這是我設(shè)計(jì)的stm32F103控制兩相電機(jī)程序
測(cè)試好用
附件有keil工程文件
- #include "Bsp.h"
- #include "stm32f10x.h"
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- #define DEBUG 1
- char TestWord[USARTBUFLEN];
- char Cmd_buf[USARTBUFLEN];
- uint8_t Cmd_LockFlag = 0;
- uint8_t ResetCmd_Flag = 0;
- uint8_t Cmd_FinishFlag= 0;
- #define ACKSTR "OK_\r\n"
- #define NACKSTR "BADCMD_\r\n"
- #define BUSYSTR "WAIT_\r\n"
- char startchar[USARTBUFLEN];
- const char CMD_LIST[8][PARASTRLEN]={"RESET","MOVE","STOP","POWER","SET","READ","ZERO"}; //允許的命令
- const char HelpMsg[8][USARTBUFLEN]={{"Command List: MOVE STOP SET READ POWER ZERO;\r\n"},
- {"MOVE: e.g. :FF MOVE VERTICAL/HORIZONT CW/ANCW xxx.xx(0-360,sOLUTION: 0.01);\r\n"},
- {"STOP: e.g. :FF STOP VERTICAL/HORIZONT;\r\n"},
- {"POWER: e.g. :FF POWER VERTICAL/HORIZONT ON/OFF;\r\n"},
- {"SET: e.g. :FF SET VERTICAL/HORIZONT ;\r\n"},
- {"READ: e.g. :FF READ VERTICAL/HORIZONT;\r\n"},
- {"ZERO: e.g. :FF ZERO VERTICAL/HORIZONT;\r\n"},
- {"RESET: e.g. :FF RESET;\r\n"}};
- char CmdRespondStr[50];
- char para_list[CMDPARANUM][PARASTRLEN]; //保存命令中的參數(shù)
- SYSTEM_STA Sys_Sta;
- void CMD_Analyse(const char *cmd,uint8_t cmdlen);
- uint8_t str2float(const char *str,float *result);
- u8 Flag=0; //指示輸出角度是否到達(dá)360度或-360,如果到了,講360置為0度
- * 名 稱: main
- * 功 能: 串口占用GPIO初始化
- * 入口參數(shù):
- * 出口參數(shù):
- * 說(shuō) 明:
- * 調(diào)用方法:
- * 修改日志:
- int main(void)
- uint16_t temp[4],temp1=0,HVTemp1;
- uint16_t data_tmp;
- int32_t step_num = 0;
- uint32_t devison_tmp,step_speed;
- uint32_t sendbytes=0;
- const char *usart_sendaddr;
- float angle_tmp,speed_tmp,limit_tmp;
- uint8_t error;
- uint8_t tmp = 0;
- uint8_t fault_try = 0;
- STEPMOTOR_INDEX ver_hor;
- MOTIONDIR cw_ncw;
- uint8_t cycle_cnt,char_num;;
- Cmd_LockFlag = 0;
- Bsp_Init();
- // AT24CXX_Write(0,HelpMsg[0],strlen(HelpMsg[0]));
- usart_sendaddr = CmdRespondStr;
- cycle_cnt = 0;
- temp[0] = 0;
- ResetCmd_Flag = 0;
- #ifdef DEBUG
- //打印識(shí)別信息
- char_num = sprintf(startchar,"\r\n 134mm-Diameter Step-Motor Driver.\r\nCorp.AGGC,By LK,140\r\n");
- UsartDMASend(startchar,char_num);
- #endif
- //上電首先檢查振鏡位置是否超出允許
- Delay_ms(5000);
- if((RESET == GPIO_ReadInputDataBit(ANCW_LIMIT))|(RESET == GPIO_ReadInputDataBit(CW_LIMIT)))
- Hor_Info.motion_sta = OutOfRange;
- if(RESET == GPIO_ReadInputDataBit(ANCW_LIMIT))
- Hor_Info.motion_dir = Motion_CW;
