查看: 5093|回復(fù): 6
51單片機(jī)6自由度機(jī)械臂調(diào)試程序,帶LCD1602PWM顯示
ID:527441 發(fā)表于 2019-5-5 10:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
以前學(xué)習(xí)51的時(shí)候?yàn)榱苏{(diào)試機(jī)械臂角度編寫(xiě)的程序,用在開(kāi)發(fā)板上也比較方便,但是由于是普通的舵機(jī),不是總線的,所以需要自己洞洞板焊一個(gè)供電帶電路。
  1. #include <reg52.h>
  2. #include <lcd1602.h>
  4. #define uint unsigned int
  5. sbit duoji0=P2^0;          //PWM輸出
  6. sbit duoji1=P2^1;
  7. sbit duoji2=P2^2;
  8. sbit duoji3=P2^3;
  9. sbit duoji4=P3^1;
  10. sbit duoji5=P3^0;
  11. #define GPIO_KEY P1
  12. unsigned int k0;
  13. unsigned int k1;
  14. unsigned int k2;
  15. unsigned int k4;
  16. unsigned int k3;
  17. unsigned int k5;         //定義下降沿節(jié)點(diǎn)
  18. uint dsip[8]={0};
  19. uint j=0;
  20. unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','D',' '};
  21. void delayms(uint xms)
  22. {
  23.   uchar j;
  24.         uint i;
  25.         for(i=xms;i>0;i--)
  26.         for(j=112;j>0;j--);
  27. }
  28. void time0() interrupt 1
  29. {
  30.         static uint ii0=0;
  31.   TH0=(65536-100)/256;      //以20ms為一個(gè)周期,以0.1ms為一個(gè)脈沖寬度
  32.   TL0=(65536-100)%256;
  33.   ii0++;
  34.
  35.         if(ii0<=k0)
  36.     duoji0=1;    //0號(hào)舵機(jī)pwm輸出
  37.   else
  38.     duoji0=0;
  39.
  40.         if(ii0<=k1)    //1號(hào)舵機(jī)pwm輸出
  41.     duoji1=1;
  42.   else
  43.     duoji1=0;
  44.   if(ii0<=k2)    //2號(hào)舵機(jī)pwm輸出
  45.     duoji2=1;
  46.   else
  47.     duoji2=0;
  48. if(ii0<=k3)     //3號(hào)舵機(jī)pwm輸出
  49.     duoji3=1;
  50.   else
  51.     duoji3=0;
  52.
  53.          if(ii0<=k4)   //4號(hào)舵機(jī)pwm輸出
  54.     duoji4=1;
  55.   else
  56.     duoji4=0;
  57.
  58.          if(ii0<=k5)   //5號(hào)舵機(jī)pwm輸出
  59.     duoji5=1;
  60.   else
  61.     duoji5=0;
  62.
  63.         if(ii0==200)
  64.     ii0=0;
  65. }
  66. void time0init()
  67. {
  68.   TMOD=0x01;
  69.   TH0=(65536-100)/256;
  70.   TL0=(65536-100)%256;
  71.   TR0=1;
  72.   ET0=1;
  73.   EA=1;
  74. }
  75. char KeyDown()
  76. {
  77.         uchar KeyValue=20;
  78.         uchar a=0;
  79.         GPIO_KEY=0x0f;
  80.         if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
  81.         {
  82.                 delayms(10);//延時(shí)10ms進(jìn)行消抖
  83.                 if(GPIO_KEY!=0x0f)//再次檢測(cè)鍵盤(pán)是否按下
  84.                 {
  85.                         //測(cè)試列
  86.                         GPIO_KEY=0X0F;
  87.                         switch(GPIO_KEY)
  88.                         {
  89.                                 case(0X07):        KeyValue=0;break;
  90.                                 case(0X0b):        KeyValue=1;break;
  91.                                 case(0X0d): KeyValue=2;break;
  92.                                 case(0X0e):        KeyValue=3;break;
  93.                         }
  94.                         //測(cè)試行
  95.                         GPIO_KEY=0XF0;
  96.                         switch(GPIO_KEY)
  97.                         {
  98.                                 case(0X70):        KeyValue=KeyValue;break;
  99.                                 case(0Xb0):        KeyValue=KeyValue+4;break;
  100.                                 case(0Xd0): KeyValue=KeyValue+8;break;
  101.                                 case(0Xe0):        KeyValue=KeyValue+12;break;
  102.                         }
  103.                         while((a<50)&&(GPIO_KEY!=0xf0))         //檢測(cè)按鍵松手檢測(cè),當(dāng)按鍵等于0xf時(shí)候跳出循環(huán)
  104.                         {
  105.                                 delayms(100);
  106.                                 a++;
  107.                         }
  108.                 }
  109.         }
  110.         return KeyValue;
  111. }
  112. void count()
  113. {
  114.
