查看: 6676|回復(fù): 2
基于51單片機(jī)和Proteus仿真的SD卡讀卡器
ID:517871 發(fā)表于 2019-5-9 16:25 | 顯示全部樓層 |閱讀模式
基于51單片機(jī)和Proteus仿真的SD卡讀卡器,包含C語言源程序及Proteus仿真電路圖,親測完全可用,部分代碼如下,全部代碼見附件
#include <AT89X52.H>
#define F_OSC  11059200//晶振平率Hz
#define F_BAUD 9600
#define RELOAD 256-F_OSC/12/32/F_BAUD
#define CR 0x0D        //回車
//定義SD卡需要的4根信號(hào)線
sbit SD_CLK = P1^4;
sbit SD_DI  = P1^6;
sbit SD_DO  = P1^5;
sbit SD_CS  = P1^7;
unsigned char xdata DATA[512];
//定義512字節(jié)緩沖區(qū),注意需要使用 xdata關(guān)鍵字
//寫一字節(jié)到SD卡,模擬SPI總線方式
void SdWrite(unsigned char n)
    unsigned char i;
    for(i=8;i;i--)
        SD_CLK=0;
        SD_DI=(n&0x80);
        n<<=1;
        SD_CLK=1;
        SD_DI=1;
//從SD卡讀一字節(jié),模擬SPI總線方式
unsigned char SdRead()
    unsigned char n,i;
    for(i=8;i;i--)
        SD_CLK=0;
        SD_CLK=1;
        n<<=1;
        if(SD_DO) n|=1;
    return n;
//檢測SD卡的響應(yīng)
unsigned char SdResponse()
    unsigned char i=0,response;
    while(i<=8)
        response = SdRead();
        if(response==0x00)
        break;
        if(response==0x01)
        break;
        i++;
    return response;
//發(fā)命令到SD卡
void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC)
    SdWrite(command|0x40);
    SdWrite(((unsigned char *)&argument)[0]);
    SdWrite(((unsigned char *)&argument)[1]);
    SdWrite(((unsigned char *)&argument)[2]);
    SdWrite(((unsigned char *)&argument)[3]);
    SdWrite(CRC);
//初始化SD卡
unsigned char SdInit(void)
    int delay=0, trials=0;
    unsigned char i;
    unsigned char response=0x01;
    SD_CS=1;
    for(i=0;i<=9;i++)
    SdWrite(0xff);
    SD_CS=0;
    //Send Command 0 to put MMC in SPI mode
    SdCommand(0x00,0,0x95);
    response=SdResponse();
    if(response!=0x01)
        return 0;
    while(response==0x01)
        SD_CS=1;
        SdWrite(0xff);
        SD_CS=0;
        SdCommand(0x01,0x00ffc000,0xff);
    SD_CS=1;
    SdWrite(0xff);
    return 1;
//往SD卡指定地址寫數(shù)據(jù),一次最多512字節(jié)
unsigned char SdWriteBlock(unsigned char *Block, unsigned long address,int len)
    unsigned int count;
    unsigned char dataResp;
    //Block size is 512 bytes exactly
    //First Lower SS
    SD_CS=0;
    //Then send write command
    SdCommand(0x18,address,0xff);
    if(SdResponse()==00)
        SdWrite(0xff);
        SdWrite(0xff);
        SdWrite(0xff);
        //command was a success - now send data
        //start with DATA TOKEN = 0xFE
        SdWrite(0xfe);
        //now send data
        for(count=0;count<len;count++) SdWrite(*Block++);
        for(;count<512;count++) SdWrite(0);
        //data block sent - now send checksum
        SdWrite(0xff); //兩字節(jié)CRC校驗(yàn), 為0XFFFF 表示不考慮CRC
        SdWrite(0xff);
        //Now read in the DATA RESPONSE token
        dataResp=SdRead();
        //Following the DATA RESPONSE token
        //are a number of BUSY bytes
        //a zero byte indicates the MMC is busy
        while(SdRead()==0);
        dataResp=dataResp&0x0f; //mask the high byte of the DATA RESPONSE token
        SD_CS=1;
        SdWrite(0xff);
        if(dataResp==0x0b)
        //printf("DATA WAS NOT ACCEPTED BY CARD -- CRC ERROR\n");
        return 0;
        if(dataResp==0x05)
        return 1;
        //printf("Invalid data Response token.\n");
        return 0;
    //printf("Command 0x18 (Write) was not received by the MMC.\n");
    return 0;
//從SD卡指定地址讀取數(shù)據(jù),一次最多512字節(jié)
unsigned char SdReadBlock(unsigned char *Block, unsigned long address,int len)
    unsigned int count;
    //First Lower SS
     //printf("MMC_read_block\n");
    SD_CS=0;
    SdCommand(0x11,address,0xff);
        while(SdRead()!=0xfe);
        for(count=0;count<len;count++) *Block++=SdRead();
        for(;count<512;count++) SdRead();
        SdRead();
        SdRead();
        SD_CS=1;
        SdRead();
        return 1;
//printf("Command 0x11 (Read) was not received by the MMC.\n");
    return 0;
         串口初始化
void UART()
    SCON=0x40;//工作與方式1不允許接受
    TMOD=0x20;//定時(shí)器1工作與方式2自動(dòng)重裝模式
    TH1=RELOAD;
    TR1=1;
    TI=0;
//通過串口發(fā)送一個(gè)字符串
void Sen_String(unsigned char *string)
    while(*string!='\0')
        if(*string=='\n')
            SBUF=CR;
            SBUF=*string;
        while(TI==0);
        TI=0;
        string++;
    UART();
    while(!SdInit()); //等待SD卡初始化完成
    SdWriteBlock("THIS IS A TEST!",0x000000,15);//寫入字符串,然后讀出進(jìn)行檢驗(yàn)
    SdReadBlock(DATA,0x000000,15);
    Sen_String(DATA);        //發(fā)出數(shù)據(jù)
全部資料51hei下載地址:
基于51單片機(jī)和Proteus仿真的SD卡讀卡器.zip (215.48 KB, 下載次數(shù): 186)
ID:636592 發(fā)表于 2019-12-24 12:46 | 顯示全部樓層
大佬,右邊那個(gè)TXD腳的是個(gè)啥設(shè)備啊?帶帶我,多謝~
ID:10641 發(fā)表于 2020-5-4 09:46 | 顯示全部樓層
有沒有寫入文件的例子
