2019-5-7 16:32 上傳
2019-5-7 16:32 上傳
2019-5-7 16:32 上傳
源碼:
//包含頭文件
- #include <reg52.h>
- #include <math.h>
- unsigned char code dispbit[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //反掃 (高位接高位)
- //unsigned char code dispbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01}; //正掃 (高位接低位)
- unsigned char code dispcode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//數(shù)碼管顯示碼0-9 (a b c d e f g dp)
- unsigned char dispbuf[6]={0,0,0,0,0,0}; //顯示數(shù)據(jù)暫存數(shù)組
- unsigned char temp[6]; //頻率值暫存數(shù)組
- unsigned char T0count; //計(jì)數(shù)器計(jì)滿次數(shù),計(jì)滿一次對(duì)應(yīng)的脈沖數(shù)為65536個(gè)
- unsigned int timecount; //定時(shí)器定時(shí)1秒的變量,每次對(duì)應(yīng)為50ms,計(jì)20次對(duì)應(yīng)就是1秒,然后計(jì)算一秒內(nèi)的計(jì)數(shù)器脈沖個(gè)數(shù)
- bit flag; //計(jì)時(shí)到1秒時(shí)該標(biāo)志位置1,進(jìn)行脈沖數(shù)的運(yùn)算,得出結(jié)果送顯示,然后該位清零,重新開(kāi)始脈沖計(jì)數(shù)
- unsigned long x; //計(jì)算脈沖的數(shù)據(jù)范圍一般比較大,所以用無(wú)符號(hào)長(zhǎng)整形變量定義該變量
- sbit dian=P0^7; //位定義小數(shù)點(diǎn),用于kHz顯示
- void display() //顯示函數(shù)
- unsigned int j; //定義變量用于顯示延時(shí)
- if(dispbuf[5]!=0) //如果十萬(wàn)位不為0
- P2=dispbit[5];
- P0=dispcode[dispbuf[5]]; //十萬(wàn)位正常顯示數(shù)字
- for(j=50;j>0;j--);
- P0=0xff;
- if(dispbuf[5]!=0||dispbuf[4]!=0) //如果十萬(wàn)位和萬(wàn)位都不等于零
- P2=dispbit[4];
- P0=dispcode[dispbuf[4]]; //萬(wàn)位正常顯示
- P0=0xff;
- P2=dispbit[3]; //同上
- P0=dispcode[dispbuf[3]];
- dian=0; //該位顯示小數(shù)點(diǎn)
- P0=0xff;
- P2=dispbit[2];
- P0=dispcode[dispbuf[2]];
- P0=0xff;
- P2=dispbit[1];
- P0=dispcode[dispbuf[1]];
- P0=0xff;
- P2=dispbit[0];
- P0=dispcode[dispbuf[0]];
- P0=0xff;
- void main(void) //主函數(shù)
- unsigned char i;
- TMOD=0x15; //定義T1為定時(shí)模式,T0位計(jì)數(shù)模式
- TH0=0;
- TL0=0; //計(jì)數(shù)器清零
- TH1=0x3c;
- TL1=0xb0; //定時(shí)器賦值(定時(shí)50ms)
- TR1=1; //打開(kāi)定時(shí)器T1
- TR0=1; //打開(kāi)計(jì)數(shù)器T0
- ET0=1; //打開(kāi)中斷允許
- ET1=1; //打開(kāi)中斷允許
- EA=1; //打開(kāi)中斷總開(kāi)關(guān)
- while(1) //進(jìn)入循環(huán),因?yàn)槔ㄌ?hào)內(nèi)為常數(shù)1,不會(huì)變化,所以該表達(dá)式一直成立,又稱死循環(huán)
- display(); //調(diào)用顯示函數(shù)
- if(flag) //判斷1秒時(shí)間是否到
- flag=0; //標(biāo)志位清零,計(jì)算完脈沖數(shù)后重新開(kāi)始計(jì)時(shí)計(jì)數(shù)
- x=T0count*65536+TH0*256+TL0; //讀取1秒時(shí)間內(nèi)的計(jì)數(shù)個(gè)數(shù)(T0count為每次計(jì)數(shù)超過(guò)65536時(shí)進(jìn)入計(jì)數(shù)中斷加1)
- for(i=0;i<6;i++) //for循環(huán)將暫存數(shù)組內(nèi)數(shù)據(jù)清零
- temp[i]=0;
- i=0; //i清零
- while(x/10) //將x拆分為6個(gè)一位數(shù)
- temp[i]=x%10; //如果x/10不為0,將x除以10的余數(shù)賦值temp【i】
- x=x/10; //然后將x/10的商賦值給x
- i++; //i++
- temp[i]=x; //最高位直接賦值給temp【i】
- for(i=0;i<6;i++) //for循環(huán)用于將數(shù)據(jù)送入顯示暫存數(shù)組
- dispbuf[i]=temp[i]; //賦值語(yǔ)句
- T0count=0; //計(jì)數(shù)器中斷次數(shù)清零
- TH0=0;
- TR0=1;
- TR1=1; //重新打開(kāi)定時(shí)計(jì)數(shù)器
- void t0() interrupt 1 //計(jì)數(shù)器中斷函數(shù)
- T0count++; //計(jì)數(shù)超過(guò)65536,就產(chǎn)生一次中斷
- void t1() interrupt 3 //定時(shí)器中斷函數(shù)
- TH1=0x3c;
- TL1=0xb0; //50ms進(jìn)入一次中斷,進(jìn)入中斷后要重新賦初值
- timecount++; //每進(jìn)一次中斷就是50ms,該變量加一
- if(timecount==20) //該變量加到20次時(shí),代表1秒到了
- TR0=0; //關(guān)閉計(jì)數(shù)器
- TR1=0; //關(guān)閉定時(shí)器
- timecount=0; //計(jì)時(shí)變量清零,準(zhǔn)備下次定時(shí)
- flag=1; //一秒時(shí)間到,該標(biāo)志位置1,主函數(shù)中執(zhí)行脈沖數(shù)運(yùn)算與顯示函數(shù)
- /**************************這里是函數(shù)的結(jié)尾END***************************/
六位數(shù)碼管頻率計(jì).zip
(480.69 KB, 下載次數(shù): 304)
2019-5-7 17:20 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