  115.           LcdWriteData(ASCII[0]);
  116.           LcdWriteData(ASCII[11]);
  117.     LcdWriteData(ASCII[k0/10]);
  118.                 LcdWriteData(ASCII[k0%10]);
  119.           LcdWriteData(ASCII[12]);
  120.
  121.           LcdWriteData(ASCII[1]);
  122.           LcdWriteData(ASCII[11]);
  123.                 LcdWriteData(ASCII[k1/10]);
  124.                 LcdWriteData(ASCII[k1%10]);
  125.           LcdWriteCom(0x80+0x40);
  126.
  127.           LcdWriteData(ASCII[2]);
  128.           LcdWriteData(ASCII[11]);
  129.                 LcdWriteData(ASCII[k2/10]);
  130.                 LcdWriteData(ASCII[k2%10]);
  131.     LcdWriteData(ASCII[12]);
  132.
  133.           LcdWriteData(ASCII[3]);
  134.           LcdWriteData(ASCII[11]);
  135.                 LcdWriteData(ASCII[k3/10]);
  136.                 LcdWriteData(ASCII[k3%10]);
  137.
  138. }
  139. void main()
  140. {
  141.   time0init();
  142.         k0=15;
  143.         k1=9;
  144.         k2=16;
  145.         k3=14;
  146.         k4=8;
  147.         k5=8;
  148.         LcdInit();
  149.         count();
  150.
  151.         while(1)
  152.   {
  153.                 uchar KeyValue1=20;
  154.           KeyValue1=KeyDown();
  155.
  156.
  157.
  158.
  159.
  160.
  161.
  162.                 if(KeyValue1==0&&k0<=20&&k0>=8)        //0號(hào)舵機(jī)高電平時(shí)間增加
  163.           {
  164.                      k0++;
  165.                      if(k0==21)
  166.                                          k0=20;
  167.                                  KeyValue1=20;LcdWriteCom(0x01);        count();
  168.     }
  169.
  170.     if(KeyValue1==4&&k0<=20&&k0>=8)         //0號(hào)舵機(jī)高電平時(shí)間減少
  171.           {
  172.
  173.                      k0--;
  174.                      if(k0==7)
  175.                                          k0=8;
  176.               KeyValue1=20;        LcdWriteCom(0x01);count();
  177.     }
  178.
  179.                 if(KeyValue1==1&&k1<=20&&k1>=8)        //1號(hào)舵機(jī)高電平時(shí)間增加
  180.           {
  181.
  182.                      k1++;
  183.                      if(k1==21)
  184.                                          k1=20;
  185.       KeyValue1=20;        LcdWriteCom(0x01);count();
  186.     }
  187.
  188.     if(KeyValue1==5&&k1<=20&&k1>=8)
  189.           {
  190.
  191.                      k1--;
  192.                      if(k1==7)
  193.                                          k1=8;
  194.               KeyValue1=20;        LcdWriteCom(0x01);count();
  195.     }
  196.
  197.                 if(KeyValue1==2&&k2<=20&&k2>=8)       //2號(hào)舵機(jī)高電平時(shí)間增加
  198.           {
  199.