- Hor_Info.dir_now = Hor_Info.dir_range_ancw;
- else
- Hor_Info.motion_dir = Motion_ANCW;
- Hor_Info.dir_now = Hor_Info.dir_range_cw;
- while(1)
- //程序運(yùn)行指示燈
- cycle_cnt++;
- if(cycle_cnt > 1)
- LEDToggle();
- cycle_cnt =0;
- //垂直電機(jī)位置超出允許范圍,嘗試反向轉(zhuǎn)動(dòng)3次,失敗后,定義為振鏡異常
- if(OutOfRange == Hor_Info.motion_sta)
- Delay_ms(1000);
- if(fault_try<3)
- if(Stop== Hor_Info.motor_sta)
- MOTOR_DISEN_HOR;
- Hor_Info.motor_sta = Move;
- Hor_Info.motor_fb = FB_Enable;
- Move_Angles(Horizontal,Hor_Info.motion_dir,5); //嘗試反向轉(zhuǎn)5度,離開(kāi)限位開(kāi)關(guān)位置
- MOTOR_START_HOR;
- fault_try++;
- else
- Hor_Info.motion_sta = Fault;
- MOTOR_EN_HOR;
- else
- fault_try = 0;
- //收到一條命令
- if(1 == Cmd_FinishFlag)
- Cmd_LockFlag =0; //串口命令解鎖
- Cmd_FinishFlag =0;
- CMD_Analyse(Cmd_buf+1,30);
- memset(Cmd_buf,0,USARTBUFLEN); //USARTBUFLEN=100 串口命令最大長(zhǎng)度
- //void *memset(void *s,int c,size_t n) 將已開(kāi)辟內(nèi)存空間S的首個(gè)n字節(jié)的值設(shè)置為C
- sendbytes = sprintf(CmdRespondStr,NACKSTR); //sprintf字符串格式化命令,主要將格式化的數(shù)據(jù)寫(xiě)入字符串中
- if(0 == strncmp(para_list[0],"MOVE",sizeof("MOVE"))) //電機(jī)運(yùn)動(dòng)命令,sizeof返回字節(jié)大小
- { //strncmp ( const char * str1, const char * str2, size_t n );str1,str2為需要比較的字符串,n為比較數(shù)量
- //str1第一個(gè)字符減去str2第一個(gè)字符,若差值為0,則繼續(xù)比較下一個(gè)字符
- if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
- ver_hor = Vertical; //垂直
- else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
- ver_hor = Horizontal; //水平
- else
- ver_hor = Unknow;
- if(Unknow != ver_hor)
- if(0 == str2float(para_list[2],&angle_tmp))
- float end_angle=0;
- end_angle= Motor_Info[ver_hor].angle_now+angle_tmp;
- //當(dāng)前位置不能超過(guò)設(shè)定范圍
- if((end_angle >= -1*Motor_Info[ver_hor].limit_angle)&&(end_angle <= Motor_Info[ver_hor].limit_angle))
- if(angle_tmp >0)
- cw_ncw = Motion_CW; //步進(jìn)電機(jī)方向
- else if(angle_tmp <0)
- cw_ncw = Motion_ANCW;
- angle_tmp *= -1;
- else
- cw_ncw = Hold;
- else if(end_angle < -1*Motor_Info[ver_hor].limit_angle) //超過(guò)逆時(shí)針轉(zhuǎn)動(dòng)范圍
- angle_tmp = Motor_Info[ver_hor].angle_now + Motor_Info[ver_hor].limit_angle;
- else if(end_angle > Motor_Info[ver_hor].limit_angle) //超過(guò)順時(shí)針轉(zhuǎn)動(dòng)范圍
- angle_tmp = Motor_Info[ver_hor].limit_angle - Motor_Info[ver_hor].angle_now;
- else
- cw_ncw = Hold;
- //電機(jī)停止?fàn)顟B(tài)下,才能允許轉(zhuǎn)動(dòng)
