查看: 5455|回復(fù): 1
MPU6050卡爾曼濾波Arduino代碼
Arduino源程序:(MPU6050芯片卡爾曼濾波)
  1. #include "Wire.h"
  2. #include "I2Cdev.h"
  3. #include "MPU6050.h"
  4. MPU6050 accelgyro;
  5. unsigned long now, lastTime = 0;
  6. float dt;                                   //微分時(shí)間
  7. int16_t ax, ay, az, gx, gy, gz;             //加速度計(jì)陀螺儀原始數(shù)據(jù)
  8. float aax=0, aay=0, agx=0, agy=0, agz=0;    //角度變量
  9. long axo = 0, ayo = 0, azo = 0;             //加速度計(jì)偏移量
  10. long gxo = 0, gyo = 0, gzo = 0;             //陀螺儀偏移量
  11. float pi = 3.1415926;
  12. float AcceRatio = 16384.0;                  //加速度計(jì)比例系數(shù)
  13. float GyroRatio = 131.0;                    //陀螺儀比例系數(shù)
  14. uint8_t n_sample = 8;                       //加速度計(jì)濾波算法采樣個(gè)數(shù)
  15. float aaxs[8] = {0}, aays[8] = {0};         //x,y軸采樣隊(duì)列
  16. long aax_sum, aay_sum;                      //x,y軸采樣和
  17. float a_x[10]={0}, a_y[10]={0} ,g_x[10]={0} ,g_y[10]={0}; //加速度計(jì)協(xié)方差計(jì)算隊(duì)列
  18. float Px=1, Rx, Kx, Sx, Vx, Qx;             //x軸卡爾曼變量
  19. float Py=1, Ry, Ky, Sy, Vy, Qy;             //y軸卡爾曼變量
  20. void setup() {
  21.   Wire.begin();
  22.   Serial.begin(9600);
  23.   accelgyro.initialize();                 //初始化
  24.   unsigned short times = 200;             //采樣次數(shù)
  25.   for(int i=0;i<times;i++){
  26.     accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); //讀取六軸原始數(shù)值
  27.     axo += ax; ayo += ay; azo += az;      //采樣和
  28.     gxo += gx; gyo += gy; gzo += gz;
  29.   }
  30.   axo /= times; ayo /= times; azo /= times; //計(jì)算加速度計(jì)偏移
  31.   gxo /= times; gyo /= times; gzo /= times; //計(jì)算陀螺儀偏移
  32. }
  33. void loop(){
  34.   unsigned long now = millis();             //當(dāng)前時(shí)間(ms)
  35.   dt = (now - lastTime) / 1000.0;           //微分時(shí)間(s)
  36.   lastTime = now;                           //上一次采樣時(shí)間(ms)
  37.   accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); //讀取六軸原始數(shù)值
  38.   float accx = ax / AcceRatio;              //x軸加速度
  39.   float accy = ay / AcceRatio;              //y軸加速度
  40.   float accz = az / AcceRatio;              //z軸加速度
  41.   aax = atan(accy / accz) * (-180) / pi;    //x軸對(duì)于水平面的夾角
  42.   aay = atan(accx / accz) * 180 / pi;       //y軸對(duì)于水平面的夾角
  43.   aax_sum = 0;                              // 對(duì)于加速度計(jì)原始數(shù)據(jù)的滑動(dòng)加權(quán)濾波算法
  44.   aay_sum = 0;
  45.   for(int i=1;i<n_sample;i++){
  46.     aaxs[i-1] = aaxs[i];
  47.     aax_sum += aaxs[i] * i;
  48.     aays[i-1] = aays[i];
  49.     aay_sum += aays[i] * i;
  50.   }
  51.   aaxs[n_sample-1] = aax;
  52.   aax_sum += aax * n_sample;
  53.   aax = (aax_sum / (11*n_sample/2.0)) * 9 / 7.0; //角度調(diào)幅至0-90°
  54.   aays[n_sample-1] = aay;                        //此處應(yīng)用實(shí)驗(yàn)法取得合適的系數(shù)
  55.   aay_sum += aay * n_sample;                     //本例系數(shù)為9/7
  56.   aay = (aay_sum / (11*n_sample/2.0)) * 9 / 7.0;
  57.   float gyrox = - (gx-gxo) / GyroRatio * dt; //x軸角速度
  58.   float gyroy = - (gy-gyo) / GyroRatio * dt; //y軸角速度
  59.   agx += gyrox;                             //x軸角速度積分
  60.   agy += gyroy;                             //x軸角速度積分
  61.   /* kalmen start */
  62.   Sx = 0; Rx = 0;
  63.   Sy = 0; Ry = 0;
  64.   for(int i=1;i<10;i++){                 //測量值平均值運(yùn)算
  65.     a_x[i-1] = a_x[i];                      //即加速度平均值
  66.     Sx += a_x[i];
  67.     a_y[i-1] = a_y[i];
  68.     Sy += a_y[i];
  69.   }
  70.   a_x[9] = aax;
  71.   Sx += aax;
  72.   Sx /= 10;                                 //x軸加速度平均值
  73.   a_y[9] = aay;
  74.   Sy += aay;
  75.   Sy /= 10;                                 //y軸加速度平均值
  76.   for(int i=0;i<10;i++){
  77.     Rx += sq(a_x[i] - Sx);
  78.     Ry += sq(a_y[i] - Sy);
  79.   }
  80.   Rx = Rx / 9;                              //得到方差
  81.   Ry = Ry / 9;
  82.   Px = Px + 0.0025;                         // 0.0025在下面有說明...
  83.   Kx = Px / (Px + Rx);                      //計(jì)算卡爾曼增益
  84.   agx = agx + Kx * (aax - agx);             //陀螺儀角度與加速度計(jì)速度疊加
  85.   Px = (1 - Kx) * Px;                       //更新p值
  86.   Py = Py + 0.0025;
  87.   Ky = Py / (Py + Ry);
  88.   agy = agy + Ky * (aay - agy);
  89.   Py = (1 - Ky) * Py;
  90.   /* kalmen end */
  91.   Serial.print(agx);Serial.print(",");
  92.   Serial.print(agy);Serial.println();
  93. }
全部資料51hei下載地址:
MPU6050卡爾曼濾波代碼.zip (1.74 KB, 下載次數(shù): 61)
收藏收藏2 分享淘帖 頂 踩
ID:1 發(fā)表于 2019-4-17 14:43 | 只看該作者
本帖需要重新編輯補(bǔ)全頭文件 電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
