avr單片機,基于ATmega88+nRF24L01p+oLED
可移植性極高
完整的接收和發(fā)送程序
2019-4-23 15:38 上傳
單片機源程序如下:
- #define _nRF24L01_C_
- #include "nRF24L01.h"
- INT8U CE_Status = 0;
- Function : L01_GetCEStatus( )
- Description : Get the status of the CE PIN
- Input : NONE
- Output: 1:CE=1, 0:CE=0
- INT8U L01_GetCEStatus( void )
- return CE_Status;
- Function : L01_SetCE( )
- Description : Set the CE PIN as 1 or 0
- Input : -status, 1: CE=1, 0: CE=0
- Output: None
- void L01_SetCE( INT8U status )
- CE_Status = status;
- if( status == 0 ) { L01_CE_LOW( ); }
- else { L01_CE_HIGH( ); }
- Function : L01_ReadSingleReg( )
- Description : Read a single register of nRF24L01
- Input : -Addr, The address of the register
- Output: The value read from the register
- INT8U L01_ReadSingleReg( INT8U Addr )
- INT8U btmp;
- L01_CSN_LOW( );//PB2輸出低電平
- SPI_ExchangeByte( R_REGISTER | Addr );
- btmp = SPI_ExchangeByte( 0xFF );
- L01_CSN_HIGH( );//PB2輸出高電平
- return btmp;
- Function : L01_ReadMultiReg( )
- Description : Read several registers of nRF24L01
- Input : -StartAddr, The start address of the registers
- -nBytes, How many registers do you want to read
- -pBuff, The buffer to save the values
- Output: None
- /*void L01_ReadMultiReg( INT8U StartAddr, INT8U nBytes, INT8U *pBuff )
- INT8U btmp;
- L01_CSN_LOW( );
- SPI_ExchangeByte( R_REGISTER | StartAddr );
- for( btmp = 0; btmp < nBytes; btmp ++ )
- *( pBuff + btmp ) = SPI_ExchangeByte( 0xFF );
- L01_CSN_HIGH( );
- Function : L01_WriteSingleReg( )
- Description : Write a single byte to a register
- -Value, The value to be written
- Output: None
- void L01_WriteSingleReg( INT8U Addr, INT8U Value )
- INT8U tmp = L01_GetCEStatus( );
- L01_SetCE( 0 );
- L01_CSN_LOW( );
- SPI_ExchangeByte( W_REGISTER | Addr );
- SPI_ExchangeByte( Value );
- L01_CSN_HIGH( );
- L01_SetCE( tmp );
- Function : L01_WriteMultiReg( )
- -pBuff, The buffer store the values
- -Length, How many registers do you want to write
- Output: None
- void L01_WriteMultiReg( INT8U StartAddr, INT8U *pBuff, INT8U Length )
- INT8U i;
- L01_SetCE( 0 );
- L01_CSN_LOW( );
- SPI_ExchangeByte( W_REGISTER | StartAddr );
- for( i = 0; i < Length; i ++ )
- SPI_ExchangeByte( *( pBuff + i ) );
- L01_CSN_HIGH( );
- L01_SetCE( tmp );
- Function : L01_FlushTX( )
- Description : Flush the TX buffer
- Input : None
- Output: None
- void L01_FlushTX( void )
- L01_CSN_LOW( );
- SPI_ExchangeByte( FLUSH_TX );
- L01_CSN_HIGH( );
- Function : L01_FlushRX( )
- Description : Flush the RX buffer
- Input : None
- Output: None
- void L01_FlushRX( void )
- L01_CSN_LOW( );
- SPI_ExchangeByte( FLUSH_RX );
- L01_CSN_HIGH( );
- Function : L01_ReuseTXPayload( )
- Description : Reuse the last transmitted payload
- Input : None
- Output: None
- void L01_ReuseTXPayload( void )
- L01_CSN_LOW( );
- SPI_ExchangeByte( REUSE_TX_PL );
- L01_CSN_HIGH( );
- Function : L01_Nop( )
- Description : nop operation of nRF24L01
- Input : None
- Output: None
- void L01_Nop( void )
- L01_CSN_LOW( );
- SPI_ExchangeByte( L01_NOP );
- L01_CSN_HIGH( );
- Function : L01_ReadStatusReg( )
- Description : Read statu register of nRF24L01
- Input : None
- Output: Statu register of nRF24L01
- INT8U L01_ReadStatusReg( void )
- INT8U Status;
- L01_CSN_LOW( );
- Status = SPI_ExchangeByte( R_REGISTER + L01REG_STATUS );
- L01_CSN_HIGH( );
- return Status;
- Function : L01_ClearIRQ( )
- Description : Clear IRQ cuased by nRF24L01
- Input : None
- Output: None
- void L01_ClearIRQ( INT8U IRQ_Source )
- INT8U btmp = 0;
- IRQ_Source &= ( 1<<RX_DR ) | ( 1<<TX_DS ) | ( 1<<MAX_RT );
- btmp = L01_ReadStatusReg( );
- L01_CSN_LOW( );
- L01_WriteSingleReg( L01REG_STATUS, IRQ_Source | btmp );
- L01_CSN_HIGH( );
