- #include<reg52.h>
- unsigned char code LedChar[10] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
- unsigned int cnt = 0;
- #define uchar unsigned char//宏定義
- #define uint unsigned int//宏定義
- bit flag=0;
- uchar b=0;//秒計(jì)數(shù)
- unsigned char i = 0;
- //unsigned char s1;
- sbit k1=P1^1;
- sbit k2=P1^4;
- sbit L1=P3^4;
- void Timer0Init(void);
- void key_scan();
- void delay(uint z)
- uint x,y;
- for(x = z; x > 0; x--)
- for(y = 114; y > 0 ; y--);
- void main()
- P0=0X00;
- Timer0Init();
- // display(0);
- while(1)
- key_scan();
- if(cnt>1000)
- cnt=0;
- b++;
- if(L1==0)
- ET0=1;
- P0=LedChar[b];
- if(b>9)
- L1=1;
- b=0;
- ET0=0;
- void key_scan()
- if(k1==0) //夜晚
- if(k1==0)
- if(k2==0) //有聲音
- delay(10);//延時(shí)10毫秒
- if(k2==0)
- L1=0;
- void InterruptTime0() interrupt 1
- TL0 = 0x18; //設(shè)置定時(shí)初值
- TH0 = 0xFC; //設(shè)置定時(shí)初值
- cnt++;
- void Timer0Init(void) //1毫秒@12.000MHz
- P1&= 0x7F; //定時(shí)器時(shí)鐘12T模式
- TMOD &= 0xF0; //設(shè)置定時(shí)器模式
- TMOD |= 0x01; //設(shè)置定時(shí)器模式
- TF0 = 0; //清除TF0標(biāo)志
- TR0 = 1; //定時(shí)器0開(kāi)始計(jì)時(shí)
- EA=1;
- ET0=0;
復(fù)制代碼 |
