TMS320F28335的例程,適合新手學(xué)習(xí)
2019-4-18 23:20 上傳
ZQ28335_examples.7z
(2 MB, 下載次數(shù): 87)
2019-4-18 23:23 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
- // FILE: Example_2833xAdcToDMA.c
- // TITLE: DSP2833x ADC To DMA
- // ASSUMPTIONS:
- // This program requires the DSP2833x header files.
- // Make sure the CPU clock speed is properly defined in
- // DSP2833x_Examples.h before compiling this example.
- // Connect the signals to be converted to channel A0, A1, A2, and A3.
- // As supplied, this project is configured for "boot to SARAM"
- // operation. The 2833x Boot Mode table is shown below.
- // For information on configuring the boot mode of an eZdsp,
- // please refer to the documentation included with the eZdsp,
- // $Boot_Table:
- // GPIO87 GPIO86 GPIO85 GPIO84
- // XA15 XA14 XA13 XA12
- // PU PU PU PU
- // 1 1 1 1 Jump to Flash
- // 1 1 1 0 SCI-A boot
- // 1 1 0 1 SPI-A boot
- // 1 1 0 0 I2C-A boot
- // 1 0 1 1 eCAN-A boot
- // 1 0 1 0 McBSP-A boot
- // 1 0 0 1 Jump to XINTF x16
- // 1 0 0 0 Jump to XINTF x32
- // 0 1 1 1 Jump to OTP
- // 0 1 1 0 Parallel GPIO I/O boot
- // 0 1 0 1 Parallel XINTF boot
- // 0 1 0 0 Jump to SARAM <- "boot to SARAM"
- // 0 0 1 1 Branch to check boot mode
- // 0 0 1 0 Boot to flash, bypass ADC cal
- // 0 0 0 1 Boot to SARAM, bypass ADC cal
- // 0 0 0 0 Boot to SCI-A, bypass ADC cal
- // Boot_Table_End$
- // DESCRIPTION:
- // ADC is setup to convert 4 channels for each SOC received, with total of 10 SOCs.
- // Each SOC initiates 4 conversions.
- // DMA is set up to capture the data on each SEQ1_INT. DMA will re-sort
- // the data by channel sequentially, i.e. all channel0 data will be together
- // all channel1 data will be together.
- // Code should stop in local_DINTCH1_ISR when complete
- // Watch Variables:
- // DMABuf1
- // Original source by: M.P.
- // $TI Release: DSP2833x Header Files V1.01 $
- // $Release Date: September 26, 2007 $
- #include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
- #include "DSP2833x_Examples.h" // DSP2833x Examples Include File
- // ADC start parameters
- #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT
- #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz
- #endif
- #if (CPU_FRQ_100MHZ)
- #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz
- #endif
- #define ADC_CKPS 0x1 // ADC module clock = HSPCLK/2*ADC_CKPS = 25.0MHz/(1*2) = 12.5MHz
- #define ADC_SHCLK 0xf // S/H width in ADC module periods = 16 ADC clocks
- #define AVG 1000 // Average sample limit
- #define ZOFFSET 0x00 // Average Zero offset
- #define BUF_SIZE 160 // Sample buffer size
- // Global variable for this example
- Uint16 j = 0,ADC_END = 0; // ADC finish flag
- #pragma DATA_SECTION(ADC_Result,"DMARAML4");
- volatile float ADC_Result[160];
- #pragma DATA_SECTION(DMABuf1,"DMARAML4");
- volatile Uint16 DMABuf1[160];
- volatile Uint16 *DMADest;
- volatile Uint16 *DMASource;
- interrupt void local_DINTCH1_ISR(void);
- void main(void)
- Uint16 i;
- // Step 1. Initialize System Control:
- // PLL, WatchDog, enable Peripheral Clocks
- // This example function is found in the DSP2833x_SysCtrl.c file.
- InitSysCtrl();
- // Specific clock setting for this example:
- EALLOW;
- SysCtrlRegs.HISPCP.all = ADC_MODCLK; // HSPCLK = SYSCLKOUT/ADC_MODCLK
- EDIS;
- // Step 2. Initialize GPIO:
- // This example function is found in the DSP2833x_Gpio.c file and
- // illustrates how to set the GPIO to it's default state.
