(shù)碼管的dp小數(shù)點(diǎn)
P0&=0x7f;
delay_1ms();
讀ADC0832函數(shù)
//采集并返回
unsigned int Adc0832(unsigned char channel) //AD轉(zhuǎn)換,返回結(jié)果
unsigned char i=0;
unsigned char j;
unsigned int dat=0;
unsigned char ndat=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=1;
_nop_();
_nop_();
ADCS=0;//拉低CS端
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿1
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=channel&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿2
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=(channel>>1)&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿3
ADDI=1;//控制命令結(jié)束
_nop_();
_nop_();
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次時(shí)鐘脈沖
_nop_();
_nop_();
dat<<=1;
if(i==7)dat|=ADDO;
for(i=0;i<8;i++)
j=0;
j=j|ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
_nop_();
_nop_();
j=j<<7;
ndat=ndat|j;
if(i<7)ndat>>=1;
ADCS=1;//拉低CS端
ADCLK=0;//拉低CLK端
ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
dat<<=8;
dat|=ndat;
return(dat); //return ad k
//啟動(dòng)I2C總線,即發(fā)送起始條件
void StartI2C()
SDA = 1; //發(fā)送起始條件數(shù)據(jù)信號(hào)
_nop_();
SCL = 1;
_nop_(); //起始建立時(shí)間大于4.7us
_nop_();
_nop_();
_nop_();
_nop_();
SDA = 0; //發(fā)送起始信號(hào)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
SCL = 0; //時(shí)鐘操作
_nop_();
_nop_();
//結(jié)束I2C總線,即發(fā)送I2C結(jié)束條件
void StopI2C()
SDA = 0; //發(fā)送結(jié)束條件的數(shù)據(jù)信號(hào)
_nop_(); //發(fā)送結(jié)束條件的時(shí)鐘信號(hào)
SCL = 1; //結(jié)束條件建立時(shí)間大于4us
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
SDA = 1; //發(fā)送I2C總線結(jié)束命令
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
//發(fā)送一個(gè)字節(jié)的數(shù)據(jù)
void SendByte(unsigned char c)
unsigned char BitCnt;
for(BitCnt = 0;BitCnt < 8;BitCnt++) //一個(gè)字節(jié)
if((c << BitCnt)& 0x80) SDA = 1; //判斷發(fā)送位
else SDA = 0;
_nop_();
SCL = 1; //時(shí)鐘線為高,通知從機(jī)開始接收數(shù)據(jù)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
SCL = 0;
_nop_();
_nop_();
SDA = 1; //釋放數(shù)據(jù)線,準(zhǔn)備接受應(yīng)答位
_nop_();
_nop_();
SCL = 1;
_nop_();
_nop_();
_nop_();
if(SDA == 1) bAck =0;
else bAck = 1; //判斷是否收到應(yīng)答信號(hào)
SCL = 0;
_nop_();
_nop_();
//接收一個(gè)字節(jié)的數(shù)據(jù)
unsigned char RevByte()
unsigned char retc;
retc = 0;
SDA = 1;
for(BitCnt=0;BitCnt<8;BitCnt++)
_nop_();
SCL = 0; //置時(shí)鐘線為低,準(zhǔn)備接收
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
SCL = 1; //置時(shí)鐘線為高使得數(shù)據(jù)有效
_nop_();
_nop_();
retc = retc << 1; //左移補(bǔ)零
if (SDA == 1)
retc = retc + 1; //當(dāng)數(shù)據(jù)為1則收到的數(shù)據(jù)+1
_nop_();
_nop_();
SCL = 0;
_nop_();
_nop_();
return(retc); //返回收到的數(shù)據(jù)
//WChipAdd:寫器件地址;RChipAdd:讀器件地址;InterAdd:內(nèi)部地址;如寫正確則返回?cái)?shù)據(jù),
//否則返回對(duì)應(yīng)錯(cuò)誤步驟序號(hào)
//向指定器件的內(nèi)部指定地址發(fā)送一個(gè)指定字節(jié)
unsigned char WIICByte(unsigned char WChipAdd,unsigned char InterAdd,unsigned char WIICData)
StartI2C(); //啟動(dòng)總線
SendByte(WChipAdd); //發(fā)送器件地址以及命令
if (bAck==1) //收到應(yīng)答
SendByte(InterAdd); //發(fā)送內(nèi)部子地址
if (bAck ==1)
SendByte(WIICData); //發(fā)送數(shù)據(jù)
if(bAck == 1)
StopI2C(); //停止總線
return(0xff);
return(0x03);
return(0x02);
return(0x01);
//讀取指定器件的內(nèi)部指定地址一個(gè)字節(jié)數(shù)據(jù)
unsigned char RIICByte(unsigned char WChipAdd,unsigned char RChipAdd,unsigned char InterDataAdd)
unsigned char TempData;
TempData = 0;
SendByte(WChipAdd); //發(fā)送器件地址以及讀命令
SendByte(InterDataAdd); //發(fā)送內(nèi)部子地址
if (bAck ==1)
StartI2C();
SendByte(RChipAdd);
if(bAck == 1)
TempData = RevByte(); //接收數(shù)據(jù)
StopI2C(); //停止I2C總線
return(TempData); //返回?cái)?shù)據(jù)
return(0x03);
return(0x02);
return(0x01);
void main(void)
unsigned int OverCounter = 0;
unsigned char ptemp;
bit OverFlg = 0;
unsigned int temp,ppress = 0;
float press;
getdata=Adc0832(0);
if(14<getdata<243) //當(dāng)壓力值介于15kpa到115kpa之間時(shí),遵循線性變換
int vary=getdata; //y=(115-15)/(243-13)*X+15kpa
press=((10.0/23.0)*vary)+9.3; //測(cè)試時(shí)補(bǔ)償值為9.3
temp=(int)(press*10); //放大10倍,便于后面的計(jì)算
if(temp != ppress)
ppress = temp;
OverFlg = 1;
dispbuf[3]=temp/1000; //取壓力值百位
dispbuf[2]=(temp%1000)/100; //取壓力值十位
dispbuf[1]=((temp%1000)%100)/10; //取壓力值個(gè)位
dispbuf[0]=((temp%1000)%100)%10; //取壓力值十分位
display();
if (temp > 100)
if(OverFlg == 1) //如果是新的一輛車通過
OverCounter++;
WIICByte(W24C04ADD,0x01,(OverCounter/0xff)); //低位
WIICByte(W24C04ADD,0x02,(OverCounter%0xff)); //高位
// ptemp = printf("%f\n",OverCounter);
OverFlg = 0; //清除標(biāo)志
可加qq有償補(bǔ)助,謝謝大家
我來(lái)回答
