附件是我的電子秤的實現(xiàn)程序,還加有關(guān)于32的無線傳輸是如何進(jìn)行傳輸?shù)摹?br />
單片機源程序如下:
[code]#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "lcd.h"
#include "spi.h"
#include "key.h"
#include "24l01.h"
#include "HX711.h"
#include "dht11.h"
//程序需要學(xué)習(xí),學(xué)習(xí)永無止境
//要寫入到W25Q16的字符串?dāng)?shù)組
const u8 TEXT_Buffer[]={"Explorer STM32F4 SPI TEST"};
#define SIZE sizeof(TEXT_Buffer)
void Send_Name();
char *itoa(); //
// int d=500; //
char buff[];
int main(void)
u8 humidity;
u8 jiage;
u8 temperature;
u8 key;
float mode;
u8 tmp_buf[33];
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
delay_init(168); //初始化延時函數(shù)
uart_init(115200); //初始化串口波特率為115200
Init_HX711pin();
LED_Init(); //初始化LED
LCD_Init(); //LCD初始化
KEY_Init(); //按鍵初始化
NRF24L01_Init(); //初始化NRF24L01
Get_Maopi(); //稱毛皮重量
delay_ms(1000);
delay_ms(1000);
Get_Maopi(); //重新獲取毛皮重量
POINT_COLOR=RED;//設(shè)置字體為紅色
LCD_ShowString(30,50,200,16,16,"Explorer STM32F4");
DHT11_Read_Data(&temperature,&humidity); //讀取溫濕度值
LCD_ShowString(30,230,200,16,16,"temperature");
LCD_ShowNum(130,230,temperature,7,16);//顯示溫度
// LCD_ShowString(30,70,200,16,16,"NRF24L01 TEST");
LCD_ShowString(30,110,200,16,16,"ATOM@ALIENTEK");
LCD_ShowString(30,130,200,16,16,"2014/5/9");
key=KEY_Scan(0);
if(key==KEY0_PRES)
delay_ms(5);
mode=0.8;
break;
}else if(key==KEY1_PRES)
delay_ms(5);
mode=0.5;
break;
break;
Get_Weight();
// LCD_ShowNum(30,70,(u8)Weight_Shiwu,7,16);
////////// printf("凈重量 = %d g\r\n",Weight_Shiwu); //打印
////////// delay_ms(500);
////////// LCD_ShowString(30,70,200,16,16,"food weight");
Weight_Shiwu=Weight_Shiwu*0.25;
////////// LCD_Fill(130,70,lcddev.width,170+16*3,WHITE);
////////// LCD_ShowNum(130,70,Weight_Shiwu,7,16);
jiage=Weight_Shiwu*mode;
//// LCD_ShowString(30,90,200,16,16,"food price");
LCD_ShowNum(130,90,jiage,7,16);
itoa(jiage, buff, 10);
Send_Name(buff);//"buff"
delay_ms(50);
void Send_Name(u8 tmp_buf[36])
while(NRF24L01_Check())
LCD_ShowString(30,150,200,16,16,"NRF24L01 Error");
delay_ms(200);
LCD_Fill(30,150,239,130+16,WHITE);
delay_ms(200);
LCD_ShowString(30,150,200,16,16,"NRF24L01 OK");
LCD_Fill(10,170,240,166,WHITE);//清空上面的顯示
POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
LCD_ShowString(30,170,200,16,16,"NRF24L01 TX_Mode");
NRF24L01_TX_Mode();
if(NRF24L01_TxPacket(tmp_buf)==TX_OK)
LCD_Fill(0,210,lcddev.width,170+16*3,WHITE);//清空顯示
LCD_ShowString(30,190,239,32,16,"Sended DATA:");
LCD_ShowString(30,210,lcddev.width-1,32,16,tmp_buf);
}else
LCD_Fill(0,190,lcddev.width,170+16*3,WHITE);//清空顯示
LCD_ShowString(30,190,lcddev.width-1,32,16,"Send Failed ");
LED0=!LED0;
delay_ms(300);
break;
char *itoa(int value, char *string, int radix)
radix=10 ???10?? ????,?????0;
?:d=-379;
?? itoa(d, buf, 10); ?
buf="-379"
int i, d;
int flag = 0;
char *ptr = string;
/* This implementation only works for decimal numbers. */
if (radix != 10)
*ptr = 0;
return string;
if (!value)
*ptr++ = 0x30;
*ptr = 0;
return string;
/* if this is a negative value insert the minus sign. */
if (value < 0)
*ptr++ = '-';
/* Make the value positive. */
value *= -1;
for (i = 10000; i > 0; i /= 10)
d = value / i;
if (d || flag)
*ptr++ = (char)(d + 0x30);
value -= (d * i);
flag = 1;
/* Null terminate the string. */
*ptr = 0;
return string;
int atoi_my(const char *str)
int s=0;
int falg=0;
while(*str==' ')
str++;
if(*str=='-'||*str=='+')
if(*str=='-')
falg=1;
str++;
while(*str>='0'&&*str<='9')
s=s*10+*str-'0';
…………限于本文篇幅 余下代碼請從51黑下載附件…………
[/code]
智能電子秤.7z
(350.78 KB, 下載次數(shù): 12)
2019-4-28 16:45 上傳
點擊文件名下載附件