- // InitGpio(); // Skipped for this example
- // Step 3. Clear all interrupts and initialize PIE vector table:
- // Disable CPU interrupts
- DINT;
- // Initialize the PIE control registers to their default state.
- // The default state is all PIE interrupts disabled and flags
- // are cleared.
- // This function is found in the DSP2833x_PieCtrl.c file.
- InitPieCtrl();
- // Disable CPU interrupts and clear all CPU interrupt flags:
- IER = 0x0000;
- IFR = 0x0000;
- // Initialize the PIE vector table with pointers to the shell Interrupt
- // Service Routines (ISR).
- // This will populate the entire table, even if the interrupt
- // is not used in this example. This is useful for debug purposes.
- // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
- // This function is found in DSP2833x_PieVect.c.
- InitPieVectTable();
- // Interrupts that are used in this example are re-mapped to
- // ISR functions found within this file.
- EALLOW; // Allow access to EALLOW protected registers
- PieVectTable.DINTCH1= &local_DINTCH1_ISR;
- EDIS; // Disable access to EALLOW protected registers
- IER = M_INT7 ; //Enable INT7 (7.1 DMA Ch1)
- EnableInterrupts();
- // Step 4. Initialize all the Device Peripherals:
- // This function is found in DSP2833x_InitPeripherals.c
- // InitPeripherals(); // Not required for this example
- InitAdc(); // For this example, init the ADC
- // Specific ADC setup for this example:
- AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;
- AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
- AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 0 Non-Cascaded Mode; 1 Cascaded Mode
- AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 0x1;
- AdcRegs.ADCTRL2.bit.RST_SEQ1 = 0x1;
- AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0;
- AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x1;
- AdcRegs.ADCCHSELSEQ1.bit.CONV02 = 0x2;
- AdcRegs.ADCCHSELSEQ1.bit.CONV03 = 0x3;
- AdcRegs.ADCCHSELSEQ2.bit.CONV04 = 0x4;
- AdcRegs.ADCCHSELSEQ2.bit.CONV05 = 0x5;
- AdcRegs.ADCCHSELSEQ2.bit.CONV06 = 0x6;
- AdcRegs.ADCCHSELSEQ2.bit.CONV07 = 0x7;
- AdcRegs.ADCCHSELSEQ3.bit.CONV08 = 0x8;
- AdcRegs.ADCCHSELSEQ3.bit.CONV09 = 0x9;
- AdcRegs.ADCCHSELSEQ3.bit.CONV10 = 0xA;
- AdcRegs.ADCCHSELSEQ3.bit.CONV11 = 0xB;
- AdcRegs.ADCCHSELSEQ4.bit.CONV12 = 0xC;
- AdcRegs.ADCCHSELSEQ4.bit.CONV13 = 0xD;
- AdcRegs.ADCCHSELSEQ4.bit.CONV14 = 0xE;
- AdcRegs.ADCCHSELSEQ4.bit.CONV15 = 0xF;
- AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 15; // Set up ADC to perform 4 conversions for every SOC
- //Step 5. User specific code, enable interrupts:
- // Initialize DMA
- DMAInitialize();
- // Clear Table
- for (i=0; i<BUF_SIZE; i++)
- DMABuf1[i] = 0xffff;
- // Configure DMA Channel
- DMADest = &DMABuf1[0]; //Point DMA destination to the beginning of the array
- DMASource = &AdcMirror.ADCRESULT0; //Point DMA source to ADC result register base
- DMACH1AddrConfig(DMADest,DMASource);
- DMACH1BurstConfig(15,1,10);
- DMACH1TransferConfig(9,-15,(-150 + 1));
- DMACH1WrapConfig(100,100,100,100); //Don't use wrap function
- DMACH1ModeConfig(DMA_SEQ1INT,PERINT_ENABLE,ONESHOT_DISABLE,CONT_DISABLE,SYNC_DISABLE,SYNC_SRC,
- OVRFLOW_DISABLE,SIXTEEN_BIT,CHINT_END,CHINT_ENABLE);
- StartDMACH1();
- // Start SEQ1