- L01_ReadStatusReg( );
- Function : L01_ReadIRQSource( )
- Description : Read the IRQ source of nRF24L01+
- Input : None
- Output: IRQ source mask code
- INT8U L01_ReadIRQSource( void )
- return ( L01_ReadStatusReg( ) & ( ( 1<<RX_DR ) | ( 1<<TX_DS ) | ( 1<<MAX_RT ) ) );
- Function : L01_ReadTopFIFOWidth( )
- Description : Read the payload width of the top buffer of FIFO
- Input : None
- Output: The width of the pipe buffer
- INT8U L01_ReadTopFIFOWidth( void )
- INT8U btmp;
- L01_CSN_LOW( );
- SPI_ExchangeByte( R_RX_PL_WID );
- L01_CSN_HIGH( );
- return btmp;
- Function : L01_ReadRXPayload( )
- Description : Read the RX payload from internal buffer
- Input : -pBuff, buffer to store the data
- Output: The length of data read
- INT8U L01_ReadRXPayload( INT8U *pBuff )
- INT8U width, PipeNum;
- PipeNum = ( L01_ReadSingleReg( L01REG_STATUS ) >> 1 ) & 0x07;
- width = L01_ReadTopFIFOWidth( );
- L01_CSN_LOW( );
- SPI_ExchangeByte( R_RX_PAYLOAD );
- for( PipeNum = 0; PipeNum < width; PipeNum ++ )
- *( pBuff + PipeNum ) = SPI_ExchangeByte( 0xFF );
- L01_CSN_HIGH( );
- L01_FlushRX( );
- return width;
- Function : L01_WriteTXPayload( )
- Description : Write TX payload to a pipe and prx will return ack back
- Input : -PipeNum, number of the pipe
- -pBuff, A buffer stores the data
- -nBytes, How many bytes to be wrote to
- Output: None
- void L01_WriteTXPayload_Ack( INT8U *pBuff, INT8U nBytes )
- INT8U btmp;
- INT8U length = ( nBytes > 32 ) ? 32 : nBytes;
- L01_FlushTX( );
- L01_CSN_LOW( );
- SPI_ExchangeByte( W_TX_PAYLOAD );
- for( btmp = 0; btmp < length; btmp ++ )
- SPI_ExchangeByte( *( pBuff + btmp ) );
- L01_CSN_HIGH( );
- Function : L01_WritePayload_NoAck( )
- Description : write data in tx mode, and prx won't return ack back
- Input : -Data, A buffer stores the address data
- -Data_Length, How many bytes of the data buff
- Output: None
- void L01_WriteTXPayload_NoAck( INT8U *Data, INT8U Data_Length )
- if( Data_Length > 32 || Data_Length == 0 )
- return ;
- L01_CSN_LOW( );
- SPI_ExchangeByte( W_TX_PAYLOAD_NOACK );
- while( Data_Length-- )
- SPI_ExchangeByte( *Data++ );
- L01_CSN_HIGH( );
- Function : L01_WritePayload_InAck( )
- Description : write data in tx fifo when rx mode
- Output: None
- void L01_WriteRXPayload_InAck( INT8U *pData, INT8U Data_Length )
- INT8U length = ( Data_Length > 32 ) ? 32 : Data_Length;
- INT8U btmp;
- L01_CSN_LOW( );
- SPI_ExchangeByte( W_ACK_PAYLOAD );
- SPI_ExchangeByte( *( pData + btmp ) );
- L01_CSN_HIGH( );
- Function : L01_SetTXAddr( )
- Description : Write address for the own device
- Input : -pAddr, A buffer stores the address data
- -Addr_Length, How many bytes of the address
- Output: None
- void L01_SetTXAddr( INT8U *pAddr, INT8U Addr_Length )
- INT8U Length = ( Addr_Length > 5 ) ? 5 : Addr_Length;
- L01_WriteMultiReg( L01REG_TX_ADDR, pAddr, Length );
- Function : L01_SetRXAddr( )
- Description : Write address for a RX pipe
- -pAddr, A buffer stores the address data
- Output: None
- void L01_SetRXAddr( INT8U PipeNum, INT8U *pAddr, INT8U Addr_Length )
- INT8U pipe = ( PipeNum > 5 ) ? 5 : PipeNum;
- L01_WriteMultiReg( L01REG_RX_ADDR_P0 + pipe, pAddr, Length );
- Function : L01_SetSpeed )
- Description : Send the communication speed of the RF device
- Input : speed,
- Output: None
- void L01_SetSpeed( L01SPD speed )
- INT8U btmp = L01_ReadSingleReg( L01REG_RF_SETUP );
- btmp &= ~( ( 1<<5 ) | ( 1<<3 ) );
- if( speed == SPD_250K ) //250K
- btmp |= ( 1<<5 );
- else if( speed == SPD_1M ) //1M
- else if( speed == SPD_2M ) //2M
- btmp |= ( 1<<3 );
avrATmega8射頻收發(fā).zip
(295.88 KB, 下載次數(shù): 22)
2019-4-23 10:24 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
