查看: 4932|回復(fù): 0
c#學(xué)生信息管理系統(tǒng)源程序(設(shè)置窗體皮膚)連接數(shù)據(jù)庫(kù)SQL
基于C# 和SQL數(shù)據(jù)的做的學(xué)生信息管理系統(tǒng),能夠?qū)崿F(xiàn):
專業(yè)設(shè)置
班級(jí)設(shè)置
學(xué)生信息增刪改查
有用戶登錄權(quán)限
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.Data.SqlClient;
  10. using System.Configuration;
  11. namespace SR_StudentManage
  12. {
  13.     public partial class SM_Main : Form
  14.     {
  15.         static string ConnStr = ConfigurationSettings.AppSettings["ConnStr"];
  16.         SqlConnection conn = new SqlConnection(ConnStr);
  17.         public SM_Main()
  18.         {
  19.             InitializeComponent();
  20.         }
  21.         private void SM_Main_Load(object sender, EventArgs e)
  22.         {
  23.             skinEngine1.SkinFile = System.Environment.CurrentDirectory + "\\skin\\GlassGreen.ssk";
  24.             this.toolStripStatusLabel1.Text = "當(dāng)前系統(tǒng)時(shí)間:"+DateTime.Now.ToString("yyyy年MM月dd日hh:mm:ss");
  25.             this.toolStripStatusLabel2.Text = "                               版權(quán)所有   盜版必究";
  26.             BindXueYuan();
  27.             //獲取用戶登錄后的級(jí)別。用于顯示不同的權(quán)限按鈕
  28.             string okroles = SM_Login.myroles;
  29.             if (okroles == "1")
  30.             {
  31.                 學(xué)生管理SToolStripMenuItem.Enabled = false;
  32.                 系統(tǒng)信息管理XToolStripMenuItem.Enabled = false;
  33.                 班級(jí)信息管理BToolStripMenuItem.Enabled = false;
  34.                 contextMenuStrip1.Enabled = false;
  35.             }
  36.             if (okroles == "2")
  37.             {
  38.
  39.                 系統(tǒng)信息管理XToolStripMenuItem.Enabled = false;
  40.             }
  41.
  42.         }
  43.         #region ***********************樹(shù)形目錄**************************
  44.         void BindXueYuan()
  45.         {
  46.             string sql = "select * from XueYuanInfo";
  47.             SqlDataAdapter da = new SqlDataAdapter(sql, conn);
  48.             DataSet ds = new DataSet();
  49.             da.Fill(ds);
  50.             if (ds.Tables[0].Rows.Count > 0)
  51.             {
  52.                 for (int i = 0; i < ds.Tables[0].Rows.Count; i++)
  53.                 {
  54.                     TreeNode xueyuan_tn = new TreeNode(ds.Tables[0].Rows[i]["XueYuanName"].ToString());
  55.                     xueyuan_tn.Tag = ds.Tables[0].Rows[i]["XueYuanCode"].ToString();
  56.                     xueyuan_tn.ImageIndex = 0;
  57.                     treeView1.Nodes.Add(xueyuan_tn);
  58.                     BindZhuanYe(xueyuan_tn);
  59.                 }
  60.
  61.             }
  62.
  63.         }
  64.         void BindZhuanYe(TreeNode xueyuan_tn)
  65.         {
  66.             string sql = "select * from ZhuanYeInfo where XueYuanCode='" + xueyuan_tn .Tag+ "'";
  67.             SqlDataAdapter da = new SqlDataAdapter(sql, conn);
  68.             DataSet ds = new DataSet();
  69.             da.Fill(ds);
  70.             if (ds.Tables[0].Rows.Count > 0)
  71.             {
  72.                 for (int i = 0; i < ds.Tables[0].Rows.Count; i++)
  73.                 {
  74.                     TreeNode zhuanye_tn = new TreeNode(ds.Tables[0].Rows[i]["ZhuanYeName"].ToString());
  75.                     zhuanye_tn.Tag = ds.Tables[0].Rows[i]["ZhuanYeCode"].ToString();
  76.                     zhuanye_tn.ImageIndex = 1;
  77.                     zhuanye_tn.SelectedImageIndex = 1;
  78.                     xueyuan_tn.Nodes.Add(zhuanye_tn);
  79.                     BindBanJi(zhuanye_tn);
  80.                 }
  81.             }
  82.
