#include "reg52.h"
typedef unsigned int u16;
typedef unsigned char u8;
sbit led=P2^1;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit beep=P1^5;
sbit k1=P3^1;
sbit k2=P3^0;
sbit k3=P3^2;
sbit k4=P3^3;
u8 code smgduan[18]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x6d};
#define KEY1 1
#define KEY2 2
#define KEY3 3
#define KEY4 4
char keynum;
u8 DisplayData[8];
char t,z;
void delay(u16 i)
while(i--);
u8 KeyScan(u8 mode)
static u8 keyen=1;
if(mode==1)
keyen=1;
if(keyen==1&&(k1==0||k2==0||k3==0||k4==0))
delay(1000);
keyen=0;
if(k1==0)return KEY1;
else if(k2==0)return KEY2;
else if(k3==0)return KEY3;
else if(k4==0)return KEY4;
else if(k1==1&&k2==1&&k3==1&&k4==1)
keyen=1;
return 0;
void DigDisplay()
u8 i;
for(i=0;i<8;i++)
switch(i)
case(0):
LSA=0;LSB=0;LSC=0; break;
case(1):
LSA=1;LSB=0;LSC=0; break;
case(2):
LSA=0;LSB=1;LSC=0; break;
case(3):
LSA=1;LSB=1;LSC=0; break;
case(4):
LSA=0;LSB=0;LSC=1; break;
case(5):
LSA=1;LSB=0;LSC=1; break;
case(6):
LSA=0;LSB=1;LSC=1; break;
case(7):
LSA=1;LSB=1;LSC=1; break;
P0=DisplayData[i];
delay(50);
P0=0x00;
void datapros()
u8 key=KeyScan(0);
u8 flag;
flag=1;
switch(key)
case 1: keynum++;if(keynum==100)keynum=0; break;
case 2: keynum--;if(keynum<=0)keynum=99; break;
case 3: keynum=0; break;
case 4: TR0=1; t=keynum; break;
DisplayData[0]=0x6d;
DisplayData[1]=smgduan[keynum%10];
DisplayData[2]=smgduan[keynum/10];
void Timer0Init()
TMOD|=0X01;
TH0=0XFC;
TL0=0X18;
ET0=1;
EA=1;
z=0;
Timer0Init();
datapros();
DigDisplay();
if(keynum==0&&z!=0)
TR0=0;
beep=~beep;
keynum=t;
datapros();
DigDisplay();
void Timer0() interrupt 1
static u16 i;
TH0=0XFC;
TL0=0X18;
i++;
z=0;
if(i==1000)
i=0;
led=~led;
keynum--;
z++;
感覺我寫的定時器跟這個差不多 可以看看 我的計時器到零以后 顯示初值 可以看看 (萌新 ) ==== 初學(xué)單片機 勿噴 |