- if((Hold != cw_ncw)&&(Stop == Motor_Info[ver_hor].motor_sta))
- // Motor_Info[ver_hor].move_pulsenum =(uint32_t)(angle_tmp*CODER_NUM);
- Move_Angles(ver_hor,cw_ncw,angle_tmp);
- sendbytes = sprintf(CmdRespondStr,ACKSTR);
- else
- sendbytes = sprintf(CmdRespondStr,BUSYSTR);
- // else
- // sendbytes = sprintf(CmdRespondStr,"AngleWrong_\r\n");
- else sendbytes = sprintf(CmdRespondStr,NACKSTR);
- else if(0 == strncmp(para_list[0],"CHECK",sizeof("CHECK"))) //查詢當(dāng)前電機(jī)狀態(tài)(是否在轉(zhuǎn))
- else
- ver_hor = Unknow;
- if(Move == Motor_Info[ver_hor].motor_sta)
- sendbytes = sprintf(CmdRespondStr,"MOVE_\r\n");
- else
- sendbytes = sprintf(CmdRespondStr,"HOLD_\r\n");
- else if(0 == strncmp(para_list[0],"STATUS",sizeof("STATUS"))) //查詢當(dāng)前電機(jī)狀態(tài)(是否在轉(zhuǎn))
- else
- ver_hor = Unknow;
- if(Stepslost == Motor_Info[ver_hor].motion_sta)
- sendbytes = sprintf(CmdRespondStr,"STEPSLOST_\r\n");
- else if(OutOfRange == Motor_Info[ver_hor].motion_sta)
- sendbytes = sprintf(CmdRespondStr,"OVERRANGE_\r\n");
- else if(Zero == Motor_Info[ver_hor].motion_sta)
- sendbytes = sprintf(CmdRespondStr,"ZERO_\r\n");
- else if(Fault == Motor_Info[ver_hor].motion_sta)
- sendbytes = sprintf(CmdRespondStr,"FAULT_\r\n");
- else
- sendbytes = sprintf(CmdRespondStr,"NORMAL_\r\n");
- else if(0 == strncmp(para_list[0],"STOP",sizeof("STOP"))) //運(yùn)動(dòng)停止命令
- else
- ver_hor = Unknow;
- if(Vertical == ver_hor)
- Ver_Info.motor_sta = Stop;
- Ver_Info.motor_fb = FB_Disable;
- MOTOR_STOP_VER;
- else
- Hor_Info.motor_sta = Stop;
- Hor_Info.motor_fb = FB_Disable;
- MOTOR_STOP_HOR;
- else if(0 == strncmp(para_list[0],"SET",sizeof("SET"))) //參數(shù)設(shè)置命令
- else
- ver_hor = Unknow;
- //電機(jī)停止時(shí),允許進(jìn)行參數(shù)設(shè)定
- if(Stop == Motor_Info[ver_hor].motor_sta)
- if(0 == strncmp(para_list[2],"DEVISION",sizeof("DEVISION"))) //設(shè)置細(xì)分比例
- devison_tmp = atoi(para_list[3]);
- if((devide_1 == devison_tmp)|(devide_2 == devison_tmp)|(devide_8 == devison_tmp)|(devide_16 == devison_tmp))
- Ver_Info.subdevision = (DEVISIONVALUE)devison_tmp;
- Ver_Info.step_resolution= MOTOR_RESOLUTION/(RATIO_GEAR*devison_tmp);
- Ver_Info.step_speed = 360.0f*Ver_Info.speed/(60.0f*Ver_Info.step_resolution);
- SPEEDSET_VER(1000000/Ver_Info.step_speed);
- Ver_Info.dir_range_cw = (int32_t)RATIO_GEAR*Ver_Info.subdevision*180/MOTOR_RESOLUTION; //順時(shí)針電機(jī)方位角范圍
