查看: 1735|回復(fù): 4
請教大佬為什么我這個藍牙小車程序電機不能自動停止
ID:447428 發(fā)表于 2019-4-15 21:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
20黑幣
#include<reg52.h>
uchar Buffer[4] = {0}; //?????????????
uint i,j;
sbit Z1=P2^2;  //???????
sbit Z2=P2^1;  //????????
sbit Y1=P2^3;  //???????
sbit Y2=P2^4;  //????????
sbit ENA=P2^0;
sbit ENB=P2^5;
sbit S1=P1^2;  //???????
sbit S2=P1^1;  //????????
sbit X1=P1^3;  //???????
sbit X2=P1^4;  //????????
sbit ENC=P1^0;
sbit END=P1^5;
bit Right_moto_stp=1;
bit Left_moto_stp =1;
bit Up_moto_stp=1;
bit Down_moto_stp=1;
uchar pwm_val_left=0;   //???????
uchar push_val_left=0;  //?????????N/20
uchar pwm_val_right=0;
uchar push_val_right=0; //?????????N/20
uchar pwm_val_up=0;
uchar pwm_val_down=0;
uchar push_val_up=0;
uchar push_val_down=0;
void stop();
void pwmint();
void pwmint(void)
        TMOD|=0X01;
        TH0= 0XFC; //2ms???
        TL0= 0X30;
        TR0= 1;
        ET0= 1;
        EA = 1;            //?????ж?
void Delay_1ms(uint i)//1ms???
uchar x,j;
for(j=0;j<i;j++)
for(x=0;x<=114;x++);
void Com_Int(void) interrupt 4
EA = 0;
if(RI == 1) //????????????????????RI????λ
Buffer[0] = SBUF - 48; //??????48???????????з??????????????ASCII??
RI = 0;
EA = 1;
void Com_Init(void)
TMOD = 0x20;
PCON = 0x00;
SCON = 0x50;
TH1 = 0xFd; //???ò????? 9600
TL1 = 0xFd;
TR1 = 1; //????????1
ES = 1; //???????ж?
EA = 1; //?????ж?
void run()
    push_val_left=5;
                push_val_right=5;
    push_val_up=3;
                push_val_down=5;
                Z1=0;Z2=1;
    Y1=0;Y2=1;
    S1=0;S2=1;
                X1=0;X2=1;
Delay_1ms(1000);
ENA=0;
ENB=0;
ENC=0;
END=0;
void back()
                push_val_left=5;
                push_val_right=5;
    push_val_up=3;
                push_val_down=5;
                Z1=1;Z2=0;
                Y1=1;Y2=0;
    S1=1;S2=0;
                X1=1;X2=0;
Delay_1ms(1000);
ENA=0;
ENB=0;
ENC=0;
END=0;
void stop()
Z1=0;Z2=0;
Y1=0;Y2=0;
S1=0;S2=0;
X1=0;X2=0;
Delay_1ms(100);
void pwm_out_left_moto(void) //????????,????push_val_left???????????,????
if(Left_moto_stp)
{if(pwm_val_left<=push_val_left)
{ ENB=1;}
  {ENB=0;}
{if(pwm_val_left>=20)
  {pwm_val_left=0;}
{ENB=0;}
void pwm_out_right_moto(void) //????????,????push_val_left???????????,????
if(Right_moto_stp)
if(pwm_val_right<=push_val_right)
{ENA=1;}
{ENA=0;}
if(pwm_val_right>=20)
{pwm_val_right=0;}
{ENA=0;}
void pwm_out_up_moto(void) //????????,????push_val_left???????????,????
if(Up_moto_stp)
{if(pwm_val_up<=push_val_up)
{ ENC=1;}
  {ENC=0;}
{if(pwm_val_up>=20)
  {pwm_val_up=0;}
{ENC=0;}
void pwm_out_down_moto(void) //????????,????push_val_left???????????,????
if(Down_moto_stp)
   if(pwm_val_down<=push_val_down)
   { END=1;}
     {END=0;}
   if(pwm_val_down>=20)
     {pwm_val_down=0;}
{END=0;}
void timer0 ()interrupt 1
                TH0=0XEC;     //5ms???
                TL0=0X30;
                pwm_val_left++;
                pwm_val_right++;
    pwm_val_up++;
    pwm_val_down++;
                pwm_out_left_moto();
                pwm_out_right_moto();
    pwm_out_up_moto();
    pwm_out_down_moto();
Delay_1ms(100);
Com_Init();//????????
pwmint();
stop();
switch(Buffer[0])
case 1: run(); break;
case 2: back();break;
case 3: stop(); break;
default:stop();break;
ID:123289 發(fā)表于 2019-4-16 13:06 | 只看該作者
你需要自己設(shè)立一個停止的條件,然后依條件停車。
ID:447428 發(fā)表于 2019-4-16 18:37 | 只看該作者
yzwzfyz 發(fā)表于 2019-4-16 13:06
我在run中延時之后已經(jīng)把使能端置零了,但還是停不下來
ID:481641 發(fā)表于 2019-5-13 16:28 | 只看該作者
程序問題多多調(diào)調(diào)
ID:511890 發(fā)表于 2019-5-14 03:02 | 只看該作者
你的Buffer[0]沒清理。。當有運行命令時,Buffer[0]=2,或者3。當命令消失時,要及時清理/重置Buffer[0]。這個步驟應(yīng)該是在while里面實現(xiàn)。