  200.                      k2++;
  201.                      if(k2==21)
  202.                                          k2=20;
  203.       KeyValue1=20;        LcdWriteCom(0x01);count();
  204.     }
  205.
  206.     if(KeyValue1==6&&k2<=20&&k2>=8)
  207.           {
  208.
  209.                      k2--;
  210.                      if(k2==7)
  211.                                          k2=8;
  212.               KeyValue1=20;        LcdWriteCom(0x01);count();
  213.     }
  214.
  215.                 if(KeyValue1==3&&k3<=20&&k3>=8)       //3號(hào)舵機(jī)高電平時(shí)間增加
  216.           {
  217.
  218.                      k3++;
  219.                      if(k3==21)
  220.                                          k3=20;
  221.               KeyValue1=20;        LcdWriteCom(0x01);count();
  222.     }
  223.
  224.     if(KeyValue1==7&&k3<=20&&k3>=8)
  225.           {
  226.
  227.                      k3--;
  228.                      if(k3==7)
  229.                                          k3=8;
  230.               KeyValue1=20;        LcdWriteCom(0x01);count();
  231.     }
  232.
  233.                 if(KeyValue1==8&&k4<=20&&k4>=8)       //4號(hào)舵機(jī)高電平時(shí)間增加
  234.           {
  235.
  236.                      k4++;
  237.                      if(k4==21)
  238.                                          k4=20;
  239.               KeyValue1=20;LcdWriteCom(0x01);        count();
  240.     }
  241.
  242.     if(KeyValue1==12&&k4<=20&&k4>=8)
  243.           {
  244.
  245.                      k4--;
  246.                      if(k4==7)
  247.                                          k4=8;
  248.               KeyValue1=20;        LcdWriteCom(0x01);count();
  249.     }
  250.
  251.                 if(KeyValue1==9&&k5<=20&&k5>=8)       //5號(hào)舵機(jī)高電平時(shí)間增加
  252.           {
  253.
  254.                      k5++;
  255.                      if(k5==21)
  256.                                          k5=20;
  257.               KeyValue1=20;LcdWriteCom(0x01);        count();
  258.     }
  259.
  260.     if(KeyValue1==13&&k5<=20&&k5>=8)
  261.           {
  262.
  263.                      k5--;
  264.                      if(k5==7)
  265.                                          k5=8;
  266.               KeyValue1=20;        LcdWriteCom(0x01);count();
  267.     }
  268.
  269.   }
  270. }
  271.
51arm1602pwm.rar (44.41 KB, 下載次數(shù): 94)
收藏收藏3 分享淘帖 頂1 踩
ID:527441 發(fā)表于 2019-5-5 10:57 | 只看該作者
如果大家需要使用機(jī)械臂的話,給大家推薦一個(gè)黑科技模塊:PCA9685,iic總線通信的,很方便
ID:165117 發(fā)表于 2019-5-5 16:55 | 只看該作者
謝謝樓主的共享,有沒(méi)有電路圖??
ID:527441 發(fā)表于 2019-5-6 12:28 | 只看該作者
gdatgb 發(fā)表于 2019-5-5 16:55
lcd1602地電路圖可以參考普中的51開(kāi)發(fā)板,是在那個(gè)上面實(shí)現(xiàn)的,舵機(jī)部分也就是供電線,共GND,然后信號(hào)線連接在51上面
ID:165117 發(fā)表于 2019-5-6 14:35 | 只看該作者
snorlaxcy 發(fā)表于 2019-5-6 12:28
lcd1602地電路圖可以參考普中的51開(kāi)發(fā)板,是在那個(gè)上面實(shí)現(xiàn)的,舵機(jī)部分也就是供電線,共GND,然后信號(hào)線 ...
好的,謝謝了!
ID:683198 發(fā)表于 2020-1-7 20:35 來(lái)自觸屏版 | 只看該作者
感謝分享
ID:582255 發(fā)表于 2021-1-24 15:19 | 只看該作者
這個(gè)硬件實(shí)現(xiàn)了沒(méi)