- Ver_Info.dir_range_ancw = -1*(int32_t)RATIO_GEAR*Ver_Info.subdevision*180/MOTOR_RESOLUTION; //逆時(shí)針電機(jī)方位角范圍
- //更新EEPROM中保存的參數(shù)
- UPDATE_DEVISIONH_VER;
- UPDATE_STEPRE_VER;
- UPDATE_SPEED_VER;
- UPDATE_DIRRANGE_VER;
- else if(Horizontal == ver_hor)
- Hor_Info.subdevision =(DEVISIONVALUE)devison_tmp;
- Hor_Info.step_resolution= MOTOR_RESOLUTION/(RATIO_GEAR*devison_tmp);
- Hor_Info.step_speed = 360.0f*Hor_Info.speed/(60.0f*Hor_Info.step_resolution);
- SPEEDSET_HOR(1000000/Hor_Info.step_speed);
- Hor_Info.dir_range_cw = (int32_t)RATIO_GEAR*Hor_Info.subdevision*360/MOTOR_RESOLUTION; //順時(shí)針電機(jī)方位角范圍
- Hor_Info.dir_range_ancw = -1*(int32_t)RATIO_GEAR*Hor_Info.subdevision*360/MOTOR_RESOLUTION; //逆時(shí)針電機(jī)方位角范圍
- AT24CXX_Write(HORINFO_ADDR,(const uint8_t *)&Hor_Info,sizeof(MOTORINFO));
- UPDATE_DEVISIONH_HOR;
- UPDATE_STEPRE_HOR;
- UPDATE_SPEED_HOR;
- UPDATE_DIRRANGE_HOR;
- else if(0 == strncmp(para_list[2],"LOCATION",sizeof("LOCATION"))) //設(shè)置當(dāng)前位置對(duì)應(yīng)角度,手動(dòng)歸零時(shí)使用該命令
- if(0 == str2float(para_list[3],&angle_tmp))
- if((angle_tmp >= -185)&&(angle_tmp <= 185))
- Ver_Info.angle_now = angle_tmp;
- Ver_Info.dir_now = angle_tmp/360.0f*Ver_Info.dir_range_cw*2;
- UPDATE_ANGEL_VER;
- UPDATE_DIRNOW_VER;
- Hor_Info.angle_now = angle_tmp;
- Hor_Info.dir_now = angle_tmp/360.0f*Hor_Info.dir_range_cw*2;
- UPDATE_ANGEL_HOR;
- UPDATE_DIRNOW_HOR;
- else if(0 == strncmp(para_list[2],"SPEED",sizeof("SPEED"))) //設(shè)置轉(zhuǎn)動(dòng)速度
- speed_tmp = atof(para_list[3]);
- if((speed_tmp > 0)&&(speed_tmp <= 2000)) //分鐘轉(zhuǎn)速小于2000r/min
- Ver_Info.speed = speed_tmp;
- UPDATE_SPEED_VER;
- UPDATE_SPEEDSTEPS_VER;
- // AT24CXX_Write(VERINFO_ADDR,(const uint8_t *)&Ver_Info,sizeof(MOTORINFO));
- Hor_Info.speed = speed_tmp;
- // AT24CXX_Write(HORINFO_ADDR,(const uint8_t *)&Hor_Info,sizeof(MOTORINFO));
- UPDATE_SPEED_HOR;
- UPDATE_SPEEDSTEPS_HOR;
- else if(0 == strncmp(para_list[2],"LIMIT",sizeof("LIMIT"))) //設(shè)置轉(zhuǎn)動(dòng)范圍
- if(0 == str2float(para_list[3],&limit_tmp))
- if((limit_tmp > 0)&&(limit_tmp <= 361))
- Motor_Info[ver_hor].limit_angle = limit_tmp;
- UPDATE_LIMITANGEL_VER;
- else
- UPDATE_LIMITANGEL_HOR;
- else
- else if(0 == strncmp(para_list[0],"READ",sizeof("READ"))) //讀取細(xì)分參數(shù)命令
- else
- ver_hor = Unknow;
- if(0 == strncmp(para_list[2],"DEVISION",sizeof("DEVISION"))) //讀取細(xì)分比例
