我用的51單片機晶振頻率是12MHz,我打算利用計數(shù)器每隔1秒讓led輪流亮,數(shù)碼管每隔兩秒亮,
但是實際情況是數(shù)碼管保持兩秒一亮,但是led確非;靵y,所以我想讓大家看看是什么問題,下面
貼代碼
#include <reg52.h>
#include <intrins.h>
typedef unsigned int uint;
typedef unsigned char uchar;
uchar code table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
sbit segment_selection = P2^1;//段選
sbit bit_selection = P2^0;//位選
uchar tt;
uchar temp;
uchar num;
void inter0() interrupt 1
TH0 = (65535-50000)/256;
TL0 = (65535-50000)%256;
tt++;
/*下面注釋的代碼在while(1)里面寫有問題,但是在中斷函數(shù)里寫就沒問題
// if(tt == 20 || tt == 40)
// temp = _cror_(temp, 1);
// P1 = temp;
// if(tt == 40)
// tt = 0;
// segment_selection = 1;
// P0 = table[num];/從0到f;
// segment_selection = 0;
// P0 = 0x00;
// num++;
// if(num == 16)
// num = 0;
num = 0;
temp = 0xfe;
tt = 0;
TMOD = 0x01;
EA = 1;/單片機總中斷開啟
ET0 = 1;/定時器0中斷開啟
TR0 = 1;/定時器0中斷允許位開啟
if( tt == 20)//這里我是打算每隔1秒led循環(huán)亮
P1 = temp;
temp = _crol_(temp, 1);
if(tt == 40)
tt = 0;
P0 = table[num]
P0 = 0x00;//消隱
num++;
if(num == 16)
num = 0;
//在while(1)循環(huán)里這么寫有問題,在中斷函數(shù)里寫就沒問題
