以51單片機為內(nèi)核,水位傳感器檢測水位,電機驅動模塊驅動水泵,1602顯示,矩陣鍵盤控制電機轉速
2019-4-26 11:24 上傳
2019-4-20 23:54 上傳
單片機源程序如下:
- //#ifndef _Use_LCD1602B
- //# define _Use_LCD1602B
- * 系 統(tǒng) 宏 定 義 *
- * 常 數(shù) 宏 定 義 *
- #ifndef True
- # define True 0x01
- #endif
- #ifndef False
- # define False 0x00
- #endif
- #ifndef Enable
- # define Enable 0x01
- #endif
- #ifndef Disable
- # define Disable 0x00
- #endif
- #ifndef RunStringSpeed
- # define RunStringSpeed 100
- #endif
- #ifndef FlashTimeOut
- # define FlashTimeOut 500
- #endif
- #ifndef FlashGIFTimeOut
- # define FlashGIFTimeOut 1000
- #endif
- # define LCD_Write 0x00
- # define LCD_Read 0x01
- # define LCD_Command 0x00
- # define LCD_Data 0x01
- # define LCD_CMD_Init 0x28
- # define LCD_CMD_DispCtr 0x0c
- # define LCD_CMD_CLS 0x01
- # define LCD_CMD_EnterSet 0x06
- # define LCD_CMD_IconShow 0x0f
- # define LCD_CMD_IconHide 0x0c
- # define LCD_CMD_NotMove 0b00010100
- * 動 作 宏 定 義 *
- # define SetReadState LCD_SetReadData;LCD_RS = LCD_Command;LCD_RW = LCD_Read;
- # define SetRead LCD_SetReadData;LCD_RW = LCD_Read;
- # define SetWrite LCD_SetWriteData;LCD_RW = LCD_Write;
- # define SetCommand LCD_RS = LCD_Command;
- # define SetData LCD_RS = LCD_Data;
- # define Print(a) LCDDisplayString(a);
- # define Locate(x,y) LCDSetXY(x-1,y-1);
- # define CLS LCDWaitForReady();LCDSendCommand(LCD_CMD_CLS);
- # define PrintN(a,b) LCDDisplayNum((unsigned long)a,b);
- # define ShowIcon LCDWaitForReady();LCDSendCommand(LCD_CMD_IconShow);
- # define HideIcon LCDWaitForReady();LCDSendCommand(LCD_CMD_IconHide);
- * 全局變量聲明區(qū) *
- const char CHR[16] = {'0','1','2','3','4','5','6','7','8'
- ,'9','a','b','c','d','e','f'};
- extern unsigned int FlashTimeCounter;
- extern unsigned int RunTimeCounter;
- extern unsigned int FlashGIFStringCounter;
- * 系統(tǒng)函數(shù)聲明區(qū) *
- void LCDInit(void);
- void LCDSendCommand(char Command);
- void LCDSendData(char Data);
- void LCDWaitForReady(void);
- void LCDSetXY(char X,char Y);
- void LCDDisplayString(char *String);
- void LCDDisplayNum(unsigned long Num,char BitCount);
- void LCDDelay(unsigned int Time);
- void LCDDelayUs(unsigned int Time);
- void RunString(char *String,char Direction,char Y,char StartX,char EndX);
- void Flash(char *String,char Icon,char X,char Y);
- char StringLength(char *String);
- void FlashStringGroup(char String[][17],char StringCounter,char X,char Y);
- * 函數(shù)說明:LCD驅動類毫秒延時函數(shù) *
- * 輸入: 需要延時的大體毫秒數(shù) *
- unsigned int TimeCounter = 0;
- for (TimeCounter = 0;TimeCounter < Time;TimeCounter ++)
- LCDDelayUs(255);
- * 函數(shù)說明:LCD驅動指令周期延時函數(shù) *
- * 輸入: 需要大體延時Us數(shù) *
- asm("nop");
- * 函數(shù)說明:LCD初始化函數(shù) *
- LCDDelay(15);
- LCDWaitForReady();
- LCDSendCommand(LCD_CMD_Init);
- LCDSendCommand(LCD_CMD_DispCtr);
- LCDSendCommand(LCD_CMD_CLS);
- LCDDelay(2);
- LCDSendCommand(LCD_CMD_EnterSet);
- * 函數(shù)說明:向LCD發(fā)送指令函數(shù) *
- * 輸入: 需要發(fā)送的指令 *
- SetWrite;
- SetCommand;
- LCD_E = Enable;
- LCD_SendHalfCharHigh(Command);
- LCD_E = Disable;
- LCD_E = Enable;
- LCD_SendHalfCharLow(Command);
- LCD_E = Disable;
- SetRead;
- SetCommand;
- * 函數(shù)說明:向LCD發(fā)送數(shù)據(jù)函數(shù) *
- SetWrite;
- SetData;
- LCD_E = Enable;
- LCD_SendHalfCharHigh(Data);
- LCD_E = Disable;
- LCD_E = Enable;
- LCD_SendHalfCharLow(Data);
- LCD_E = Disable;
- SetRead;
- SetCommand;
- * 函數(shù)說明:等待LCD空閑狀態(tài)函數(shù) *
- #ifdef _Use_LCDOnlyWrite
- LCDDelayUs(30);
- #else
- SetRead;
- SetCommand;
- LCD_E = Enable;
- while (LCD_BF == Enable); //RW=1,讀PD7,為0表示空閑;
- LCD_E = Disable;
- #endif
- * 函數(shù)說明:設置顯示坐標函數(shù) *
- char Address;
- if (Y == 0)
- Address = 0x80 + X;
- else
- Address = 0xc0 + X;
- LCDSendCommand(Address);
- * 函數(shù)說明:LCD字符串顯示函數(shù) *
- while(*String)
- LCDSendData(*String);
- String++;
- * 函數(shù)說明:數(shù)值顯示函數(shù)(HEX) *
- * 輸入: 需要顯示的數(shù)字(無符號長整形) *
- char a = 0;
- for (a = 8-BitCount ;a<8;a++)
- LCDSendData(CHR[(Num<<(a<<2))>>28]);
- * 函數(shù)說明:滾屏字幕效果 *
- * 輸入: 需要滾屏的字符串 長度 位置 *
- static char StringHead = 0;
- char SCREEN[17];
- char a = 0;
- char Point = StringHead;
- char StringLong = StringLength(String);
- static int RunTimeCounter = 0;
- for (a = 0;a<EndX - StartX + 1;a++)
- SCREEN[a] = String[Point];
- Point ++;
- if (Point == StringLong)
- Point = 0;
- for (;a < 17;a++)
- SCREEN[a] =' ';
- RunTimeCounter ++;
- if (RunTimeCounter >RunStringSpeed)
- StringHead ++;
- RunTimeCounter = 0;
- if (StringHead == StringLong)
- StringHead = 0;
- Locate(StartX,Y)
- Print(SCREEN)
- * 函數(shù)說明:字符串長度測試函數(shù) *
- char n = 0;
- while (*String)
- n++;
- String ++;
- return n;
- * 函數(shù)說明:閃爍顯示函數(shù) *
- char a = 0;
- if (FlashTimeCounter % FlashTimeOut > (FlashTimeOut >> 1))
- Locate(X,Y)
- Print(String)
- else
- for (a = X ;a < X+StringLong;a++)
- Locate(a,Y)
復制代碼
源代碼.rar
(35.93 KB, 下載次數(shù): 37)
2019-4-15 23:41 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
