用stm32cubemx配置的,單片機(jī)是stm32f103v8t6,采用普通i/o模式判斷按鍵,一個(gè)按鍵控制LED亮,一個(gè)控制滅,我就貼上主要的代碼,供學(xué)習(xí)HAL庫(kù)的朋友學(xué)習(xí),我也剛開(kāi)始學(xué),stm32cubemx的配置文件也在這個(gè)文件里面
void MX_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(LED_GPIO_Port, LED_Pin, GPIO_PIN_RESET);
/*Configure GPIO pin : PtPin */
GPIO_InitStruct.Pin = KEY1_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(KEY1_GPIO_Port, &GPIO_InitStruct);
GPIO_InitStruct.Pin = LED_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(LED_GPIO_Port, &GPIO_InitStruct);
GPIO_InitStruct.Pin = KEY0_Pin;
HAL_GPIO_Init(KEY0_GPIO_Port, &GPIO_InitStruct);
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
if( HAL_GPIO_ReadPin(KEY0_GPIO_Port, KEY0_Pin)==0)//讀一個(gè)引腳的電平,判斷key0是否按下
HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_RESET);//LED滅
while(!HAL_GPIO_ReadPin(KEY0_GPIO_Port, KEY0_Pin));//松手檢測(cè)
// HAL_GPIO_TogglePin (LED_GPIO_Port, LED_Pin );
if( HAL_GPIO_ReadPin(KEY1_GPIO_Port, KEY1_Pin)==0)//判斷key0是否按下
HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_SET);//LED亮
while(!HAL_GPIO_ReadPin(KEY1_GPIO_Port, KEY1_Pin));//松手檢測(cè)
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
全部資料51hei下載地址:
KEY.7z
(602.91 KB, 下載次數(shù): 42)
2019-4-19 17:39 上傳
點(diǎn)擊文件名下載附件