  83.
  84.         }
  85.         void BindBanJi(TreeNode zhuanye_tn)
  86.         {
  87.             string sql = "select * from BanJiInfo where ZhuanYeCode='" + zhuanye_tn.Tag + "'";
  88.             SqlDataAdapter da = new SqlDataAdapter(sql, conn);
  89.             DataSet ds = new DataSet();
  90.             da.Fill(ds);
  91.             if (ds.Tables[0].Rows.Count > 0)
  92.             {
  93.                 for (int i = 0; i < ds.Tables[0].Rows.Count; i++)
  94.                 {
  95.                     TreeNode banji_tn = new TreeNode(ds.Tables[0].Rows[i]["BanJiName"].ToString());
  96.                     banji_tn.Tag = ds.Tables[0].Rows[i]["BanJiName"].ToString();
  97.                     banji_tn.ImageIndex = 2;
  98.                     banji_tn.SelectedImageIndex = 2;
  99.                     zhuanye_tn.Nodes.Add(banji_tn);
  100.                 }
  101.             }
  102.
  103.         }
  104.
  105.
  106.
  107.         #endregion
  108.         private void timer1_Tick(object sender, EventArgs e)
  109.         {
  110.             this.toolStripStatusLabel1.Text = "當(dāng)前系統(tǒng)時(shí)間:" + DateTime.Now.ToString("yyyy年MM月dd日hh:mm:ss");
  111.         }
  112.         public static string str = "";
  113.         private void 學(xué)院設(shè)置ToolStripMenuItem_Click(object sender, EventArgs e)
  114.         {
  115.             str = "學(xué)院設(shè)置";
  116.             SM_SystemAdmin sm = new SM_SystemAdmin();
  117.             //將第一窗體的權(quán)限賦予第二窗體
  118.             sm.Owner = this;
  119.             sm.ShowDialog();
  120.         }
  121.         private void 專業(yè)設(shè)置ToolStripMenuItem_Click(object sender, EventArgs e)
  122.         {
  123.             str = "專業(yè)設(shè)置";
  124.             SM_SystemAdmin sm = new SM_SystemAdmin();
  125.             sm.ShowDialog();
  126.         }
  127.         private void 班級(jí)設(shè)置ToolStripMenuItem_Click(object sender, EventArgs e)
  128.         {
  129.             str = "班級(jí)設(shè)置";
  130.             SM_SystemAdmin sm = new SM_SystemAdmin();
  131.             sm.ShowDialog();
  132.         }
  133.         private void 學(xué)科設(shè)置ToolStripMenuItem_Click(object sender, EventArgs e)
  134.         {
  135.             str = "學(xué)科設(shè)置";
  136.             SM_SystemAdmin sm = new SM_SystemAdmin();
  137.             sm.ShowDialog();
  138.         }
  139.         private void 獎(jiǎng)懲設(shè)置ToolStripMenuItem_Click(object sender, EventArgs e)
  140.         {
  141.             str = "獎(jiǎng)懲設(shè)置";
  142.             SM_SystemAdmin sm = new SM_SystemAdmin();
  143.             sm.ShowDialog();
  144.         }
  145.         private void 新建學(xué)生檔案ToolStripMenuItem_Click(object sender, EventArgs e)
  146.         {
  147.             SM_AddStudent sma = new SM_AddStudent();
  148.             sma.ShowDialog();
  149.         }
  150.         private void treeView1_NodeMouseDoubleClick(object sender, TreeNodeMouseClickEventArgs e)
  151.         {
  152.             listView1.Items.Clear();
  153.             string banjiname = treeView1.SelectedNode.Tag.ToString();
  154.             string sql = "select * from XueShengInfo where BanJiName='" + banjiname + "'";
  155.             SqlDataAdapter da = new SqlDataAdapter(sql, conn);
  156.             DataSet ds = new DataSet();
  157.             da.Fill(ds);
  158.             if (ds.Tables[0].Rows.Count > 0)
  159.             {
  160.                 for (int i = 0; i < ds.Tables[0].Rows.Count; i++)
  161.                 {
  162.                     ListViewItem lvi = new ListViewItem(ds.Tables[0].Rows[i]["XueShengName"].ToString());
  163.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengXueHao"].ToString());
  164.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengSex"].ToString());
  165.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengSID"].ToString());
  166.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengTel"].ToString());
  167.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengAddress"].ToString());
  168.                     listView1.Items.Add(lvi);
  169.