- sendbytes = sprintf(CmdRespondStr,"Vertical_Devision_%d_\r\n",Ver_Info.subdevision);
- sendbytes = sprintf(CmdRespondStr,"Horizontal_Devision_%d_\r\n",Hor_Info.subdevision);
- else if(0 == strncmp(para_list[2],"LOCATION",sizeof("LOCATION"))) //讀取當(dāng)前位置對(duì)應(yīng)角度
- sendbytes = sprintf(CmdRespondStr,"%.2f_\r\n",Ver_Info.angle_now);
- sendbytes = sprintf(CmdRespondStr,"%.2f_\r\n",Hor_Info.angle_now);
- else if(0 == strncmp(para_list[2],"SPEED",sizeof("SPEED"))) //讀取當(dāng)前位置對(duì)應(yīng)步進(jìn)速度
- sendbytes = sprintf(CmdRespondStr,"%.2d_\r\n",Ver_Info.step_speed);
- sendbytes = sprintf(CmdRespondStr,"%.2d_\r\n",Hor_Info.step_speed);
- sendbytes = sprintf(CmdRespondStr,"%.1f_\r\n",Ver_Info.limit_angle);
- sendbytes = sprintf(CmdRespondStr,"%.1f_\r\n",Hor_Info.limit_angle);
- else if(0 == strncmp(para_list[0],"ZERO",sizeof("ZERO"))) //角度歸零,待完善
- else
- ver_hor = Unknow;
- ZeroMotor(ver_hor);
- else if(0 == strncmp(para_list[0],"HELP",sizeof("HELP"))) //命令使用信息查詢
- usart_sendaddr =HelpMsg[0];
- sendbytes =strlen(HelpMsg[0]);
- else if(0 == strncmp(para_list[0],"RESET",sizeof("RESET"))) //系統(tǒng)復(fù)位命令
- //復(fù)位前,停止電機(jī)轉(zhuǎn)動(dòng)
- MOTOR_STOP_HOR;
- MOTOR_STOP_VER;
- Sys_Soft_Reset();
- else
- for(tmp=0;tmp<CMDPARANUM;tmp++)
- memset(para_list[tmp],0,PARASTRLEN);
- //DMA空閑時(shí),將數(shù)據(jù)發(fā)送出去
- if((0 == DMA_GetCurrDataCounter(PC_DMA_CHANNEL))&&(sendbytes > 0))
- UsartDMASend(usart_sendaddr,sendbytes);
- sendbytes =0;
- //將方位更新到角度,并判斷是否超過(guò)設(shè)定范圍
- Ver_Info.angle_now = (float)Ver_Info.dir_now*Hor_Info.step_resolution;
- Hor_Info.angle_now = (float)Hor_Info.dir_now*Hor_Info.step_resolution; //當(dāng)前的角度為實(shí)際脈沖數(shù)計(jì)算得到,angle_now=360*dir_now/(2*200*140) (細(xì)分比率*200*次輪比)
- UPDATE_ANGEL_HOR;
- UPDATE_ANGEL_VER;
- WG_Feed();
- * 名 稱: str2float()
- * 功 能:收到的角度是否合法
- * 入口參數(shù):
- * 出口參數(shù):
- * 說(shuō) 明:
- * 調(diào)用方法:
- * 修改日志:
- uint8_t charcnt;
- volatile uint8_t isok=1;
- uint8_t paracnt =0;
- uint8_t paracharcnt =0;
- uint8_t point_flag =0;
- uint8_t num_flag =0;
- uint8_t sym_flag =0;
- uint8_t sym_loc =0;
- for(charcnt=0;charcnt<PARASTRLEN;charcnt++)
- if(('-' == *(str+charcnt))|('-' == *(str+charcnt)))
- sym_flag = charcnt+1;
- if(sym_flag>1)
- break; //符號(hào)位超過(guò)一個(gè)
StepMotor_LV4(134口徑振鏡源代碼).7z
(180.66 KB, 下載次數(shù): 32)
2019-5-8 20:51 上傳
點(diǎn)擊文件名下載附件
