查看: 4270|回復(fù): 3
MAX31865 串口讀出數(shù)據(jù)為0 求教
ID:307274 發(fā)表于 2019-4-21 11:33 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
問有用51單片機(jī)與MAX31865模擬SPI通信的嗎,通過串口助手在電腦上顯示始終為0x00,希望有人能給指導(dǎo)一下,幫我看看是不是程序的問題
#include<reg52.h>
#include<intrins.h>
sbit SDI=P2^0;
sbit SCLK=P2^1;
sbit CS=P2^2;
sbit DRDY=P2^3;
sbit SDO=P2^4;
uchar i=0;
float temps;
void Delay(uint nCount)
for(; nCount != 0; nCount--);
uchar MAX31865_Read(uchar addr)    //SPI Single-Byte Read
    uchar read = 0;
    CS=0;
    //SCLK=1;
    Delay(0x1f);
for(i = 0; i < 8; i++)
  SCLK=1;
  if (addr & 0x80){SDI=1;}
  else {SDI=0;}
  Delay(0x1f);
  SCLK=0;
  addr <<= 1;
  Delay(0x1f);
Delay(0x1f);
  SCLK=1;
  read = read<<1;
  Delay(0x1f);
  if(SDO){read++;}
  SCLK=0;
  Delay(0x1f);
CS=1;
    return read;
void MAX31865_Write(uchar addr,uchar wdata)//SPI Single-Byte Write
CS=0;
Delay(0x1f);
for(i = 0; i< 8; i++)
  SCLK=1;
  else {SDI=0;}
  Delay(0x1f);
  SCLK=0;
  addr <<= 1;
  Delay(0x1f);
  SCLK=1;
  if (wdata & 0x80){SDI=1;}
  else {SDI=0;}
  Delay(0x1f);
  SCLK=0;
  wdata <<= 1;
  Delay(0x1f);
CS=1;
void MAX31865_Init(void)
MAX31865_Write(0x80,0xd1);
Delay(0x1f);
CS=1;
SCLK=1;
void UART_send_byte(uchar dat)
SBUF=dat;
while(TI==0);
TI=0;
uchar Get_tempture(void)
uint dtemp[2];
uint data_temp;
dtemp[0]=MAX31865_Read(0x01);
dtemp[1]=MAX31865_Read(0x02);
data_temp=(dtemp[0]<<7)+(dtemp[1]>>1);      //Get 15Bit DATA
//temps=(data_temp*402)/32768.0;                     //Here is the rtd R value;
//temps=(temps-100)/0.385055;               //temperature
temps=data_temp/32.0-256;
return temps;
void configUART()
TMOD&=0X0F;
TMOD|=0x20;
SCON=0X50;
TH1=0Xfd;
TL1=TH1;
ET1=0;
TR1=1;
configUART();
MAX31865_Init();
Delay(0xff);
  Delay(0xff);
  UART_send_byte(Get_tempture());
ID:478261 發(fā)表于 2019-7-4 23:42 | 只看該作者
你好,請(qǐng)問這個(gè)問題解決了嗎?我遇到同樣的問題了
ID:275742 發(fā)表于 2020-5-17 20:05 | 只看該作者
這里提供51和stm32的例程,可以點(diǎn)擊鏈接看看
MAX31865 RTD鉑電阻溫度檢測(cè)器 PT100至PT1000傳感器模塊-那個(gè)寶搜索這個(gè)
ID:140644 發(fā)表于 2024-1-16 08:12 | 只看該作者
中斷EA呢