  170.                 }
  171.             }
  172.         }
  173.         private void toolStripButton1_Click(object sender, EventArgs e)
  174.         {
  175.             新建學(xué)生檔案ToolStripMenuItem_Click(sender, e);
  176.         }
  177.         public static string XueHao = "";
  178.         private void 查看學(xué)生信息ToolStripMenuItem_Click(object sender, EventArgs e)
  179.         {
  180.             try
  181.             {
  182.                 XueHao = listView1.SelectedItems[0].SubItems[1].Text;
  183.                 SM_ShowStudent sms = new SM_ShowStudent();
  184.                 sms.ShowDialog();
  185.             }
  186.             catch {
  187.                 MessageBox.Show("請(qǐng)選擇您要查看的學(xué)生");
  188.             }
  189.         }
  190.         private void 刪除學(xué)生信息ToolStripMenuItem_Click(object sender, EventArgs e)
  191.         {
  192.             XueHao = listView1.SelectedItems[0].SubItems[1].Text;
  193.             DialogResult jieguo= MessageBox.Show("您確定要?jiǎng)h除嗎?", "提示信息", MessageBoxButtons.OKCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1);
  194.             if (DialogResult.OK == jieguo)
  195.             {
  196.                 string sql = "delete from XueShengInfo where XueShengXueHao='" + XueHao + "'";
  197.                 SqlCommand cmd = new SqlCommand(sql, conn);
  198.                 conn.Open();
  199.                 int i = cmd.ExecuteNonQuery();
  200.                 conn.Close();
  201.                 if (i > 0)
  202.                 {
  203.                     MessageBox.Show("刪除成功");
  204.                     List();
  205.                 }
  206.             }
  207.
  208.         }
  209.         void List()
  210.         {
  211.             listView1.Items.Clear();
  212.             string banjiname = treeView1.SelectedNode.Tag.ToString();
  213.             string sql = "select * from XueShengInfo where BanJiName='" + banjiname + "'";
  214.             SqlDataAdapter da = new SqlDataAdapter(sql, conn);
  215.             DataSet ds = new DataSet();
  216.             da.Fill(ds);
  217.             if (ds.Tables[0].Rows.Count > 0)
  218.             {
  219.                 for (int i = 0; i < ds.Tables[0].Rows.Count; i++)
  220.                 {
  221.                     ListViewItem lvi = new ListViewItem(ds.Tables[0].Rows[i]["XueShengName"].ToString());
  222.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengXueHao"].ToString());
  223.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengSex"].ToString());
  224.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengSID"].ToString());
  225.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengTel"].ToString());
  226.                     lvi.SubItems.Add(ds.Tables[0].Rows[i]["XueShengAddress"].ToString());
  227.                     listView1.Items.Add(lvi);
  228.                 }
  229.             }
  230.         }
  231.         private void 添加學(xué)生信息ToolStripMenuItem_Click(object sender, EventArgs e)
  232.         {
  233.             新建學(xué)生檔案ToolStripMenuItem_Click(sender, e);
  234.         }
  235.         private void toolStripButton2_Click(object sender, EventArgs e)
  236. ……………………
  237. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
16_學(xué)生管理系統(tǒng)(設(shè)置窗體皮膚).rar (3.26 MB, 下載次數(shù): 52)
